Eval Kit Manual
DN[Document ID]
AS6200
Adapter Board
AS6200-WL_EK_AB
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 1
Document Feedback
AS6200 Adapter Board
Content Guide
1
Introduction .......................................................................................................................... 3
1.1
Kit Content ........................................................................................................................... 3
2
Getting Started ..................................................................................................................... 4
3
Hardware Description........................................................................................................... 4
3.1
Hardware Architecture ......................................................................................................... 4
3.2
AS6200 Configuration .......................................................................................................... 5
3.3
Power Supply and Connections ........................................................................................... 5
4
Software Description ............................................................................................................ 6
4.1
Index Register ...................................................................................................................... 6
4.2
Temperature Register .......................................................................................................... 7
5
Schematics, Layers and BOM ............................................................................................. 8
5.1
Schematics ........................................................................................................................... 8
5.2
Layout and Board Dimensions ............................................................................................. 9
5.3
Bill of Materials ................................................................................................................... 10
6
Copyrights & Disclaimer ..................................................................................................... 12
7
Revision Information .......................................................................................................... 13
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 2
Document Feedback
1
Introduction
The AS6200 adapter board is a small PCB allowing a simple and quick evaluation of the AS6200
digital temperature sensor without the need to design a custom PCB. This small form factor board is
fully assembled with the AS6200 temperature sensor and its necessary external components.
1.1
Kit Content
This kit contains following material listed in
Table 1: Kit Content.
Figure 1: adapter board
Pos.
Item
Comment
1
AS6200-EK-AB
Eval kit adapter board
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 3
Document Feedback
2
Getting Started
The AS6200 adapter board is ideal for rapid setup of a digital temperature sensor. To get started
connect the board to your microcontroller configuration as described in Figure 3: I²C connection.
Add a command in your source code to request two bytes from the selected I²C address. Finally
convert the returned data as described in chapter 4.2 Temperature Register to get the actual
temperature value.
3
The P1 connector does provide all relevant signals which can be easily wired to a microcontroller
and power supplied with a voltage of 1.8 to 3.6V
Pin
Symbol
Description
Info
1
SCL
I²C clock
Use R1 if pull-up is required
2
SDA
I²C data
Use R2 if pull-up is required
3
GND
Ground
4
VDD
Power supply
1,8 – 3,6 V
5
IRQ
Digital output pin
Alert interrupt output
Table 2 Adapter board pin-out
3.1
P1 connector
Address
selector
AS6200
Figure 2: AS6200 adapter board
R1, R2 and R3 are pull-up resistors for the I²C interface and the Alert pin.
Depending on the application, it is recommended to either populate the decoupling capacitor C1 or
C2.
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 4
Document Feedback
3.2
With the address selector it is possible to choose the I²C address of the device The included jumper
is an easy way of setting the I²C address of the sensor. The address selector must not be left open.
Address Selector
Device Address
GND
100 1000
0x48
VDD
100 1001
0x49
Table 3: I²C address
3.3
The PCB has to be connected to an external microcontroller. P1 is populated with a 1x5 pin header
and is required for power supply as well as I²C communication. In addition to that it can be used to
monitor the interrupt status via pin 5 (IRQ).
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 5
Document Feedback
4
The AS6200 has 4 data registers. With the use of the index register, it is possible to address the
specific data register. When powered up the address register is set to 0x0.
0x0
TVAL (Read Only)
0x1
CONFIG (Read/Write)
0x2
SCLK
TLOW (Read/Write)
0x3
Serial Interface
SDA
THIGH (Read/Write)
INDEX (Read/Write)
For additional configuration settings the Config register (0x1) has to be addressed. Please refer the
data sheet for details.
Address Symbol
0x0
0x1
TVAL
Register
Description
Temperature Register Contains the temperature value
CONFIG Configuration Register Configuration settings of the temperature sensor
0x2
TLOW
TLOW Register
Low temperature threshold value
0x3
THIGH
THIGH Register
High temperature threshold value
Table 4: Configuration Register
4.1
Index Register
The index register contains 8 bit, but only D0 and D1 are used.
Bit
D7
D6
D5
D4
D3
D2
Value
D1
D0
Address Bits
Table 5: Index Register
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 6
Document Feedback
4.2
D15
D14
D13
D12
D11
D10
D9
D8
D7
D6
D5
D4
D3
D2
D1
D0
T11
T10
T9
T8
T7
T6
T5
T4
T3
T2
T1
T0
MSB Byte
LSB Byte
Table 6: Temperature Register
The temperature register contains the digitally converted temperature value. It
consists of 2 byte and can be converted according to the following formula:
Positive values= |Value| / LSB
Negative values= Complement( |Value| / LSB ) + 1
Example +75°C
75°𝐶 / 0.0625°𝐶 = 1200 = 𝐵𝑖𝑛𝑎𝑟𝑦 0100 1011 0000 = 𝐻𝑒𝑥 4𝐵0
Example -40°C
|−40°𝐶| / 0.0625°𝐶 + 1 = 640 + 1 = 𝐵𝑖𝑛𝑎𝑟𝑦 0010 1000 0000 + 1 = 1101 0111 1111 + 1 =
1101 10000 0000 = 𝐻𝑒𝑥 𝐷80
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 7
Document Feedback
5
The schematics, layout and BOM of the adapter board are shown below for reference.
5.1
Schematics
The schematics of the board is shown below in Figure 4: Schematics.
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 8
Document Feedback
5.2
The PCB layout is shown below in Figure 5: Top Layer and Figure 6: Bottom Layer.
Figure 5: Top Layer
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 9
Document Feedback
The board dimensions are shown below in Figure 7: Dimensions.
5.3
Bill of Materials
The BOM of the board is shown below in Table 7: BOM.
Position
Name
Value
1
R7
NP
2
R6
NP
3
R5
NP
4
R4
NP
5
R3
10K
6
R2
10K
7
R1
10K
8
P1
Header 5
9
C2
NP
10
C1
10nF
11
AS6200
AS6200 WLCSP
Table 7: BOM
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 10
Document Feedback
Ordering & Contact Information
Ordering Code
Description
AS6200-WL_EK_AB
AS6200 Eval Kit Adapter Board
Buy our products or get free samples online at:
www.ams.com/ICdirect
Technical Support is available at:
www.ams.com/Technical-Support
Provide feedback about this document at:
www.ams.com/Document-Feedback
For further information and requests, e-mail us at:
ams_sales@ams.com
For sales offices, distributors and representatives, please visit:
www.ams.com/contact
Headquarters
ams AG
Tobelbaderstrasse 30
8141 Premstaetten
Austria, Europe
Tel: +43 (0) 3136 500 0
Website: www.ams.com
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 11
Document Feedback
6
Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks
Registered. All rights reserved. The material herein may not be reproduced, adapted, merged,
translated, stored, or used without the prior written consent of the copyright owner.
Demo Kits, Evaluation Kits and Reference Designs are provided to recipient on an “as is” basis for
demonstration and evaluation purposes only and are not considered to be finished end-products
intended and fit for general consumer use, commercial applications and applications with special
requirements such as but not limited to medical equipment or automotive applications. Demo Kits,
Evaluation Kits and Reference Designs have not been tested for compliance with electromagnetic
compatibility (EMC) standards and directives, unless otherwise specified. Demo Kits, Evaluation Kits
and Reference Designs shall be used by qualified personnel only.
ams AG reserves the right to change functionality and price of Demo Kits, Evaluation Kits and
Reference Designs at any time and without notice.
Any express or implied warranties, including, but not limited to the implied warranties of
merchantability and fitness for a particular purpose are disclaimed. Any claims and demands and any
direct, indirect, incidental, special, exemplary or consequential damages arising from the inadequacy
of the provided Demo Kits, Evaluation Kits and Reference Designs or incurred losses of any kind (e.g.
loss of use, data or profits or business interruption however caused) as a consequence of their use
are excluded.
ams AG shall not be liable to recipient or any third party for any damages, including but not limited to
personal injury, property damage, loss of profits, loss of use, interruption of business or indirect,
special, incidental or consequential damages, of any kind, in connection with or arising out of the
furnishing, performance or use of the technical data herein. No obligation or liability to recipient or
any third party shall arise or flow out of ams AG rendering of technical or other services.
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 12
Document Feedback
7
Changes from previous version to current revision 1-00 (2016-Jun-01)
Page
Initial version 1-00
Note: Page numbers for the previous version may differ from page numbers in the current revision.
Correction of typographical errors is not explicitly mentioned.
ams Eval Kit Manual
[v1-00] 2016-Jun-01
Page 13
Document Feedback
很抱歉,暂时无法提供与“AS6200-WL_EK_AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+195.62403
- 5+191.71884
