ASX00007
ASX00007
    ARDUINO
    Grove 转 MKR 接口 MKR 平台评估扩展板
ASX00007 数据手册
MKR CONNECTOR CARRIER The perfect companion for the MKR boards & grove ecosystem. Want to connect several Seeed Studio Grove modules to your Arduino board? The Arduino MKR CONNECTOR CARRIER is the perfect companion for Arduino MKR boards and a Grove ecosystem. STORE.ARDUINO.CC/ARDUINO-MKR-CONNECTION-SHIELD MKR CONNECTOR CARRIER Do you have several components to connect to your project and would rather use connectors instead of soldering? The Arduino MKR CONNECTOR CARRIER provides Seeed Studio's Grove connectors to your MKR board. The MKR CONNECTOR CARRIER shield is an essential tool for rapidly prototyping activity. It allows you to connect easily and quickly sensors with Grove connectors. This shield can allow you to build applications with different IoT connectivities by simply changing the MKR board and with almost no changes to the code. GENERAL Input Voltage 7V-16 V Analog Inputs 7 Digital I/Os 7 Interfaces UART, I2C Power Consumption 5mA Weight 25 g Product Code ASX00007
ASX00007 价格&库存
很抱歉,暂时无法提供与“ASX00007”相匹配的价格&库存,您可以联系我们找货
ASX00007
    • 1+49.11355
    库存:730
    ASX00007
      • 1+139.09660
      库存:1
