AKX00034
AKX00034
    ARDUINO
    CD4081BNSR,CD40106BNSR,CD40109BNSRG4,LT3652HV,MP2322,MP1542,MC14067BDWG,TPS54620,TS13102,TCA6424A,W2...
AKX00034 数据手册
Arduino® Edge Control Product Datasheet SKU: AKX00034 Description The Arduino Edge Control board is designed to address the needs of precision farming. It provides a low power control system, suitable for irrigation with modular connectivity. The board is compatible with MKR Boards 2G/3G/CatM1/NBIoT, LoRa, Sigfox and WiFi/BT connectivity. Target areas: Agriculture measurements, smart irrigation systems, hydroponics Features ■ Nina B306 Module 128 bit AES/ECB/CCM/AAR ■ ■ Processor co-processor ■ 64 MHz Arm® Cortex-M4F (with FPU) ■ 1 MB Flash + 256 KB RAM ■ 1 MB internal Flash memory ■ Wireless ■ 2MB onboard QSPI ■ Bluetooth (BLE 5 via Cordio stack, ■ SD Card slot ■ Memory BLE 4.2 via Arduino Stack) ■ Advertising Extensions ■ +8 dBm TX power ■ Low Power ■ 95 dBm sensitivity ■ 200uA Sleep current ■ 4.8 mA in TX (0 dBm) ■ Can operate for up to 34 months on a ■ 4.6 mA in RX (1 Mbps) ■ Peripherals ■ Full-speed 12 Mbps USB ■ Arm CryptoCell CC310 security ■ 12V/5Ah battery ■ QSPI/SPI/TWI/I²S/PDM/QDEC ■ High speed 32 MHz SPI ■ Quad SPI interface 32 MHz ■ 12-bit 200 ksps ADC 12 V Acid/lead SLA Battery Supply (Recharged via solar panels) subsystem ■ Power ■ RTC CR2032 Lithium Battery back up ■ Battery ■ LT3652 Solar Panel Battery Charger Input Supply Voltage Regulation Loop ■ ■ for Peak Power Tracking in (MPPT) 4x 60V/2.5A galvanically isolated solid state relays Solar applications ■ 6x 18 pin plug in terminal block connectors ■ I/O ■ 6x edge sensitive wake up pins ■ 16x hydrostatic watermark sensor ■ Individual power control input ■ Individual Serial Port ■ 8x 0-5V analog inputs ■ Individual I2C ports ■ 4x 4-20mA inputs ■ 8x latching relay command outputs with drivers ■ 8x latching relay command outputs without drivers ■ ■ Dual MKR Socket Safety information ■ Class A Contents 1. The board 5 1.1 Application examples 5 1.2 Accessories 5 1.3 Related products 5 2. Specifications 6 2.1 Absolute maximum ratings 6 2.2 Recommended Operating Conditions 6 3. Functional Overview 6 3.1 Board Topology 6 3.2 Processor 8 3.3 5V Analog Sensors 9 3.4 4-20mA sensors 9 3.5 Watermark Sensors 10 3.6 Latching outputs 10 3.7 Solid State Relays 11 3.8 Storage 11 3.9 Power tree 12 3.10 Solution overview 13 4. Board Operation 13 4.1 Getting started - IDE 13 4.2 Getting started - Arduino Web Editor 13 4.3 Getting started - Arduino IoT Cloud 13 4.4 Sample Sketches 14 4.5 Online resources 14 4.6 Board Recovery 14 5. Connector Pinouts 14 5.1 USB 14 5.2 J11 Power/Relay connector 14 5.3 J3 Wake up signals/External relay commands 15 5.4 J7 Analog/4-20mA 15 5.5 J8 Watermark 16 5.6 J9 Latching relay (+/- VBAT) 16 5.7 J10 Latching relay command (0-5) 17 5.8 J1 LCD Connector 18 6. Mechanical Information 19 6.1 Board outline 19 6.2 Mounting holes 19 6.3 Connector Positions 7. Certifications 20 21 7.1 Declaration of Conformity CE DoC (EU) 21 7.2 Declaration of Conformity to EU RoHS & REACH 211 01/19/2021 21 7.3 Conflict Minerals Declaration 22 8. FCC Caution 22 9. Company information 24 10. Reference Documentation 24 11. Revision History 24 1. The board 1.1 Application examples The Arduino Edge Control is your gateway to Agriculture 4.0. Get real-time insight into the state of your process and increase crop yield. Improve business efficiency through automation and predictive farming. Tailor the Edge Control to your needs by using up two Arduino MKR Boards and an assortment of compatible Shields. Maintain historical records, automate quality control, implement crop planning and more through the Arduino IoT Cloud from anywhere in the world. Automated Greenhouses: In order to minimise carbon emissions and increase economic yield, it is important to ensure that the best environment is provided for the growth of crops in terms of humidity, temperature and other factors. The Arduino Edge Control is an integrated platform that enables remote monitoring and real-times optimization to this end. Including a Arduino MKR GPS Shield (SKU:ASX00017) allows for optimum crop rotation planning and acquisition of geospatial data. Hydroponics/Aquaponics: Since hydroponics involves the growth of plants without soil, delicate care must be maintained to ensure they maintain the narrow window required for optimum growth. The Arduino Edge Control can ensure that this window is achieved with minimal manual labour. Aquaponics can provide even more benefits than conventional hydroponics towards which the Arduino Edge Control can help match the even higher requirements by providing better control over the internal process while ultimately reducing production risks. Mushroom Cultivation: Mushrooms are notorious for requiring the perfect temperature and humidity conditions to sustain spore growth while also preventing competing fungi from growing. Thanks to the numerous watermark sensors, output ports and connectivity options available on the Arduino Edge Control as well as the Arduino IoT Cloud, this precision farming can be achieved on an unprecedented level. 1.2 Accessories - Irrometer Tensiometers - Watermark soil moisture sensors - Mechanized ball valves - Solar panel - 12V/5Ah acid/lead SLA battery (11 - 13.3V) 1.3 Related products - LCD Display + Flat Cable + plastic enclosure - 1844646 Phoenix contacts (included with the product) - Arduino MKR family boards (for expanding wireless connectivity) 1.4 Solution overview Example of a typical application for a solution including LCD Display and two Arduino MKR 1300 boards. 2. Ratings 2.1 Absolute maximum ratings Symbol Description TMax VBattMax VSolarMax ARelayMax PMax Maximum thermal limit Maximum input voltage from battery input Maximum input voltage from solar panel Maximum current through relay switch Maximum Power Consumption Min -40 -0.3 -20 - Typ Max Unit 20 12 18 - 85 17 20 2.4 5000 °C V V A mW Typ Max Unit 20 12 18 60 20 °C V V 2.2 Recommended Operating Conditions Symbol Description T VBatt VSolar Conservative thermal limits Input voltage from battery input Input voltage from solar panel Min -15 16 3. Functional Overview 3.1 Board Topology Top View Ref. Description Ref. Description U1 LT3652HV battery charger IC PB1 Reset pushbutton U2 MP2322 3.3V buck converter IC J1 LCD Module Connector U3 MP1542 19V boost converter IC J3,7,9,8,10,11 1844798 pluggable terminal blocks U4 TPS54620 5V boost converter IC J6 Micro SD Card U5 CD4081BNSR AND gate IC J4 CR2032 battery holder U6 CD40106BNSR NOT gate IC J5 Micro USB (NINA Module) U12,U17 MC14067BDWG multiplexer IC U8 TCA6424A IO expander IC U16 CD40109BNSRG4 I/O Expander U9 NINA-B306 Module U18,19,20,21 TS13102 solid state relay IC U10 ADR360AUJZ-R2 Voltage reference series 2.048V IC LED1 On board LED Back View Ref. Description Ref. Description U11 W25Q16JVZPIQ Flash 16M IC Q3 ZXMP4A16GTA MOSFET P-CH 40V 6.4A U7 CD4081BNSR AND gate IC U14, 15 MC14067BDWG IC MUX 3.2 Processor The Main Processor is a Cortex M4F running at up to 64MHz. 3.1 LCD Screen The Arduino Edge Control provides a dedicated connector (J1) for interfacing with a HD44780 16x2 LCD display module, sold seperately. The main processor controls the LCD via a TCA6424 port expander over I2C. Data is transferred over a 4-bit interface. LCD backlight intensity is also adjustable by the main processor. 3.3 5V Analog Sensors Up to eight 0-5V analog inputs can be connected to J4 for interfacing analog sensors such as tensiometers and dendrometers. Inputs are protected by a 19V Zener diode. Each input is connected to an analog multiplexer that channels the signal to a single ADC port. Each input is connected to an analog multiplexer (MC14067) that channels the signal to a single ADC port. The main processor controls the input selection via a TCA6424 port expander over I2C. 3.4 4-20mA sensors Up to four 4-20mA sensors can be connected to J4. A reference voltage of 19V is generated by the MP1542 step-up converter to power the current loop. The sensor value is read via a 220 ohm resistor. Each input is connected to an analog multiplexer (MC14067) that channels the signal to a single ADC port. The main processor controls the input selection via a TCA6424 port expander over I2C. 3.5 Watermark Sensors Up to sixteen hydrostatic watermark sensors can be connected to J8. Pins J8-17 and J8-18 are the common sensor pins for all the sensors, controlled directly by the microcontroller. Inputs and the common sensor pins are protected by a 19V Zener diode. Each input is connected to an analog multiplexer (MC14067) that channels the signal to a single ADC port. The main processor controls the input selection via a TCA6424 port expander over I2C. The board supports 2 precision modes. 3.6 Latching outputs Connectors J9 and J10 provide outputs to latching devices like motorized valves. The latching output consists of dual channels (P and N) through which an impulse or strobe can be sent in either of the 2 channels (to open a close valve for example). The duration of the strobes can be configured to adjust to the external device requirement. The board provides a total of 16 latching ports divided in 2 types: ● Latching commands (J10): 8 ports for high impedance inputs ( max +/- 25 mA). Connect to external devices with third-party protection/power circuits. Referenced to VBAT. ● Latching Out (J9): 8 ports. This outputs includes drivers for the latching device. No external drivers are needed. Referenced to VBAT. 3.7 Solid State Relays The board features four configurable 60V 2.5A solid state relays with galvanic isolation available in J11. Typical applications include HVAC, sprinkler control etc. 3.8 Storage The board includes both a microSD card socket and an additional 2MB flash memory for data storage. Both are directly connected to the main processor via a SPI interface. 3.9 Power tree The board can be powered via solar panels and/or SLA batteries. 4. Board Operation 4.1 Getting started - IDE If you want to program your Arduino Edge Control while offline you need to install the Arduino Desktop IDE [1] To connect the Arduino Edge control to your computer, you’ll need a Micro-B USB cable. This also provides power to the board, as indicated by the LED. 4.2 Getting started - Arduino Web Editor All Arduino boards, including this one, work out-of-the-box on the Arduino Web Editor [2], by just installing a simple plugin. The Arduino Web Editor is hosted online, therefore it will always be up-to-date with the latest features and support for all boards. Follow [3] to start coding on the browser and upload your sketches onto your board. 4.3 Getting started - Arduino IoT Cloud All Arduino IoT enabled products are supported on Arduino IoT Cloud which allows you to Log, graph and analyze sensor data, trigger events, and automate your home or business. 4.4 Sample Sketches Sample sketches for the Arduino Edge Control can be found either in the “Examples” menu in the Arduino IDE or in the “Documentation” section of the Arduino Pro website [4]. 4.5 Online resources Now that you have gone through the basics of what you can do with the board you can explore the endless possibilities it provides by checking exciting projects on ProjectHub [5], the Arduino Library Reference [6] and the online store [7] where you will be able to complement your board with sensors, actuators and more. 4.6 Board Recovery All Arduino boards have a built-in bootloader which allows flashing the board via USB. In case a sketch locks up the processor and the board is not reachable anymore via USB it is possible to enter bootloader mode by double-tapping the reset button right after power up. 5. Connector Pinouts 5.1 J1 LCD Module Connector Pin Function Type Description 1 PWM Power Backlight LED Cathode (PWM control) 2 Power On Digital Button input 3 +5V LCD Power LCD power supply 4 LCD RS Digital LCD RS signal 5 Contrast Analog LCD Contrast control 6 LCD RW Digital LCD Read/Write signal 7 LED+ Power Backlight LED Anode 8 LCD EN Digital LCD Enable signal 10 LCD D4 Digital LCD D4 signal 12 LCD D5 Digital LCD D5 signal 14 LCD D6 Digital LCD D6 signal 16 LCD D7 Digital LCD D7 signal 9,11,13,15 GND Power Ground 5.2 J3 Wake up signals/External relay commands Pin Function Type Description 1,3,5,7,9 V BAT Power Gated voltage battery for wake up signal reference 2,4,6,8,10,12 Input Digital Edge sensitive wake up signals 13 Output Digital External solid state relay clock signal 1 14 Output Digital External solid state relay clock signal 2 17 Bidir Digital External solid state relay data signal 1 18 Bidir Digital External solid state relay data signal 2 15,16 GND Power Ground 5.3 J5 USB Pin Function Type Description 1 V USB Power Power Supply Input Note: A board powered only via V USB will not enable most of the features of the board. Check the power tree in Section 3.8 2 D- Differential USB differential data - 3 D+ Differential USB differential data + 4 ID NC Unused 5 GND Power Ground 5.4 J7 Analog/4-20mA Pin Function Type Description 1,3,5,7 +19V Power 4-20mA voltage reference 2 IN1 Analog 4-20mA input 1 4 IN2 Analog 4-20mA input 2 6 IN3 Analog 4-20mA input 3 8 IN4 Analog 4-20mA input 4 9 GND Power Ground 10 +5V Power 5V output for 0-5V analog reference 11 A5 Analog 0-5V input 5 12 A1 Analog 0-5V input 1 13 A6 Analog 0-5V input 6 14 A2 Analog 0-5V input 2 15 A7 Analog 0-5V input 7 16 A3 Analog 0-5V input 3 17 A8 Analog 0-5V input 8 18 A4 Analog 0-5V input 4 5.5 J8 Watermark Pin Function Type Description 1 WaterMrk1 Analog Watermark input 1 2 WaterMrk2 Analog Watermark input 2 3 WaterMrk3 Analog Watermark input 3 4 WaterMrk4 Analog Watermark input 4 5 WaterMrk5 Analog Watermark input 5 6 WaterMrk6 Analog Watermark input 6 7 WaterMrk7 Analog Watermark input 7 8 WaterMrk8 Analog Watermark input 8 9 WaterMrk9 Analog Watermark input 9 10 WaterMrk10 Analog Watermark input 10 11 WaterMrk11 Analog Watermark input 11 12 WaterMrk12 Analog Watermark input 12 13 WaterMrk13 Analog Watermark input 13 14 WaterMrk14 Analog Watermark input 14 15 WaterMrk15 Analog Watermark input 15 16 WaterMrk16 Analog Watermark input 16 17,18 VCOMMON Digital Sensor common voltage 5.6 J9 Latching out (+/- VBAT) Pin Function Type Description 1 PULSE_OUT0_P Digital Latching output 1 positive 2 PULSE_OUT0_N Digital Latching output 1 negative 3 PULSE_OUT1_P Digital Latching output 2 positive 4 PULSE_OUT1_N Digital Latching output 2 negative 5 PULSE_OUT2_P Digital Latching output 3 positive 6 PULSE_OUT2_N Digital Latching output 3 negative 7 PULSE_OUT3_P Digital Latching output 4 positive 8 PULSE_OUT3_N Digital Latching output 4 negative 9 PULSE_OUT4_P Digital Latching output 5 positive 10 PULSE_OUT4_N Digital Latching output 5 negative 11 PULSE_OUT5_P Digital Latching output 6 positive 12 PULSE_OUT5_N Digital Latching output 6 negative 13 PULSE_OUT6_P Digital Latching output 7 positive 14 PULSE_OUT6_N Digital Latching output 7 negative 15 PULSE_OUT7_P Digital Latching output 8 positive 16 PULSE_OUT7_N Digital Latching output 8 negative 17,18 GND Power Ground 5.7 J10 Latching command (+/- VBAT) Pin Function Type Description 1 STOBE8_P Digital Latching command 1 positive 2 STOBE8_N Digital Latching command 1 negative 3 STOBE9_P Digital Latching command 2 positive 4 STOBE9_N Digital Latching command 2 negative 5 STOBE10_P Digital Latching command 3 positive 6 STOBE10_N Digital Latching command 3 negative 7 STOBE11_P Digital Latching command 4 positive 8 STOBE11_N Digital Latching command 4 negative 9 STOBE12_N Digital Latching command 5 positive 10 STOBE12_P Digital Latching command 5 negative 11 STOBE13_P Digital Latching command 6 positive 12 STOBE13_N Digital Latching command 6 negative 13 STOBE14_P Digital Latching command 7 positive 14 STOBE14_N Digital Latching command 7 negative 15 STOBE15_P Digital Latching command 8 positive 16 STOBE15_N Digital Latching command 8 negative 17 GATED_VBAT_PULSE Power Gated Positive terminal of battery 18 GND Power Ground 5.8 J11 Relay (+/- VBAT) Pin Function Type Description 1 SOLAR+ Power Solar Panel Positive Terminal 2 NC NC Unused 3 GND Power Ground 4 RELAY1_P Switch Relay 1 positive 5 NC NC Unused 6 RELAY1_N Switch Relay 1 negative 7 NC NC Unused 8 RELAY2_P Switch Relay 2 positive 9 NC NC Unused 10 RELAY2_N Switch Relay 2 negative 11 10kGND Power Ground via 10k resistor 12 RELAY3_P Switch Relay 3 positive 13 NTC Analog Negative temperature coefficient (NTC) thermoresistor 14 RELAY3_N Switch Relay 3 negative 15 GND Power Ground 16 RELAY4_P Switch Relay 4 positive 17 BATTERY+ Power Battery Positive Terminal 18 RELAY4_N Switch Relay 4 negative 6. Mechanical Information 6.1 Board outline 6.2 Mounting holes 6.3 Connector Positions 7. Certifications 7.1 Declaration of Conformity CE DoC (EU) We declare under our sole responsibility that the products above are in conformity with the essential requirements of the following EU Directives and therefore qualify for free movement within markets comprising the European Union (EU) and European Economic Area (EEA). ROHS 2 Directive 2011/65/EU Conforms to: EN50581:2012 Directive 2014/35/EU. (LVD) Conforms to: EN 60950-1:2006/A11:2009/A1:2010/A12:2011/AC:2011 Directive 2004/40/EC & 2008/46/EC & 2013/35/EU, EMF Conforms to: EN 62311:2008 7.2 Declaration of Conformity to EU RoHS & REACH 211 01/19/2021 Arduino boards are in compliance with RoHS 2 Directive 2011/65/EU of the European Parliament and RoHS 3 Directive 2015/863/EU of the Council of 4 June 2015 on the restriction of the use of certain hazardous substances in electrical and electronic equipment. Substance Lead (Pb) Cadmium (Cd) Mercury (Hg) Hexavalent Chromium (Cr6+) Poly Brominated Biphenyls (PBB) Poly Brominated Diphenyl ethers (PBDE) Bis(2-Ethylhexyl} phthalate (DEHP) Benzyl butyl phthalate (BBP) Dibutyl phthalate (DBP) Diisobutyl phthalate (DIBP) Exemptions : No exemptions are claimed. Maximum Limit (ppm) 1000 100 1000 1000 1000 1000 1000 1000 1000 1000 Arduino Boards are fully compliant with the related requirements of European Union Regulation (EC) 1907 /2006 concerning the Registration, Evaluation, Authorization and Restriction of Chemicals (REACH). We declare none of the SVHCs (https://echa.europa.eu/web/guest/candidate-list-table), the Candidate List of Substances of Very High Concern for authorization currently released by ECHA, is present in all products (and also package) in quantities totaling in a concentration equal or above 0.1%. To the best of our knowledge, we also declare that our products do not contain any of the substances listed on the "Authorization List" (Annex XIV of the REACH regulations) and Substances of Very High Concern (SVHC) in any significant amounts as specified by the Annex XVII of Candidate list published by ECHA (European Chemical Agency) 1907 /2006/EC. 7.3 Conflict Minerals Declaration As a global supplier of electronic and electrical components, Arduino is aware of our obligations with regards to laws and regulations regarding Conflict Minerals, specifically the Dodd-Frank Wall Street Reform and Consumer Protection Act, Section 1502. Arduino does not directly source or process conflict minerals such as Tin, Tantalum, Tungsten, or Gold. Conflict minerals are contained in our products in the form of solder, or as a component in metal alloys. As part of our reasonable due diligence Arduino has contacted component suppliers within our supply chain to verify their continued compliance with the regulations. Based on the information received thus far we declare that our products contain Conflict Minerals sourced from conflict-free areas. 8. FCC Caution Any Changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate the equipment. This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference (2) this device must accept any interference received, including interference that may cause undesired operation. FCC RF Radiation Exposure Statement: 1. This Transmitter must not be co-located or operating in conjunction with any other antenna or transmitter. 2. This equipment complies with RF radiation exposure limits set forth for an uncontrolled environment. 3. This equipment should be installed and operated with minimum distance 20cm between the radiator & your body. English: User manuals for licence-exempt radio apparatus shall contain the following or equivalent notice in a conspicuous location in the user manual or alternatively on the device or both. This device complies with Industry Canada licence-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference (2) this device must accept any interference, including interference that may cause undesired operation of the device. French: Le présent appareil est conforme aux CNR d’Industrie Canada applicables aux appareils radio exempts de licence. L’exploitation est autorisée aux deux conditions suivantes : (1) l’ appareil ne doit pas produire de brouillage (2) l’utilisateur de l’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement. IC SAR Warning: English This equipment should be installed and operated with minimum distance 20 cm between the radiator and your body. French: Lors de l’ installation et de l’ exploitation de ce dispositif, la distance entre le radiateur et le corps est d ’au moins 20 cm. Important: The operating temperature of the EUT can’t exceed 85℃ and shouldn’t be lower than -40℃. Hereby, Arduino S.r.l. declares that this product is in compliance with essential requirements and other relevant provisions of Directive 2014/53/EU. This product is allowed to be used in all EU member states. Frequency bands Maximum output power (ERP) 863-870Mhz -3.22dBm 9. Company information Company name Arduino S.r.l. Company Address Via Ferruccio Pelli 14, 6900 Lugano, TI (Ticino), Switzerland 10. Reference Documentation Ref Link 1. Arduino IDE (Desktop) https://www.arduino.cc/en/Main/Software 2. Arduino IDE (Cloud) https://create.arduino.cc/editor 3. Cloud IDE Getting Started https://create.arduino.cc/projecthub/Arduino_Genuino/getting-st arted-with-arduino-web-editor-4b3e4a 4. Arduino Pro Website https://www.arduino.cc/pro 5. Project Hub https://create.arduino.cc/projecthub?by=part&part_id=11332&so rt=trending 6. Library Reference https://github.com/bcmi-labs/Arduino_EdgeControl/tree/4dad0d 95e93327841046c1ef80bd8b882614eac8 7. Online Store https://store.arduino.cc/ 11. Revision History Date Revision Changes 02/21/2020 02/10/2021 1 2 First Release Design/structure update
AKX00034 价格&库存
很抱歉,暂时无法提供与“AKX00034”相匹配的价格&库存,您可以联系我们找货
AKX00034
    • 1+1595.64087
    库存:79
    AKX00034
    • 1+1283.13052
    • 10+1265.58321
    • 25+1249.38969
    • 100+1234.53956
    库存:45
