AS3561
Class-H Stereo Headphone Amplifier
General Description
The AS3561 is a Class-H stereo headphone amplifier optimized
for usage within portable devices. The Class-H supply rail
adaptation is implemented by an integrated DCDC buck
converter that takes its input directly from the battery. The
continuous adoption of supply rails is done according to the
input signal swing and load conditions. This architecture
implements significant power savings compared to traditional
Class-AB amplifiers.
An I²C control interface is implemented for a 32-step volume
control including a mute function for each channel separately.
The integrated charge pump generates a symmetric negative
supply for true ground output signal levels without the need of
output coupling capacitors. In addition it helps to lower the
overall pop noise of the amplifier.
A supervisory circuit is included for overtemperature and
short-circuit protection.
Differential inputs together with output ground sensing
guarantees very low noise sensitivity.
Ordering Information and Content Guide appear at end of
datasheet.
Key Benefits & Features
The benefits and features of the AS3561 Class-H stereo
headphone amplifier, are listed below:
Figure 1:
Added value of using AS3561
Benefits
Features
Highly optimized system power
consumption
H-Class amplifier with integrated DCDC buck converter
• 2x30mW, 0.02% THD @ 16Ω
• 100dB SNR @ 0.9Vrms
• 1mA quiescent with both channels enabled
Popless startup and mute/unmute
Ultra low DC offset
Full digital system control
Direct Li-Ion battery operation
Wide supply range 2.3V to 5.5V
No DC blocking capacitors
Charge pump for true ground headphone operation
Highest Noise Immunity
Two fully differential stereo inputs with ground sensing input
PCB area optimized
Package: 0.4mm Pitch WL-CSP (1.615 x 1.615mm)
ams Datasheet
[v1-07] 2014-Sep-26
Page 1
Document Feedback
AS3561 − General Description
Applications
The AS3561 applications include:
• Mobile Phones
• Portable Navigation Devices
• Media Devices
Block Diagram
The functional blocks of this device for reference are
shown below:
Figure 2:
AS3561 Block Diagram
Page 2
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Pin Assignments
The AS3561 pin assignments are described below:
Pin Assignments
Figure 3:
Pin Assignments (Top View)
Pin Descriptions
Figure 4:
Pin Descriptions
Pin Name
Pin Number
SW
A1
Buck converter switching node
AVDD
A2
Primary power supply for device
HPL
A3
Left channel headphone amplifier output
INLN
A4
Inverting left input for differential signals;
Connect to left input signal through 2.2μF capacitor for single-ended
input applications
AGND
B1
Main Ground for headphone amplifiers, DC/DC converter, and charge
pump
CPP
B2
Charge pump positive flying cap; connect to 2.2μF flying capacitor
HPVDD
B3
Power supply for headphone amplifier (DC/DC output node)
INLP
B4
Non-inverting left input for differential signals;
Connect to ground through 2.2μF capacitor for single-ended input
applications
ams Datasheet
[v1-07] 2014-Sep-26
Description
Page 3
Document Feedback
Pin Name
Pin Number
CPN
C1
Charge pump negative flying cap; connect to 2.2μF flying capacitor
HPVSS
C2
Charge pump output; connect 2.2μF capacitor to GND
SGND
C3
Ground sense; connect to headphone jack ground
INRP
C4
Non-Inverting right input for differential signals;
Connect to right input signal through 2.2μF capacitor for single-ended
input applications
SDA
D1
I²C Data; 1.8V logic compliant
SCL
D2
I²C Clock; 1.8V logic compliant
HPR
D3
Right channel headphone amplifier output
INRN
D4
applications
Page 4
Document Feedback
Description
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Absolute Maximum Ratings
Stresses beyond those listed under “Absolute Maximum
Ratings” may cause permanent damage to the device. These are
stress ratings only. Functional operation of the device at these
or any other conditions beyond those indicated under
Operating Conditions is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect
device reliability.
Figure 5:
Symbol
AVDD
HPVDD
Parameter
Min
Max
Unit
Supply voltage
-0.3
7
V
Amplifier supply voltage
-0.3
2.0
V
-0.3
0.3
V
Differential Input voltage
HPVSS - 0.3V
HPVDD + 0.3V
V
Input voltage at SCL, SDA
-0.3
7.0
V
Breakdown voltage at
amplifier outputs
-0.5
HPVDD + 0.5
V
±200
mA
Norm: JEDEC 78
PT (1)
SGND
Input current (latchup
immunity)
Comments
for 1ms peaks
Continuous Power Dissipation
Continuous power
dissipation
TBD
mW
Continuous power
dissipation derating factor
TBD
mW/°C
PDERATE (2)
Electrostatic Discharge
ESD HBM
±2
kV
Norm: MIL 883 E
Method 3015
ESD MM
±100
V
Norm: JEDEC JESD
22-A115-A level A
ESD CDM
±500
V
Norm: JEDEC JESD
22-C101C
ams Datasheet
[v1-07] 2014-Sep-26
Page 5
Document Feedback
Symbol
Parameter
Min
Max
Unit
Comments
Temperature Range and Storage Conditions
Junction Temperature
Storage Temperature
Range
Humidity non-condensing
Moisture Sensitive Level
Package Body Temperature
+150
°C
-55
+125
°C
5
85
internally limited
(overtemperature
protection)
auto shutdown at
140°C
Represents a max.
floor life time of
unlimited
1
+260
The reflow peak
soldering temperature
(body temperature)
specified is in
accordance with
IPC/JEDEC J-STD-020
“Moisture/Reflow
Sensitivity Classification
for Non-Hermetic Solid
State Surface Mount
Devices”.
Note(s) and/or Footnote(s):
1. Depending on actual PCB layout and PCB used
2. P DERATE derating factor changes the total continuous power dissipation (PT ) if the ambient temperature is not 70°C.
Therefore for e.g. TAMB=85°C calculate P T at 85°C = P T - PDERATE * (85°C - 70°C)
Page 6
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Electrical Characteristics
All limits are guaranteed. The parameters with min and max
values are guaranteed with production tests or
SQC (Statistical Quality Control) methods.
AVDD=3.6V, TA=25°C, Rload = 32Ω unless otherwise specified.
Figure 6:
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
5.5
V
General Operating Conditions
AVDD
Supply Voltage
2.3
Rail Voltages HPVDD,
HPVSS
(Buck and CP output)
0.8
0.9
1.0
V
1.15
1.25
1.35
V
1.7
1.8
1.9
V
IDD
Quiescent Current
both channels
enabled, no audio
signal
0.9
1.5
mA
ISD
Shutdown Current
SW shutdown
1.8
5
μA
Output: 2 × 100μW
@ 3dB Crest Factor
1.7
2.3
mA
Output: 2 × 500μW
@ 3dB Crest Factor
2.85
3.6
mA
Output: 2 × 1mW @
3dB Crest Factor
3.7
4.6
mA
25
+85
°C
10
15
ms
0.6
V
IS
Supply Current
TA
tWAKEUP
Operating Temperature
Range
-30
Wakeup Time
Input Interfaces
VIL
Low-level input voltage
(SCL, SDA)
AVDD 2.9V to 4.5V
VIH
High-level input voltage
(SCL, SDA)
AVDD 2.9V to 4.5V
VHYST
Hysteresis (SCL, SDA)
ZIN
Input Impedance Line
Inputs
ams Datasheet
[v1-07] 2014-Sep-26
1.2
50
V
100
200
mV
Differential
kΩ
Single Ended
10
kΩ
Page 7
Document Feedback
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
HPA Output
Output Voltage
Rload=16Ω, THD +
N=1%, L+R out of
phase
0.7
Vrms
Rload=32Ω, THD +
N=1%, L+R in
phase
0.9
Vrms
VOUT
Output DC Offset
Both channels
enabled
Output Impedance
In HiZ mode <
40KHz
10
kΩ
In HiZ mode for
6MHz
500
Ω
In HiZ mode for
36MHz
75
Ω
ZOUT
500
Voltage applied to
Output; HPR, HPL
when SWS = 0,
HiZ_L = HiZ_R =
1,device in HI-Z
mode
-1.8
Capacitive Load
ext. cap, 15Ω series
resistor
0.8
5
μV
1.8
V
100
nF
100
pF
CLOAD
ext cap, directly
connected
Output impedance in
shutdown
SWS = 1
Voltage applied to
Output; HPR, HPL
when SWS = 1,
device disabled
8
kΩ
ZOOT,SD
-0.3
3.6
V
0.04
Audio Parameters
Total Harmonic
Distortion + Noise
700mVrms, 1KHz
PSRR
Power Supply Rejection
Ratio
Gain 0dB @ 217Hz
SNR
Signal-to-Noise Ratio
Channel Separation
THD + N
VN
Output Noise
0.02
90
dB
900mVrms, 1KHz
104
dB
>16Ω (Headset)
60
dB
>10kΩ (Lineout)
80
dB
Gain 0dB,
A-weighted
5.3
9
μVrms
Other Parameters
Thermal Shutdown
Threshold
140
Hysteresis
°C
Page 8
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Detailed Operating Characteristics
Detailed Operating
Characteristics
TA = 25°C, AVDD (VDD) = 3.6V, GAIN = 0dB, CHPVDD = 10μF,
CHPVSS = 2.2μF, CINPUT = C FLYING = 2.2μF. RL = 32Ω unless
Figure 7:
THD + N versus output power for AVDD = 2.5V,RL = 32Ω
10
THD+N [%]
1
0,1
0,01
Lef t
Right
0,001
1 Pout (mW) 10
100
A
0,1
Figure 8:
THD + N versus output power for AVDD = 2.5V,RL = 16Ω
10
THD+N [%]
1
0,1
0,01
Lef t
Right
0,001
0,1
ams Datasheet
[v1-07] 2014-Sep-26
1 Pout (mW) 10
100
Page 9
Document Feedback
Figure 9:
THD + N versus output power for AVDD = 3.6V,RL = 32Ω
10
THD+N [%]
1
0,1
0,01
Lef t
Right
0,001
0,1
1 Pout (mW) 10
100
Figure 10:
THD+ N versus output power for AVDD = 3.6V,RL = 16Ω
10
THD+N [%]
1
0,1
0,01
Lef t
Right
0,001
0,1
Page 10
Document Feedback
1 Pout (mW) 10
100
ams Datasheet
[v1-07] 2014-Sep-26
Figure 11:
THD + N versus output power for AVDD = 5.5V,RL = 32Ω
10
THD+N [%]
1
0,1
0,01
Lef t
Right
0,001
0,1
1 Pout (mW) 10
100
Figure 12:
THD + N versus output power for AVDD = 5.5V,RL = 16Ω
10
THD+N [%]
1
0,1
0,01
Lef t
Right
0,001
0,1
ams Datasheet
[v1-07] 2014-Sep-26
1 Pout (mW) 10
100
Page 11
Document Feedback
Figure 13:
THD + N versus Frequency for AVDD = 2.5V,RL = 32Ω
1
1mW
10mW
20mW
THD+N [%]
0,1
0,01
0,001
0,0001
10
100
1000
10000
100000
f [Hz]
Figure 14:
THD + N versus Frequency for AVDD = 2.5V,RL = 16Ω
1
1mW
10mW
20mW
THD+N [%]
0,1
0,01
0,001
0,0001
10
100
1000
10000
100000
f [Hz]
Page 12
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
Figure 15:
THD + N versus Frequency for AVDD = 3.6V,RL = 32Ω
1
1mW
10mW
20mW
THD+N [%]
0,1
0,01
0,001
0,0001
10
100
1000
10000
100000
f [Hz]
Figure 16:
THD + N versus Frequency for AVDD = 3.6V,RL = 16Ω
1
1mW
10mW
20mW
THD+N [%]
0,1
0,01
0,001
0,0001
10
100
1000
10000
100000
f [Hz]
ams Datasheet
[v1-07] 2014-Sep-26
Page 13
Document Feedback
Figure 17:
THD + N versus Frequency for AVDD = 5.5V,RL = 32Ω
1
1mW
10mW
20mW
THD+N [%]
0,1
0,01
0,001
0,0001
10
100
1000
10000
100000
f [Hz]
Figure 18:
THD + N versus Frequency for AVDD = 5.5V,RL = 16Ω
1
1mW
10mW
20mW
THD+N [%]
0,1
0,01
0,001
0,0001
10
100
1000
10000
100000
f [Hz]
Page 14
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
Figure 19:
Supply Current vs. POUT for AVDD=2.5V
(Pout is the output power per channel)
I(AVDD) [mA]
100
10
16 Ohm
32 Ohm
1
0,1
1 Pout (mW) 10
100
Figure 20:
Ptotal vs. POUT for AVDD = 2.5V
Ptotal [mA]
1000
100
10
16 Ohm
32 Ohm
1
0,1
ams Datasheet
[v1-07] 2014-Sep-26
1 Pout (mW) 10
100
Page 15
Document Feedback
Figure 21:
Supply Current vs. POUT for AVDD=3.6V
I(AVDD) [mA]
100
10
16 Ohm
32 Ohm
1
0,1
1 Pout (mW) 10
100
Figure 22:
Ptotal vs. POUT for AVDD = 3.6V
Ptotal [mW]
1000
100
10
16 Ohm
32 Ohm
1
0,1
Page 16
Document Feedback
1 Pout (mW) 10
100
ams Datasheet
[v1-07] 2014-Sep-26
Figure 23:
Supply Current vs. POUT for AVDD=5.5V
I(AVDD) [mA]
100
10
16 Ohm
32 Ohm
1
0,1
1 Pout (mW) 10
100
Figure 24:
Ptotal vs. POUT for AVDD = 5.5V
1000
Ptotal [mW]
100
10
16 Ohm
32 Ohm
1
0,1
ams Datasheet
[v1-07] 2014-Sep-26
1 Pout (mW) 10
100
Page 17
Document Feedback
Figure 25:
Quiescent Current Consumption vs. AVDDI
2
Audio On
Audio Of f
I(AVDD) [mA]
1,5
1
0,5
3
4
5
AVDD [V]
PSRR [dB]
Figure 26:
PSRR vs. Frequency (200mVpkpk supply ripple)
-20
-30
-40
-50
-60
-70
-80
-90
-100
-110
-120
-130
-140
HPVDD
10
100
1000
10000
100000
f [Hz]
Page 18
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
Figure 27:
Crosstalk vs. Frequency (700mVrms, RL = 32Ω)
Crosstalk[dB]
-20
-30
-40
-50
-60
-70
-80
-90
-100
10
100
1000
10000
100000
f [Hz]
Figure 28:
Startup Pop Noise for AVDD = 3.6V and RL=16Ω
2,5
1
AVDD
2
0,9
0,8
AVDD [V]
0,7
1,5
0,6
0,5
1
0,4
0,3
0,5
0,2
Headphone Output [mV]
Headphone Output
0,1
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
t (ms)
ams Datasheet
[v1-07] 2014-Sep-26
Page 19
Document Feedback
Figure 29:
Startup Pop Noise for AVDD = 3.6V and RL=32Ω
2,5
1
AVDD
2
0,9
0,8
AVDD [V]
0,7
1,5
0,6
0,5
1
0,4
0,3
0,5
0,2
Headphone Output
0,1
t (ms)
Page 20
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Detailed Description
I²C Control Interface
An I²C slave interface is implemented for read/write access of
the internal registers. SCL is the corresponding clock input pin
and SDA the data input pin.
Access is done in 7-bit addressing mode, addresses for read and
write are defined by
C0h = 11000000b … write
C1h = 11000001b … read
Figure 30:
I²C Block Diagram
10k
10k
SCL
SDA
Registers
I2C
Interface
AS3561
START
STOP
SR
T
Figure 31:
I²C Timing Definition
AS3561
START
STOP
SR
THD;STA
SDA
TLO
TF
SCL
THD;STA
TR
THI
ams Datasheet
[v1-07] 2014-Sep-26
TSU;DAT
TSU;STA
TSU;STO
TSP
Page 21
Document Feedback
Figure 32:
I²C Timing Parameters
Symbol
Parameter
TSP
Spike Insensitivity
THI
High Clock Time
Condition
Min
Typ
50
100
Max
Unit
ns
330
ns
660
ns
400KHz clock speed
TLO
Low Clock Time
TSU
SDA has to change Tsetup
before rising edge of SCLK
30
ns
THD
no hold time needed for SDA
relative to rising edge of
CSCL
-40
ns
300
ns
100
ns
100
ns
THD;STA
TST;SUO
TST;STA
Within start condition, after low going SDA, SCL has to stay
constant for the specified hold time
After high going edge of SCL, SDA has to stay constant for the
specified setup time before STOP or repeated start condition is
applied
Page 22
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Register Definition
Register Definition
Register Overview
Figure 33:
Register Overview
Register
Description
Enable Register (1h)
General control register to switch on/off the device and enable the
headphone amplifier stages.
Volume Register (2h)
Allows the use to configure the output volume of the headphone amplifier
from -59dB up to +4dB.
HiZ Register (3h)
Configures the headphone amplifier for a high impedance output for power
optimization.
Info Register (4h)
This register contains general information like IC version number and supplier
information.
Detailed Register Descriptions
Figure 34:
Bit
Bit Name
Default
Access
Bit 7
HP_EN_L
RW
0 … Disable Headphone Left; 1 … Enable
Headphone Left Channel
Bit 6
HP_EN_R
RW
0 … Disable Headphone Right;1 … Enable
Headphone Right Channel
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Thermal
S_RC
0 … Normal Operation;1 … Thermal Shutdown
Bit 0
SWS
1
RW
0 … Normal Operation;1 … Software Shutdown
ams Datasheet
[v1-07] 2014-Sep-26
Bit Description
Page 23
Document Feedback
Figure 35:
Bit
Bit Name
Default
Access
Bit 7
Mute_L
1
RW
0 … Unmuted Left Channel;
1 … Mute Left Channel
Bit 6
Mute_R
1
RW
0 … Unmuted Right Channel;
1 … Mute Right Channel
0d … -55 dB;
1d … -52 dB;
2d … -49 dB;
3d … -46 dB;
4d … -43 dB;
5d … -39 dB;
6d … -35 dB;
7d … -31 dB;
8d … -27 dB;
9d … -25 dB;
10d … -23 dB;
11d … -21 dB;
12d … -19 dB;
13d … -17 dB;
14d … -15 dB;
15d … -13 dB;
16d … -11 dB;
17d … -10 dB;
18d … -9 dB;
19d … -8 dB;
20d … -7 dB;
21d … -6 dB;
22d … -5 dB;
23d … -4 dB;
24d … -3 dB;
25d … -2 dB;
26d … -1 dB;
27d … 0 dB;
28d … 1 dB;
29d … 2 dB;
30d … 3 dB;
31d … 4 dB
Bit[5:1]
Vol[4:0]
RW
Bit 0
Bit Description
Figure 36:
HiZ Register (3h)
Bit
Bit Name
Default
Access
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
HiZ_L
RW
0 … Normal Operation;1 … High Impedance on
HPH_Output Left
Bit 0
HiZ_R
RW
HPH_Output Right
Page 24
Document Feedback
Bit Description
ams Datasheet
[v1-07] 2014-Sep-26
Figure 37:
Info Register (4h)
Bit
Bit Name
Default
Supplier Bit [1:0]
RO
Bit 7
Access
1
Bit 6
1
Bit Description
11b … Default Supplier ID;
else … unused
Bit 5
Bit 4
Bit 3
Bit 2
Version Bit [3:0]
Bit 1
Bit 0
ams Datasheet
[v1-07] 2014-Sep-26
0 … First Version;
else … unused
Page 25
Document Feedback
Input Left
U4
Input Right
U2
R 2
GND 1
L
3
R 2
GND 1
L
3
R 2
GND 1
Stereo Single Ended
3
INLN_MEAS
INLP_MEAS
INRN_MEAS
INRP_MEAS
T3
SGND
D3
ESD
D2
ESD
ESD
D8
ESD
D4
ESD
D9
ESD
D5
2.2uF
J19
En. Stereo Left
2.2uF
C8
2.2uF
2.2uF
C7
C6
C5
A4
B4
D4
C4
INLN
INLP
INRN
INRP
J20
En. Stereo Right
INLN
INLP
INRN
INRP
T2
2.2uF
C3
AVDD
CPN
10uF
C1
AS3561
SCL
HPVSS
L
2.2uF
C2
CPP
3.3uH
L1
SW
A1
SW
A2
AVDD
SCL
SDA
SCL
D1
SDA
SDA
D2
HPVDD
B3
HPVDD
B2
CPP
C1
CPN
C2
HPVSS
AGND
Page 26
Document Feedback
GND
B1
U5
SGND
HPR
HPL
ESD
D6
SGND
HPR
D3
C3
HPL
A3
U1
AS3561
2.2uF
C4
ESD
D7
T1
L
U3
2 R
1 GND
3
Headphone
AS3561 − Application Information
Figure 38:
AS3561 Application Board
ams Datasheet
[v1-07] 2014-Sep-26
SGND
GND Connections
The SGND pin is an input reference and must be connected to
the headphone ground connector pin. This ensures no turn-on
pop and minimizes output offset voltage. Do not connect more
than ±0.3V to SGND. AGND is a power ground. Connect supply
decoupling capacitors for AVDD, HPVDD, and HPVSS to AGND.
External Elements
1 × 3.3μH Coil (SW-HPVDD)
7 × 2.2μF ±10% X5R (AVDD, CPP-CPN, HPVSS, INRP, INRN, INLP,
INLN)
1 × 10μF ±10% X5R (HPVDD)
Software Shutdown
Set software shutdown by writing a logic 1 in
Enable Register (1h), bit 0 (SWS bit). Software shutdown places
the device in the lowest power state. See “Operating
Conditions” on page 7 for values. Engaging software shutdown
turns off the buck regulator and charge pump and disables the
amplifier outputs. Write a logic 0 to the SWS bit to reactivate
the device.
Note(s): When the device is in SWS mode all registers will
maintain their values. The HP_EN_L and HP_EN_R bits can be
reset because a full word must be used when writing just one
bit to the register.
Note that I²C read and write access is still possible in shutdown
mode.
ams Datasheet
[v1-07] 2014-Sep-26
Page 27
Document Feedback
AS3561 − Package Drawings and Markings
Markings
Figure 39:
WCSP (1.615x1.615mm) Marking
Figure 40:
Packaging Code XXXX)
XXXX
encoded Datecode
1. The device is available in a WCSP (1.615x1.615mm) package.
Page 28
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
Figure 41:
WCSP (1.615 x 1.615mm) Package
Green
RoHS
1. ccc Coplanarity
2. All dimension are in μm
ams Datasheet
[v1-07] 2014-Sep-26
Page 29
Document Feedback
AS3561 − Ordering & Contact Information
Figure 42:
Ordering Code
Description
Delivery Form
Package
AS3561-DWLT
AS3561 Class-H Stereo Headphone Amplifier
Tape & Reel
WL-CSP 16
AS3561-DWLT-500
Tape & Reel
WL-CSP 16
Buy our products or get free samples online at:
www.ams.com/ICdirect
Technical Support is available at:
www.ams.com/Technical-Support
Provide feedback about this document at:
www.ams.com/Document-Feedback
For further information and requests, e-mail us at:
ams_sales@ams.com
For sales offices, distributors and representatives, please visit:
www.ams.com/contact
Headquarters
ams AG
Tobelbaderstrasse 30
8141 Unterpremstaetten
Austria, Europe
Tel: +43 (0) 3136 500 0
Website: www.ams.com
Page 30
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − RoHS Compliant & ams Green Statement
Statement
RoHS: The term RoHS compliant means that ams AG products
fully comply with current RoHS directives. Our semiconductor
products do not contain any chemicals for all 6 substance
categories, including the requirement that lead not exceed
0.1% by weight in homogeneous materials. Where designed to
be soldered at high temperatures, RoHS compliant products are
suitable for use in specified lead-free processes.
ams Green (RoHS compliant and no Sb/Br): ams Green
defines that in addition to RoHS compliance, our products are
free of Bromine (Br) and Antimony (Sb) based flame retardants
(Br or Sb do not exceed 0.1% by weight in homogeneous
material).
Important Information: The information provided in this
statement represents ams AG knowledge and belief as of the
date that it is provided. ams AG bases its knowledge and belief
on information provided by third parties, and makes no
representation or warranty as to the accuracy of such
information. Efforts are underway to better integrate
information from third parties. ams AG has taken and continues
to take reasonable steps to provide representative and accurate
information but may not have conducted destructive testing or
chemical analysis on incoming materials and chemicals. ams AG
and ams AG suppliers consider certain information to be
proprietary, and thus CAS numbers and other limited
information may not be available for release.
ams Datasheet
[v1-07] 2014-Sep-26
Page 31
Document Feedback
AS3561 − Copyrights & Disclaimer
Copyright ams AG, Tobelbader Strasse 30, 8141
Unterpremstaetten, Austria-Europe. Trademarks Registered. All
rights reserved. The material herein may not be reproduced,
adapted, merged, translated, stored, or used without the prior
written consent of the copyright owner.
Devices sold by ams AG are covered by the warranty and patent
indemnification provisions appearing in its General Terms of
Trade. ams AG makes no warranty, express, statutory, implied,
or by description regarding the information set forth herein.
ams AG reserves the right to change specifications and prices
at any time and without notice. Therefore, prior to designing
this product into a system, it is necessary to check with ams AG
for current information. This product is intended for use in
commercial applications. Applications requiring extended
temperature range, unusual environmental requirements, or
high reliability applications, such as military, medical
life-support or life-sustaining equipment are specifically not
recommended without additional processing by ams AG for
each application. This product is provided by ams AG “AS IS”
and any express or implied warranties, including, but not
limited to the implied warranties of merchantability and fitness
for a particular purpose are disclaimed.
ams AG shall not be liable to recipient or any third party for any
damages, including but not limited to personal injury, property
damage, loss of profits, loss of use, interruption of business or
indirect, special, incidental or consequential damages, of any
kind, in connection with or arising out of the furnishing,
performance or use of the technical data herein. No obligation
or liability to recipient or any third party shall arise or flow out
of ams AG rendering of technical or other services.
Page 32
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Document Status
Document Status
Document Status
Product Preview
Preliminary Datasheet
Datasheet
Datasheet (discontinued)
ams Datasheet
[v1-07] 2014-Sep-26
Product Status
Definition
Pre-Development
Information in this datasheet is based on product ideas in
the planning phase of development. All specifications are
design goals without any warranty and are subject to
change without notice
Pre-Production
Information in this datasheet is based on products in the
design, validation or qualification phase of development.
The performance and parameters shown in this document
are preliminary without any warranty and are subject to
Production
ramp-up to full production or full production which
conform to specifications in accordance with the terms of
ams AG standard warranty as given in the General Terms of
Trade
Discontinued
Information in this datasheet is based on products which
Trade, but these products have been superseded and
should not be used for new designs
Page 33
Document Feedback
AS3561 − Revision Information
Changes from 1-06 (2014-Aug-26) to current revision 1-07 (2014-Sep-26)
Page(1)
Updated Key Benefits and Features section
1
Updated Figure2
2
Updated Figure 3
3
1. Page numbers for the previous version may differ from page numbers in the current revision.
Page 34
Document Feedback
ams Datasheet
[v1-07] 2014-Sep-26
AS3561 − Content Guide
Content Guide
ams Datasheet
[v1-07] 2014-Sep-26
1
1
2
2
General Description
Applications
Block Diagram
3
3
Pin Assignments
Pin Descriptions
5
7
9
21
21
23
23
23
Register Definition
Register Overview
26
27
27
27
GND Connections
External Elements
Software Shutdown
28
30
31
32
33
34
Document Status
Page 35
Document Feedback
