ABX00022
ABX00022
    ARDUINO
    ARDUINO MKR VIDOR 4000
ABX00022 数据手册
MKR VIDOR 4000 Looking for a board for a very specific use that Arduino doesn’t make? Or maybe you want a more complex central board, optimized for your particular needs that will interface with all other Arduino boards and devices. The MKR VIDOR 4000 is highly configurable and powerful, and it perform high-speed digital audio and video processing. STORE.ARDUINO.CC/ARDUINO-MKR-VIDOR-4000 MKR VIDOR 4000 ARDUINO MICROCONTROLLER With the MKR VIDOR 4000 you can configure it the way you want; you can essentially create your own controller board. It comes loaded with hardware and potential: an 8 MB SDRAM; a 2 MB QSPI Flash chip — 1 MB allocated for user applications; a Micro HDMI connector; an MIPI camera connector; and Wifi & BLE powered by U-BLOX NINA W10 Series. It also includes the classic MKR interface on which all pins are driven both by SAMD21 and FPGA. Plus, it has a Mini PCI Express connector with up to 25 user programmable pins. Microcontroller SAMD21 Architecture ARM Cortex-M0+ 32bit plus Cyclone 10 Operating Voltage 3.3V Flash Memory 256 KB SRAM 32 KB Clock Speed 48 MHz DC Current per I/O Pin 3 mA (I/O Pins) GENERAL Connectivity Wi-Fi w/ NINA W102 Peripherals Programmable Cyclone 10 accelerator w/ 8MB RAM The FPGA contains 16K Logic Elements, 504 KB of embedded RAM, and 56 18x18 bit HW multipliers for high-speed DSP. Each pin can toggle at over 150 MHz and can be configured for functions such as UARTs, (Q)SPI, high resolution/high frequency PWM, quadrature encoder, I2C, I2S, Sigma Delta DAC, etc. Digital I/O Pins 20 (headers) +32 (mPCI) Interfaces I2C, SPI, UART, mPCI express MIPI Camera, miniHDMI PWM Output 12 (D21)/22 (Cyclone 10) Analog I/O Pins 7/1 Power Consumption < 100 mA < 10 mA Weight 9 g Product Code ABX00022 (low power, Wi-Fi off)
ABX00022 价格&库存
很抱歉,暂时无法提供与“ABX00022”相匹配的价格&库存,您可以联系我们找货
ABX00022
  • 1+520.69186
库存:586
