AS7341-DLGM
AS7341-DLGM
    AMSOSRAM(艾迈斯半导体)
    TFLGA8
    颜色传感器 16 b 8-TFLGA
AS7341-DLGM 数据手册
Datasheet DS000504 AS7341 11-Channel Spectral Sensor Frontend v2-00 • 2019-Apr-16 Document Feedback AS7341 Content Guide Content Guide 1 General Description....................... 3 1.1 1.2 1.3 Key Benefits & Features .............................. 3 Applications .................................................. 4 Block Diagram .............................................. 4 9.1 9.2 9.3 9.4 9.5 I²C Address ................................................ 21 I²C Write Transaction ................................. 21 I²C Read Transaction ................................. 22 Timing Characteristics ............................... 22 Timing Diagrams ........................................ 23 2 Ordering Information ..................... 5 10 Register Description ................... 24 3 Pin Assignment ............................. 6 3.1 3.2 Pin Diagram .................................................. 6 Pin Description ............................................. 6 10.1 10.2 Register Overview ...................................... 24 Detailed Register Description .................... 26 11 Application Information .............. 58 4 Absolute Maximum Ratings .......... 7 5 Electrical Characteristics .............. 8 11.1 11.2 11.3 Schematic .................................................. 58 PCB Pad Layout......................................... 59 Application Optical Requirements .............. 60 6 Optical Characteristics .................. 9 12 Package Drawings & Markings... 61 7 Typical Operating Characteristics ............................. 15 13 Tape & Reel Information ............. 62 8 Functional Description ................ 16 14 Soldering & Storage Information 64 14.1 Storage Information ................................... 65 8.1 8.2 8.3 8.4 8.5 Channel Architecture .................................. 17 Sensor Array .............................................. 18 GPIO/INT .................................................... 18 SMUX ......................................................... 18 Integration Mode ........................................ 19 15 Revision Information ................... 66 16 Legal Information ........................ 67 9 I²C Interface .................................. 21 Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 2 Document Feedback 1 AS7341 General Description General Description AS7341 is an 11-channel spectrometer for spectral identification and color matching applications used in mobile devices. The spectral response is defined in the wavelengths from approximately 350nm to 1000nm. 6 channels can be processed in parallel by independent ADCs while the other channels are accessible via a multiplexer. 8 optical channels cover the visible spectrum, one channel can be used to measure near infra-red light and one channel is a photo diode without filter (“clear”). The device also integrates a dedicated channel to detect 50Hz or 60Hz ambient light flicker. The flicker detection engine can also buffer data for calculating other flicker frequencies externally. The NIR channel in combination with the other VIS channel may provide information of surrounding ambient light conditions (light source detection).The device can also be synchronized to external signals via pin GPIO. AS7341 integrates filters into standard CMOS silicon via Nano-optic deposited interference filter technology and its package provides a built in aperture to control the light entering the sensor array. Control and Spectral data access is implemented through a serial I²C interface. The device is available in an ultra-low profile package with dimensions of 3.1mm x 2mm x 1mm. 1.1 Key Benefits & Features The benefits and features of AS7341, 11-Channel Spectral Sensor Frontend, are listed below: Figure 1: Added Value of Using AS7341 Benefits Features Color matching and skin tone measurement in mobile phones 8 optical channels distributed over the visible spectral range + clear and NIR channel to accurately measure and match colors in mobile phones Low power consumption and minimum I²C traffic ● 1.8VDD operation ● Configurable sleep mode ● Interrupt-driven device Integrated ambient light flicker detection on chip and light source detection through NIR channel ● ● ● ● Electronic shutter/external trigger functionality GPIO can be used as external trigger input External photodiodes to expand detection range GPIO can be used as input for external InGaAs PDs for MIR range. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Dedicated channel Independently configurable timing and gain Automatic gain adjustment 50Hz and 60Hz flicker detection flags 67 │ 3 Document Feedback 1.2 Applications ● ● ● 1.3 AS7341 General Description Reflective object color sensor in mobile phones Color management for displays Ambient light flicker detection for camera assist (flicker detection) Block Diagram The functional blocks of this device are shown below: Figure 2 : Functional Blocks of AS7341 1.8V VDD PGND GND GPIO AS7341 e.g.: Flash LED LDR 1.8V light source 8CH VIS NIR/CLE AR MCU SCL SDA INT Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 350-100 0nm sensor reflective surface light in 67 │ 4 Document Feedback 2 AS7341 Ordering Information Ordering Information Ordering Code Package Delivery Form Delivery Quantity AS7341-DLGT OLGA-8 Tape & Reel 13-inch 5000 pcs/reel AS7341-DLGM OLGA-8 Tape & Reel 7-inch 500 pcs/reel Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 5 Document Feedback 3 Pin Assignment 3.1 Pin Diagram AS7341 Pin Assignment Figure 3: Pin Assignment of AS7341 (TOP VIEW) VDD 1 SCL 2 AS7341 8 SDA 7 INT TOP VIEW 3.2 GND 3 6 GPIO LDR 4 5 PGND Pin Description Figure 4: Pin Description of AS7341 Pin Number Pin Name Pin Type(1) Description 1 VDD P Positive supply terminal 2 SCL DI Serial interface clock signal line for I2C interface 3 GND P Ground. All voltages referenced to GND 4 LDR A_I/O LED current sink input 5 PGND P Ground. All voltages referenced to GND 6 GPIO DI General purpose input/output 7 INT DO_OD Interrupt. Open drain output. Connect pull up resistor to 1.8V. 8 SDA D_I/O Serial interface data signal line for I2C interface (1) Explanation of abbreviations: DI Digital Input D_I/O Digital Input/Output DO_OD Digital Output, open drain P Power pin A_I/O Analog pin Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 6 Document Feedback 4 AS7341 Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings“ may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. All voltages with respect to GND/PGND. Device parameters are guaranteed at VDD=1.8V and TA=25°C unless otherwise noted. Figure 5 Absolute Maximum Ratings of AS7341 Symbol Parameter Min Max Unit Comments Electrical Parameters VDD / VGND Supply Voltage to Ground -0.3 2.2 V Applicable for pin VDD VANA_MAX Analog Pins -0.3 3.6 V Applicable for pin LDR VDIG_MAX Digital Pins -0.3 3.6 V Applicable for pins SCL,SDA and INT ISCR Input Current (latch-up immunity) mA JEDEC JESD78D Nov 2011 IO Output Terminal Current ± 100 -1 20 mA Electrostatic Discharge ESDHBM Electrostatic Discharge HBM ± 2000 V JS-001-2014 ESDCDM Electrostatic Discharge CDM ± 500 V JEDEC JESD22-C101F Temperature Ranges and Storage Conditions TA Operating Ambient Temperature -30 85 °C TSTRG Storage Temperature Range -40 85 °C TBODY Package Body Temperature 260 °C RHNC Relative Humidity (noncondensing) 85 % MSL Moisture Sensitivity Level (1) 5 3 IPC/JEDEC J-STD-020(1) Maximum floor life time of 168h The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices.” The lead finish for Pbfree leaded packages is “Matte Tin” (100% Sn) Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 7 Document Feedback 5 AS7341 Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with Min and Max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. All voltages with respect to GND/PGND. Device parameters are guaranteed at VDD=1.8V and TA=25°C unless otherwise noted. Figure 6: Electrical Characteristics of AS7341 Symbol Parameter VDD TA Conditions Min Typ Max Unit Supply Voltage 1.7 1.8 2.0 V Operating free-air temperature(1) -30 25 70 °C VDD=1.8V; TA=25°C Active mode(3) 210 300 µA VDD=1.8V; TA=25°C Idle mode(4) 35 60 µA VDD=1.8V; TA=25°C Sleep mode(5) 0.7 5 µA Power Consumption Supply Current(2) IDD Digital pins VIH SCL,SDA input high voltage VIL SCL,SDA input low voltage VOL INT, SDA output low voltage CI Input pin capacitance Ileak Leakage current into SCL,SDA,INT pins 1.26 6mA sink current -5 V 0.54 V 0.4 V 10 pF 5 µA 20 pF GPIO CLOAD (1) (2) (3) (4) (5) Maximum capacitive load GPIO While the device is operational across the temperature range, functionality will vary with temperature. Supply current values are shown at the VDD pin and do not include current through pin LDR. Active state occurs during active integration. (PON = “1” ; SP_EN = “1”) If wait is enabled (WEN = “1”), supply current is lower during the wait period Idle state occurs when PON = “1” and all functions are disabled Sleep state occurs when PON = “0” and I2C bus is idle. If I2C traffic is active device automatically enters idle mode. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 8 Document Feedback 6 AS7341 Optical Characteristics Optical Characteristics All limits are guaranteed. The parameters with Min and Max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. All voltages with respect to GND/PGND. Device parameters are guaranteed at VDD=1.8V and TA=25°C unless otherwise noted. Figure 7: Optical Characteristics of Channel F1, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Irradiance responsivity channel F1(2) Re_F1 λp Center wavelength(1) FWHM Full width half maximum(1) (1) (2) (3) Conditions Min Typ Max Unit LED: warm white 2700K (3) Ee = 107.67μW/cm2 55 counts LED: 420nm (3) Ee = 57 µW/cm² AGAIN = 512x tint = 100ms 3200 counts 405 415 425 26 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Figure 8: Optical Characteristics of Channel F2, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F2 Irradiance responsivity channel F2(2) LED: warm white 2700K(3) Ee = 107.67μW/cm2 λp Center wavelength(1) FWHM (1) (2) (3) Full width half maximum Min Max 110 435 (1) Typ 445 30 Unit counts 455 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 9 Document Feedback AS7341 Optical Characteristics Figure 9: Optical Characteristics of Channel F3, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F3 Irradiance responsivity channel F3(2) LED: warm white 2700K(3) Ee = 107.67μW/cm2 λp Center wavelength(1) FWHM (1) (2) (3) Full width half maximum Min Typ Max 210 470 (1) 480 Unit counts 490 36 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Figure 10: Optical Characteristics of Channel F4, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F4 Irradiance responsivity channel F4(2) LED: warm white 2700K(3) Ee = 107.67μW/cm2 λp Center wavelength(1) FWHM Full width half maximum(1) (1) (2) (3) Min Typ Max 390 505 515 Unit counts 525 39 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Figure 11: Optical Characteristics of Channel F5, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F5 Irradiance Responsivity channel F5(2) LED: warm white 2700K(3) Ee = 107.67μW/cm2 λp Center wavelength(1) FWHM (1) (2) (3) Full width half maximum Min Max 590 545 (1) Typ 555 39 Unit counts 565 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 10 Document Feedback AS7341 Optical Characteristics Figure 12: Optical Characteristics of Channel F6, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F6 Irradiance responsivity channel F6(2) LED: warm white 2700K(3) Ee = 107.67μW/cm2 λp Center wavelength(1) FWHM (1) (2) (3) Full width half maximum Min Typ Max 840 580 (1) 590 Unit counts 600 40 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Figure 13: Optical Characteristics of Channel F7, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F7 Irradiance responsivity channel F7(2) LED: warm white 2700K(3) Ee = 107.67μW/cm² λp Center wavelength(1) FWHM Full width half maximum(1) (1) (2) (3) Min Typ Max 1350 620 630 50 Unit counts 640 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 11 Document Feedback AS7341 Optical Characteristics Figure 14: Optical Characteristics of Channel F8, AGAIN: 64x, Integration Time: 27.8ms Symbol Parameter Conditions Re_F8 Irradiance responsivity channel F8(2) LED: warm white 2700K(3) Ee = 107.67μW/cm² λp Center wavelength(1) FWHM Full width half maximum(1) (1) (2) (3) Min Typ Max 1070 670 680 Unit counts 690 52 nm nm Parameter measured on a production ongoing sample bases on glass using diffused light The following diffuser is used in final test on top of AS7341: ED1-C50 Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 normalized LED spectra Figure 15: Typical LED Spectra Used in Final Test of AS7341 1 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0 LED 420nm LED 940nm warm white 2700K 350 450 550 650 750 850 950 1050 wavelength [nm] Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 12 Document Feedback AS7341 Optical Characteristics Figure 16: Optical Characteristics of AS7341, AGAIN: 64x, Integration Time: 27.8ms (unless otherwise noted) Symbol Parameter Conditions Re_CLEAR Irradiance responsivity channel CLEAR LED: warm white 2700K(5) Ee = 107.67μW/cm2 1750 counts Re_FLICKER Irradiance responsivity channel FLICKER LED: warm white 2700K(5) Ee = 52.32μW/cm2 6810 counts LED: warm white 2700K(5) Ee = 107.67μW/cm2 112 Irradiance responsivity channel NIR Re_NIR Min Typ LED: 940nm(5) Ee = 98 µW/cm² AGAIN = 128x tint = 100ms 5135 Max Unit counts Dark_1 (1)(6) Dark ADC 0-4 count value Ee = 0μW/cm2 AGAIN: 512x Integration time: 98ms 0 3 counts Dark_2 (6) Dark ADC 5 count value Ee = 0μW/cm2 AGAIN: 512x Integration time: 98ms 0 5 counts Gain(2) ratio Optical gain ratios, relative to 64x gain setting AGAIN: 0.5x 0.007 0.008 0.009 AGAIN: 1x 0.0145 0.016 0.0175 AGAIN: 2x 0.03 0.032 0.034 AGAIN: 4x 0.062 0.065 0.068 AGAIN: 8x 0.119 0.125 0.131 AGAIN: 16x 0.237 0.25 0.263 AGAIN: 32x 0.47 0.5 0.53 AGAIN: 64x ADC noise(3) 1 AGAIN: 128x 1.8 2 2.1 AGAIN: 256x 3.75 3.95 4.25 AGAIN: 512x 7.25 7.75 8.25 AGAIN: 16x Integration time: 10ms 0.005 % full scale tint Typical integration time(4) ASTEP = 599 ATIME = 29 50 ms tASTEP Integration time step size ASTEP = 999 2.78 ms Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 13 Document Feedback Symbol Parameter Conditions hca Half cone angle On the sensor (1) (2) (3) (4) (5) (6) AS7341 Optical Characteristics Min Typ Max 40 Unit deg The typical 3-sigma distribution is between 0 and 1 counts for AGAIN setting of 16x. The gain ratios are calculated relative to the response with integration time: 27.8ms and AGAIN: 64x. ADC noise is calculated as the standard deviation of 1000 data samples divided by full scale. Integration time, in milliseconds, is equal to: (ATIME + 1) x (ASTEP + 1) x 2.78µs Refer to Figure 15: Typical LED Spectra Used in Final Test of AS7341 Register 0xD6 / AZ_CONFIG is set to “1” – auto zero done before every integration cycle Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 14 Document Feedback 7 AS7341 Typical Operating Characteristics Typical Operating Characteristics Figure 17: Normalized Spectral Responsivity F1 F7 F2 F8 F3 Clear F4 NIR F5 Flicker F6 1 0,9 relative sensitivity 0,8 0,7 0,6 0,5 0,4 0,3 0,2 0,1 0 350 450 550 650 750 850 950 1050 wavelength [nm] Figure 18: Measured Spectral Responsivity Relative to F8(1) F1_256x F5_256x Clear_512x spectral responsivty relative to F8 1,2 F2_256x F6_256x NIR_64x F3_256x F7_256x F l i c k e r_64x F4_256x F8_256x 1 0,8 0,6 0,4 0,2 0 350 390 430 470 510 550 590 630 670 710 750 790 830 870 910 950 990 1030 wavelength [nm] (1) Fx_256x…AGAIN = 256x, diffuser mounted on top of package surface Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 15 Document Feedback 8 AS7341 Functional Description Functional Description Upon power-up (POR), the device initializes. During initialization (typically 200μs), the device will deterministically send NAK on I²C and cannot accept I²C transactions. All communication with the device must be delayed and all outputs from the device must be ignored including interrupts. After initialization, the device enters the SLEEP state. In this operational state, the internal oscillator and other circuitry are not active, resulting in ultra-low power consumption. If an I²C transaction occurs during this state, the I²C core wakes up temporarily to service the communication. Once the Power ON bit, “PON”, is enabled, the device enters the IDLE state in which the internal oscillator and attendant circuitry are active, but power consumption remains low. Whenever the spectral measurement is enabled (SP_EN = “1”) the device enters the ACTIVE state. If the spectral measurement is disabled (SP_EN = “0”) the device returns to the IDLE state. The figure below describes a simplified state diagram and the typical supply currents in each state. If Sleep after Interrupt is enabled (SAI = “1” in register 0xAC), the state machine will enter SLEEP when an interrupt occurs. Entering SLEEP does not automatically change any of the register settings (e.g. PON bit is still high, but the normal operational state is over-ridden by SLEEP state). SLEEP state is terminated when the SAI_ACTIVE bit is cleared (the status bit is in register 0xA7 and the clear status bit is in register 0xFA). Figure 19: Simplified State Diagram Power On VDD > VDD_POR SLEEP PON = „0" IDD = 0.7µA (typ) PON = „1" IDLE SPM = „0" IDD = 35µA (typ) SPM = „1" ACTIVE Spectral/Flicker IDD = 115µA (typ) Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 16 Document Feedback 8.1 AS7341 Functional Description Channel Architecture The device features 6 independent optical channels with a dedicated 16-bit light-to-frequency converter. Gain and integration time of the 6 channels can be adjusted with the serial interface. A wait time can be programed to automatically set a delay between two consecutive spectral measurements and to reduce overall power consumption. The other available channels can be accessed by a multiplexer (SMUX) connecting them to one of the internal ADCs. Figure 20: Simplified Block Diagram VDD GND LDR PGND LED GPIO 6 x 16bit LTF ADC SMUX CH0 ADC CH1 ADC CH2 ADC CH3 ADC CH4 ADC CH5 ADC CH0 Data CH1 Data CH2 Data CH3 Data CH4 Data CH5 Data SCL I2C Interface SDA INT interrupt handling CH0 data CH5 data register 8 x VIS F1-F8 4x4 PD array Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 OTP RCosc NIR/CLEAR/FLICKER 67 │ 17 Document Feedback 8.2 AS7341 Functional Description Sensor Array The device features a 4x4-photodiode array. On top and below the photodiode array there are two photodiodes with dedicated functions such as flicker detection (“FLICKER”) and near- infrared response (“NIR”). A clear channel (“C”) – photodiode without filter – is provided at the left and right bottom corner. Each of the filter pairs can be mapped to one of the six internal ADCs (CH0 – CH5). Figure 21: Sensor Array 520µm F1 F3 F5 F7 F6 F8 F2 F4 F4 F2 F8 F6 F7 F5 F3 F1 C 8.3 NIR 780µm 520µm F L IC K ER C GPIO/INT The GPIO can be either used as input for external photodiodes (e.g. InGaAs) or as synchronization input to start/stop the spectral measurement. (SYNS/SYND mode) The interrupt output pin INT can also be used to indicate the status (READY/BUSY) of the spectral measurement in mode SYNS and SYND. 8.4 SMUX The device integrates a multiplexer (SMUX). With the SMUX, it is possible to map all available photo diodes to one of the six available light-to-frequency converter (ADC0 to ADC5). After power up of the device the SMUX needs to be configured before a spectral measurement is started. ams provides reference codes and an application note on how to configure the SMUX. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 18 Document Feedback 8.5 AS7341 Functional Description Integration Mode The device features three modes to perform a spectral measurement. The integration mode (INT_MODE) can be configured in register 0x70 (CONFIG). For auto zero configuration refer to register 0xD6. Figure 22: Integration Mode Description Mode Description SPM (spectral measurement, no sync) Default setting: INT_MODE = 0x0 Synchronization Integration Time Registers SP_EN = “1” Integration is started with bit SP_EN = “1”. Integration Time is set by register ATIME and ASTEP. INT_MODE = 0x0 ATIME [7:0] No ATIME [7:0] ASTEP [15:0] ASTEP [15:0] WTIME [7:0] SYNS (spectral measurement, start sync) INT_MODE = 0x1 SYND (spectral measurement, start/stop sync) INT_MODE = 0x3 SP_EN = “1” Integration with external start: Integration is started with rising/falling edge on pin GPIO. INT_MODE = 0x1 ATIME [7:0] Yes (start) ATIME [7:0] ASTEP [15:0] Integration Time is set by register ATIME and ASTEP. ASTEP [15:0] WTIME [7:0] Integration with external start and stop: SP_EN = “1” Integration is controlled via rising/falling edge on pin GPIO and register EDGE. If the number of edges on pin GPIO is reached, integration time is stopped. Actual integration time can be read out in register “ITIME”. Yes (start/stop) Rising/falling edge on pin GPIO and register EDGE[7:0] INT_MODE = 0x3 EDGE[7:0] ITIME[23:0] Figure 23 : SPM Mode Start I2C write enable register auto re-start WTIME ATIME x ASTEP STATE IDLE AUTO ZERO INTEGRATION RESULT WAIT INTEGRATION RESULT INT I2C read data registers Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 I2C read data registers 67 │ 19 Document Feedback AS7341 Functional Description Figure 24 : SYNS Mode WTIME Start Start ATIME x ASTEP STATE IDLE AUTO ZERO RESULT INTEGRATION WAIT IDLE RESULT INTEGRATION SYNC (GPIO) READY_BUSYX (INT) I2C read data registers I2C read data registers Figure 25 : SYND Mode Start EDGE = 0x4 Start ITIME IDLE AUTO ZERO RESULT INTEGRATION IDLE STATE RESULT INTEGRATION SYNC (GPIO) 1st 2nd 3rd 4th 5th 1st 2nd 3rd 4th 5th READY_BUSYX (INT) I2C read data registers Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 I2C read data registers 67 │ 20 Document Feedback 9 AS7341 I²C Interface I²C Interface The device uses I²C serial communication protocol for communication. The device supports 7-bit chip addressing and both standard and full-speed clock frequency modes. Read and Write transactions comply with the standard set by Philips (now NXP). Internal to the device, an 8-bit buffer stores the register address location of the desired byte to read or write. This buffer auto-increments upon each byte transfer and is retained between transaction events (i.e. valid even after the master issues a STOP command and the I²C bus is released). During consecutive Read transactions, the future/repeated I²C Read transaction may omit the memory address byte normally following the chip address byte; the buffer retains the last register address +1. All 16-bit fields have a latching scheme for reading and writing. In general, it is recommended to use I²C bursts whenever possible, especially in this case when accessing two bytes of one logical entity. When reading these fields, the low byte must be read first, and it triggers a 16-bit latch that stores the 16-bit field. The high byte must be read immediately afterwards. When writing to these fields, the low byte must be written first, immediately followed by the high byte. Reading or writing to these registers without following these requirements will cause errors. 9.1 I²C Address Figure 26: AS7341 I2C Slave Address 9.2 Device I2C Address AS7341 0x39 I²C Write Transaction A Write transaction consists of a START, CHIP-ADDRESSWRITE, REGISTER-ADDRESS WRITE, DATA BYTE(S), and STOP (P). Following each byte (9TH clock pulse) the slave places an ACKNOWLEDGE/NOT- ACKNOWLEDGE (A/N) on the bus. If the slave transmits N, the master may issue a STOP. Figure 27: I2C Byte Write S DW A WA A reg_data A P WA++ Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 21 Document Feedback 9.3 AS7341 I²C Interface I²C Read Transaction A Read transaction consists of a START, CHIP-ADDRESSWRITE, REGISTER-ADDRESS, RESTART, CHIP-ADDRESSREAD, DATA BYTE(S), and STOP. Following all but the final byte the master places an ACK on the bus (9TH clock pulse). Termination of the Read transaction is indicated by a NACK being placed on the bus by the master, followed by STOP. Figure 28: I2C Read S DW A WA A Sr DR A data N P RA++ 9.4 Timing Characteristics Figure 29: I²C Timing Characteristics Symbol Parameter fSCL I²C clock frequency tBUF Bus free time between start and stop condition 1.3 µs tHS;STA Hold time after (repeated) start condition. After this period, the first clock is generated. 0.6 µs tSU;STA Repeated start condition setup time 0.6 µs tSU;STO Stop condition setup time 0.6 µs tLOW SCL clock low period 1.3 µs tHIGH SCL clock high period 0.6 µs tHD;DAT Data hold time 0 ns tSU;DAT Data setup time 100 ns tF Clock/data fall time 300 ns tR Clock/data rise time 300 ns Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Min Typ Max Unit 400 kHz 67 │ 22 Document Feedback 9.5 AS7341 I²C Interface Timing Diagrams Figure 30: I²C Slave Timing Diagram Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 23 Document Feedback 10 AS7341 Register Description Register Description The device is controlled and monitored by registers accessed through the I²C serial interface. These registers provide device control functions and can be read to determine device status and acquire device data. The register set is summarized below. The values of all registers and fields that are listed as reserved or are not listed must not be changed at any time. Two-byte fields are always latched with the low byte followed by the high byte. The “Name” column illustrates the purpose of each register by highlighting the function associated to each bit. The bits are shown from MSB (D7) to LSB (D0). GRAY fields are reserved and their values must not be changed at any time. In order to access registers from 0x60 to 0x74 bit REG_BANK in register CFG0 (0xA9) needs to be set to “1”. 10.1 Register Overview Figure 31: Register Overview Addr Name 0x60 ASTATUS 0x61 ASAT_ AGAIN_STATUS [3:0] STATUS CH0_DATA_L [7:0] CH0_DATA 0x62 CH0_DATA_H [7:0] 0x63 ITIME_L [7:0] 0x64 ITIME 0x65 ITIME_M [7:0] ITIME_H [7:0] 0x66 CH1_DATA_L [7:0] CH1_DATA 0x67 CH1_DATA_H [7:0] 0x68 CH2_DATA_L [7:0] CH2_DATA 0x69 CH2_DATA_H [7:0] 0x6A CH3_DATA_L [7:0] CH3_DATA 0x6B CH3_DATA_H [7:0] 0x6C CH4_DATA_L [7:0] CH4_DATA 0x6D CH4_DATA_H [7:0] 0x6E CH5_DATA_L [7:0] CH5_DATA 0x6F CH5_DATA_H [7:0] 0x70 CONFIG 0x71 STAT 0x72 EDGE Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 LED_SEL INT_SEL INT_MODE[1:0] WAIT_SYNC READY SYNC_EDGE [7:0] 67 │ 24 Document Feedback AS7341 Register Description Addr Name 0x73 GPIO 0x74 LED 0x80 ENABLE 0x81 ATIME ATIME [7:0] 0x83 WTIME WTIME [7:0] PD_GPIO LED_ACT PD_INT LED_DRIVE [6:0] FDEN SMUXEN 0x84 WEN SP_EN PON SP_TH_L_LSB [7:0] SP_TH_L 0x85 SP_TH_L_MSB [7:0] 0x86 SP_TH_H_LSB [7:0] SP_TH_H 0x87 SP_TH_H_MSB [7:0] 0x90 AUXID AUXID [7:0] 0x91 REVID REVID [7:0] 0x92 ID 0x93 STATUS 0x94 ASTATUS ID [7:0] ASAT AINT FINT CINT SINT ASAT_ AGAIN_STATUS [3:0] STATU S 0x95 CH0_DATA_L [7:0] CH0_DATA 0x96 CH0_DATA_H [7:0] 0x97 CH1_DATA_L [7:0] CH1_DATA 0x98 CH1_DATA_H [7:0] 0x99 CH2_DATA_L [7:0] CH2_DATA 0x9A CH2_DATA_H [7:0] 0x9B CH3_DATA_L [7:0] CH3_DATA 0x9C CH3_DATA_H [7:0] 0x9D CH4_DATA_L [7:0] CH4_DATA 0x9E CH4_DATA_H [7:0] 0x9F CH5_DATA_L [7:0] CH5_DATA 0xA0 CH5_DATA_H [7:0] 0xA3 STATUS 2 0xA4 STATUS 3 0xA6 STATUS 5 0xA7 STATUS 6 0xA9 CFG 0 0xAA CFG 1 0xAC CFG 3 0xAF CFG 6 0xB1 CFG 8 Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 AVALI D INT_SP_ H ASAT_ ASAT_ DIG ANA FDSAT _ANA FDSAT_ SAI_ INT_BUS Y DIG INT_SP_L SINT_FD FIFO_ OV OVTEMP FD_TRIG SP_TRIG LOW_ REG_ POWER BANK ACT WLONG AGAIN[4:0] SAI SMUX_ CMD[4:3] FIFO_TH [7:6] FD_AGC SP_AGC 67 │ 25 Document Feedback Addr Name 0xB2 CFG 9 0xB3 CFG 10 0xB5 CFG 12 0xBD PERS 0xBE GPIO 2 AS7341 Register Description SIEN SIEN _FD _SMUX AGC_H [7:6] AGC_L[7:6] FD_PERS [2:0] SP_TH_CH [2:0] APERS [3:0] 0xCA GPIO_ GPIO_ GPIO_ GPIO_ INV IN OUT IN ASTEP [7:0] ASTEP 0xCB ASTEP [15:8] 0xCF AGC_GAIN_M AX 0xD6 AZ_CONFIG 0xD8 FD_TIME 1 0xDA FD_TIME 2 0xD7 FD_CFG0 0xDB FD_STATUS 0xF9 INTENAB 0xFA CONTROL 0xFC FIFO_MAP 0xFD FIFO_LVL 0xFE AGC_FD_GAIN_MAX [7:4] AGC_AGAIN_MAX [3:0] AT_NTH_ITERATION [7:0] FD_TIME [7:0] FD_GAIN [7:3] FD_TIME [10:8] FD_ FIFO FD_ FD_ VALID SAT ASIEN FD_ FD_ 120HZ_ 100Hz_ VALID VALID SP_IEN FD_ FD_ 120Hz 100Hz FIEN CIEN SIEN AZ_SP_ FIFO_ CLEAR_ MAN CLR SAI_ACT FIFO_WRITE_CH5_DATA – FIFO_WRITE_CH0_DATA [6:1] ASTATU S FIFO_LVL [7:0] FDATA [7:0] FDATA 0xFF 10.2 FDATA [15:8] Detailed Register Description For easier readability, the detailed register description is done in groups of registers related to dedicated device functions. This is not necessarily related to its register address. Explanation of register access abbreviations: RW = read or write R = read only W = write only SC = self-clearing after access Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 26 Document Feedback 10.2.1 AS7341 Register Description Enable and Configuration Register The following registers are needed to power up and configure the device. To operate the device set bit PON = “1” first (register 0x80) after that configure the device and enable interrupts before setting SP_EN = “1”. Changing configuration while SP_EN = “1” may result in invalid results. Register CONFIG (0x70) is used to set the INT_MODE (SYNS,SYND). ENABLE Register (Address 0x80) Figure 32: ENABLE Register Addr: 0x80 ENABLE Bit Bit Name Default Access Bit Description 7 reserved 0 RW reserved 6 FDEN 0 RW Flicker Detection Enable. 0: Flicker Detection disabled 1: Flicker Detection enabled 5 reserved 0 RW reserved SMUX Enable. 4 SMUXEN 0 RW 1: Starts SMUX command Note: this bit gets cleared automatically as soon as SMUX operation is finished Wait Enable. 3 WEN 0 RW 0: Wait time between two consecutive spectral measurements disabled 1: Wait time between two consecutive spectral measurements enabled 2 reserved 0 RW reserved Spectral Measurement Enable. 1 SP_EN 0 RW 0: Spectral Measurement Disabled 1: Spectral Measurement Enabled Power ON. 0: AS7341 disabled 0 PON 0 RW 1: AS7341 enabled Note: When bit is set, internal oscillator is activated, allowing timers and ADC channels to operate. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 27 Document Feedback AS7341 Register Description CONFIG Register (Address 0x70) Figure 33: CONFIG Register Addr: 0x70 CONFIG Bit Bit Name Default Access Bit Description 7:4 reserved 0 RW reserved LED control. 3 LED_SEL 0 RW 0: External LED not controlled by AS7341 1: Register LED controls LED connected to pin LDR Note: register 0x74 2 INT_SEL 0 RW 1: Sync signal applied on output pin INT Ambient light sensing mode: 0: SPM mode (spectral measurement, normal mode) 1: SYNS mode 1:0 INT_MODE 0 RW 2: reserved 3: SYND mode Note: in SYND mode it is recommended to use register 0x60 to 0x6F to read out spectral data. GPIO Register (Address 0x73) Figure 34: GPIO Register Addr: 0x73 GPIO Bit Bit Name Default Access Bit Description 7:2 reserved 0 RW reserved 1 PD_GPIO 0 RW 1: Photo diode connected to pin GPIO 0 PD_INT 0 RW 1: Photo diode connected to pin INT Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 28 Document Feedback AS7341 Register Description GPIO 2 Register (Address 0xBE) Figure 35: GPIO2 Register Addr: 0xBE GPIO 2 Bit Bit Name Default 7:4 reserved 0 3 GPIO_INV 0 RW 2 GPIO_IN_EN 0 RW 1 GPIO_OUT 1 RW 0 GPIO_IN 0 R Indicates the status of the GPIO input if GPIO_IN_EN is set. Bit Description Access Bit Description reserved GPIO Invert. If set, the GPIO output is inverted. GPIO Input Enable. If set, the GPIO pin accepts a non-floating input. GPIO Output. If set, the output state of the GPIO is active directly. GPIO Input. LED Register (Address 0x74) Figure 36: LED Register Addr: 0x74 LED Bit Bit Name Default Access 7 LED_ACT 0 RW LED control. 0: External LED connected to pin LDR off 1: External LED connected to pin LDR on LED driving strength. 000 0000: 4mA 000 0001: 6mA 000 0010: 8mA 000 0011: 10mA 6:0 LED_DRIVE 000 0100 RW 000 0100: 12mA …… 111 1110: 256mA 111 1111: 258mA Note: Bit LED_SEL (register 0x70) needs to be set to “1” to control LED connected to pin LDR. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 29 Document Feedback AS7341 Register Description INTENAB Register (Address 0xF9) Figure 37: INTENAB Register Addr: 0xF9 INTENAB Bit Default Bit Name 7 ASIEN 6:4 reserved 0 Access RW Bit Description Spectral and Flicker Detect Saturation Interrupt Enable. When asserted permits saturation interrupts to be generated. reserved Spectral Interrupt Enable. 3 SP_IEN 0 RW When asserted permits interrupts to be generated, subject to the spectral thresholds and persistence filter. Bit is mirrored in the ENABLE register. FIFO Buffer Interrupt Enable. 2 F_IEN 0 1 reserved 0 RW When asserted permits interrupt to be generated when FIFO_LVL exceeds the FIFO threshold condition. reserved System Interrupt Enable. 0 SIEN RW When asserted permits system interrupts to be generated. Indicates that flicker detection status has changed or SMUX operation has finished. Access Bit Description CONTROL Register (Address 0xFA) Figure 38: CONTROL Register Addr: 0xFA CONTROL Bit Bit Name Default 7:3 reserved 0 reserved Spectral Engine Manual Autozero. 2 SP_MAN_AZ 0 RW 1 FIFO_CLR 0 RW 0 CLEAR_SAI_ACT 0 RW Starts a manual autozero of the spectral engines. Set SP_EN = 0 before starting a manual autozero for it to work. FIFO Buffer Clear. Clears all FIFO data, FINT, FIFO_OV, and FIFO_LVL. Clear Sleep-After-Interrupt Active. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Clears SAI_ACTIVE, ends sleep, and restarts device operation. 67 │ 30 Document Feedback 10.2.2 AS7341 Register Description ADC Timing Configuration / Integration Time The integration time in INT_MODE = “00” and “01” (SPM/SYNS) is set using the ATIME (0x81) and ASTEP (0xCA, 0xCB) registers. The integration time, in milliseconds, is equal to: Equation 1: Setting the integration time 𝑡𝑖𝑛𝑡 = (𝐴𝑇𝐼𝑀𝐸 + 1) × (𝐴𝑆𝑇𝐸𝑃 + 1) × 2.78µ𝑠 The reset value for ASTEP is 999 (2.78ms) and the recommended configuration for these two registers is ASTEP = 599 and ATIME = 29, which results in an integration time of 50ms. It is not allowed that both settings –ATIME and ASTEP – are set to “0”. The integration time also defines the full-scale ADC value, which is equal to: Equation 2: ADC full scale value 𝐴𝐷𝐶𝑓𝑢𝑙𝑙𝑠𝑐𝑎𝑙𝑒 = (𝐴𝑇𝐼𝑀𝐸 + 1) × (𝐴𝑆𝑇𝐸𝑃 + 1) ATIME Register (Address 0x81) Figure 39: ATIME Register Addr: 0x81 ATIME Bit Default Bit Name Access Bit Description Integration time. Sets the number of integration steps from 1 to 256. 7:0 ATIME Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0x00 RW Value Integration Time 0 ASTEP n ASTEP x (n+1) 255 256 x ASTEP 67 │ 31 Document Feedback AS7341 Register Description ASTEP Register (Address 0xCA, 0xCB) Figure 40: ASTEP Register Addr: 0xCA, 0xCB ASTEP Bit Default Bit Name Access Bit Description Integration time step size. Sets the integration time per step in increments of 2.78µs. The default value is 999. 7:0 ASTEP 0xCA 999 15:8 RW ASTEP 0xCB VALUE STEP SIZE 0 2.78µs n 2.78µs x (n+1) 599 1.67ms 999 2.78ms 17999 50ms 65534 182ms 65535 reserved, do not use WTIME Register (Address 0x83) If wait is enabled (WEN = “1” register 0x80), each new measurement is started based on WTIME. It is necessary for WTIME to be sufficiently long for spectral integration and any other functions to be completed within the period. The device will warn the user if the timing is configured incorrectly. If WTIME is too short, then SP_TRIG in register STATUS6 (ADDR: 0xA7) will be set to “1”. Figure 41: WTIME Register Addr: 0x83 WTIME Bit Default Bit Name Access Bit Description Spectral Measurement Wait time. 8-bit value to specify the delay between two consecutive spectral measurements. 7:0 WTIME Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0x00 RW Value Wait Cycles Wait Time 0x00 1 2.78ms 0x01 2 5.56ms n n 2.78ms x (n+1) 0xff 256 711ms 67 │ 32 Document Feedback AS7341 Register Description ITIME Register (Address 0x63, 0x64, 0x65) The register ITIME can be used to read-out the actual integration time in INT_MODE = “11” (SYND). In SYND mode the integration time is defined by the register “EDGE” and the device is running integration until the number of falling edges on pin GPIO is reached. Equation 3: Calculating the integration time in SYND mode 𝑡𝑖𝑛𝑡 = 𝐼𝑇𝐼𝑀𝐸 × 2.78µ𝑠 Figure 42: ITIME_L Register Addr: 0x63 ITIME_L Bit Bit Name Default Access Bit Description 7:0 ITIME_L 0 R Integration time in integration mode SYND Figure 43: ITIME_M Register Addr: 0x64 ITIME_M Bit Bit Name Default Access Bit Description 15:8 ITIME_M 0 R Integration time in integration mode SYND Figure 44: ITIME_H Register Addr: 0x65 ITIME_H Bit Bit Name Default Access Bit Description 23:16 ITIME_H 0 R Integration time in integration mode SYND Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 33 Document Feedback AS7341 Register Description EDGE Register (Address 0x72) Figure 45: EDGE Register Addr: 0x72 EDGE Bit Bit Name Default Access Bit Description 7:0 SYNC_EDGE 0 RW Number of falling SYNC-edges between start and stop of integration in mode SYND Number of edges = SYNC_EDGE + 1 FD_TIME Register (Address 0xD8, 0xDA) The register FD Time 1 and FD Time 2 can be used to configure the integration time and gain (ADC 5) of the flicker detection independently from the other ADCs. The FD_TIME register is an 11-bit register with the MSB in register 0xDA (bit 10:8) and the LSB in register 0xD8 (bit 7:0). The bit FDEN (register 0x80) must be set to “1” in order to use the FD_TIME registers. If the bit FDEN is not set, ADC5 runs automatically with the same gain and integration time as ADC0 to ADC4. Equation 4: Calculating the flicker detection integration time 𝑡𝑖𝑛𝑡_𝐹𝐷 = 𝐹𝐷_𝑇𝐼𝑀𝐸 × 2.78µ𝑠 Figure 46: FD Time Register Addr: 0xD8 FD_TIME_1 Bit Bit Name Default Access 7:0 FD_TIME [7:0] 0 RW Bit Description LSB of flicker detection integration time Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Note: must not be changed during FDEN = 1 and PON = 1. 67 │ 34 Document Feedback AS7341 Register Description Figure 47: FD Time Register Addr: 0xDA FD_TIME_2 Bit Default Bit Name Access Bit Description Flicker Detection gain setting (ADC5) 7:3 FD_GAIN 9 R/W VALUE GAIN 0 0.5x 1 1x 2 2x 3 4x 4 8x 5 16x 6 32x 7 64x 8 128x 9 256x 10 512x MSB of flicker detection integration time 2:0 FD_TIME [10:8] Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0 RW Note: must not be changed during FDEN = 1 and PON = 1. 67 │ 35 Document Feedback 10.2.3 AS7341 Register Description ADC Configuration (gain, AGC…) The following registers provide configuration for the 6 integrated ADCs (CH0 to CH5). It is possible to adjust the gain, configure and enable the automatic gain control (AGC) and setup the auto zero compensation for the engines. CFG1 Register (Address 0xAA) Figure 48: CFG1 Register Addr: 0xAA CFG1 Bit Bit Name Default 7:5 reserved 0 Access Bit Description reserved Spectral engines gain setting. Sets the spectral sensitivity. 4:0 AGAIN 9 RW VALUE GAIN 0 0.5x 1 1x 2 2x 3 4x 4 8x 5 16x 6 32x 7 64x 8 128x 9 256x 10 512x CFG10 Register (Address 0xB3) Figure 49: CFG10 Register Addr: 0xB3 CFG10 Bit Default Bit Name Access Bit Description AGC High Hysteresis. 7:6 AGC_H Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 3 RW Sets the data threshold at which AGAIN is reduced when spectral AGC mode is enabled. The threshold is automatically calculated internally as a percentage of full-scale. Note that full-scale is equal to (ATIME + 1) x (ASTEP + 1). 67 │ 36 Document Feedback Addr: 0xB3 CFG10 Bit Default Bit Name Access AS7341 Register Description Bit Description VALUE SIGNAL 0 50% 1 62.5% 2 75% 3 87.5% AGC Low Hysteresis. Sets the data threshold at which AGAIN is increased when spectral AGC mode is enabled. The threshold is automatically calculated internally as a percentage of full-scale. Note that full-scale is equal to (ATIME + 1) x (ASTEP + 1). 5:4 3 AGC_L reserved 3 RW 0 VALUE SIGNAL 0 12.5% 1 25% 2 37.5% 3 50% reserved Flicker Detect Persistence. 2:0 FD_PERS Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 2 RW Sets the number of consecutive flicker detect results that must be different before the flicker detect status will be changed. Flicker detection interrupts on SINT are affected by this setting. Flicker detect persistence is equal to 2(𝐹𝐷𝑃𝐸𝑅𝑆 −1) 67 │ 37 Document Feedback AS7341 Register Description AZ_CONFIG Register (Address 0xD6) The following register configures how often the spectral engine offsets are reset (auto zero) to compensate for changes of the device temperature. The typical time auto zero needs to be completed is 15ms. Figure 50: AZ_CONFIG Register Addr: 0xD6 AZ_CONFIG Bit Default Bit Name Access Bit Description AUTOZERO FREQUENCY. Sets the frequency at which the device performs auto zero of the spectral engines. Note: If FDEN = “1” auto zero is also done for ADC 5. The flicker detection measurement will be interrupted and restarted in this case. 7:0 AZ_NTH_ITERATION 255 RW VALUE AUTOZERO FREQUENCY 0 Never (not recommended) 1 Every integration cycle 2 Every 2 cycles … Every “AZ_NTH_ITERATION” cycle 254 Every 254 cycles 255 Only before first measurement cycle AGC_GAIN_MAX Register (Address 0xCF) Figure 51: AGC_GAIN_MAX Register Addr: 0xCF AGC_GAIN_MAX Bit Default Bit Name Access Bit Description Flicker Detection AGC Gain Max. 7:4 AGC_FD_GAIN_MAX 9 RW Sets the maximum gain for flicker detection to 2𝐴𝐺𝐶_𝐹𝐷_𝐺𝐼𝐴𝑁_𝑀𝐴𝑋 Default value is 9 (256x). The range can be set from 0 (0.5x) to 10 (512x). AGC Gain Max. 3:0 AGC_AGAIN_MAX 9 RW Sets the maximum gain for AGC engine to 2𝐴𝐺𝐶_𝐹𝐷_𝐺𝐼𝐴𝑁_𝑀𝐴𝑋 Default value is 9 (256x). The range can be set from 0 (0.5x) to 10 (512x). Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 38 Document Feedback AS7341 Register Description CFG8 Register (Address 0xB1) Figure 52: CFG8 Register Addr: 0xB1 CFG8 Bit Default Bit Name Access Bit Description FIFO Threshold. Sets a threshold on the FIFO level that triggers the first FIFO buffer interrupt (FINT). 7:6 FIFO_TH 2 5:4 reserved 0 3 FD_AGC 1 R/W VALUE FIFO_LVL 0 1 1 4 2 8 3 16 reserved Flicker Detect AGC Enable. RW If set, device uses automatic gain control for the flicker detect engine to maximize flicker signal and avoid saturation. Spectral AGC enable. 10.2.4 RW If asserted, device uses automatic gain control for the spectral engines to maximize signal while avoiding saturation. 2 SP_AGC 0 1 reserved 0 reserved 0 reserved 0 reserved Device Identification The following registers provided device identification. Device ID, revision ID and auxiliary ID are read only. AUXID Register (Address 0x90) Figure 53: AUXID Register Addr: 0x90 AUXID Bit Bit Name Default Access 7:4 reserved 3:0 AUXID 000 R Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Bit Description reserved Auxiliary identification 67 │ 39 Document Feedback AS7341 Register Description REVID Register (Address 0x91) Figure 54: REVID Register Addr: 0x91 REVID Bit Bit Name Default 7:3 reserved 2:0 REV_ID Access Bit Description reserved 000 R Revision number identification Bit Description ID Register (Address 0x92) Figure 55: ID Register 10.2.5 Addr: 0x92 ID Bit Bit Name Default Access 7:2 ID 001001 R 1:0 reserved Part number Identification Value 001001 reserved Spectral Interrupt Configuration The spectral interrupt threshold registers provide 16-bit values to be used as the high and low thresholds for comparison to the 16-bit CH0_DATA values (ADC CH0). If SP_IEN (register 0xF9) is enabled and CH0_DATA is not between the two thresholds for the number of consecutive measurements specified in APERS (register 0xBD) an interrupt is set. SP_TH_L_LSB Register (Address 0x84) Figure 56: SP_TH_L_LSB Register Addr: 0x84 SP_TH_L_LSB Bit Bit Name Default Access 7:0 SP_TH_L_LSB 0x00 RW Bit Description Spectral low threshold LSB Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 This register provides the low byte of the low interrupt threshold (CH0). 67 │ 40 Document Feedback AS7341 Register Description SP_TH_L_MSB Register (Address 0x85) Figure 57: SP_TH_L_MSB Register Addr: 0x85 SP_TH_L_MSB Bit Default Bit Name Access Bit Description Spectral low threshold MSB This register provides the high byte of the low interrupt threshold (CH0). 7:0 SP_TH_L_MSB 0x00 RW Both SP_TH_L registers are combined to a 16-bit threshold. If the value captured by channel 0 is below the low threshold and the APERS value is reached the bit SP_IEN is set and an interrupt is generated. There is an 8-bit data latch implemented that stores the written low byte until the high byte is written. Both bytes will be applied at the same time to avoid an invalid threshold. Note: The LSB register cannot be changed without writing to the MSB register. It is recommended to write to SP_TH_L_LSB and SP_TH_L_MSB within one I2C command. SP_TH_H_LSB Register (Address 0x86) Figure 58: SP_TH_H_LSB Register Addr: 0x86 SP_TH_H_LSB Bit Bit Name Default Access 7:0 SP_TH_H_LSB 0x00 RW Bit Description Spectral high threshold LSB This register provides the low byte of the high interrupt threshold (CH0). SP _TH_H_MSB Register (Address 0x87) Figure 59: SP _TH_H_MSB Register Addr: 0x87 SP _TH_H_MSB Bit Bit Name Default Access 7:0 SP_TH_H_MSB 0x00 RW Bit Description Spectral high threshold MSB Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 This register provides the high byte of the high interrupt threshold (CH0). 67 │ 41 Document Feedback Addr: 0x87 SP _TH_H_MSB Bit Default Bit Name Access AS7341 Register Description Bit Description Both SP_TH_H registers are combined to a 16-bit threshold. If the value captured by channel 0 is above the high threshold and the APERS value is reached the bit SP_IEN is set and an interrupt is generated. CFG12 Register (Address 0xB5) Figure 60: CFG12 Register Addr: 0xB5 CFG12 Bit Bit Name Default 7:3 reserved 0 Access Bit Description reserved Spectral Threshold Channel. Sets the channel used for interrupts, persistence and the AGC, if enabled, to determine device status and gain settings. 2:0 SP_TH_CH Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0 RW VALUE CHANNEL 0 CH0 1 CH1 2 CH2 3 CH3 4 CH4 67 │ 42 Document Feedback 10.2.6 AS7341 Register Description Device Status Register The following register provide status of the device and indicate details about saturation, interrupts, over temperature, device execution and ambient light flicker detection. STAT Register (Address 0x71) Figure 61: STAT Register Addr: 0x71 STAT Bit Bit Name Default Access Bit Description 7:2 reserved 0 RW reserved 1 WAIT_SYNC 0 R 1: Device waits for sync pulse on GPIO to start integration (SYNS / SYND INT_mode) 0 READY 0 R Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0: Spectral measurement status is busy 1: Spectral measurement status is ready 67 │ 43 Document Feedback AS7341 Register Description STATUS Register (Address 0x93) The primary status register for AS7341 indicates if there are saturation or interrupt events that need to be handled by the user. This register is self-clearing, meaning that writing a “1” to any bit in the register clears that status bit. In this way, the user should read the STATUS register, handle all indicated event(s) and then write the register value back to STATUS to clear the handled events. Writing “0” will not clear those bits if they have a value of “1”, which means that new events that occurred since the last read of the STATUS register will not be accidentally cleared. Figure 62: STATUS Register Addr: 0x93 STATUS Bit Default Bit Name Access Bit Description Spectral and Flicker Detect saturation. 7 ASAT 0 R, SC If ASIEN is set, indicates Spectral saturation. Check STATUS2 register to distinguish between analog or digital saturation. 6:4 reserved 0 R reserved Spectral Channel Interrupt. 3 AINT 0 R, SC If SP_IEN is set, indicates that a spectral event that met the programmed thresholds and persistence (APERS) occurred. FIFO Buffer Interrupt. If FIEN is set, indicates that the FIFO_LVL fulfills the threshold condition. If cleared by writing 1, the interrupt will be asserted again as more data is collected. To fully clear this interrupt, all data must be read from the FIFO buffer. 2 FINT 0 R, SC 1 C_INT 0 R, SC 0 SINT 0 R, SC If SIEN is set, indicates that system interrupt is set. Refer to Status5 register. Access Bit Description Calibration Interrupt. System Interrupt. STATUS 2 Register (Address 0xA3) Figure 63: STATUS 2 Register Addr: 0xA3 STATUS 2 Bit Bit Name Default 7 reserved 0 6 AVALID 0 5 reserved 0 reserved Spectral Valid. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 R Indicates that the spectral measurement has been completed reserved 67 │ 44 Document Feedback Addr: 0xA3 STATUS 2 Bit Default Bit Name Access AS7341 Register Description Bit Description Digital saturation. Indicates that the maximum counter value has been reached. Maximum counter value depends on integration time set in the ATIME register. 4 ASAT_DIGITAL 0 R 3 ASAT_ANALOG 0 R Indicates that the intensity of ambient light has exceeded the maximum integration level for the spectral analog circuit. 2 reserved 0 R reserved Analog saturation. Flicker detect analog saturation. Indicates that the intensity of ambient light has exceeded the maximum integration level for the analog circuit for flicker detection. 1 FDSAT_ANALOG 0 R 0 FDSAT_DIGITAL 0 R Indicates that the maximum counter value has been reached during flicker detection. Access Bit Description Flicker detect digital saturation. STATUS 3 Register (Address 0xA4) Figure 64: STATUS 3 Register Addr: 0xA4 STATUS 3 Bit Bit Name Default 7:6 reserved 0 5 INT_SP_H 0 R 4 INT_SP_L 0 R 3:0 reserved 0 reserved Spectral interrupt high. Indicates that a spectral interrupt occurred because the data exceeded the high threshold. Spectral interrupt low. Indicates that a spectral interrupt occurred because the data is below the low threshold. reserved STATUS 5 Register (Address 0xA6) Figure 65: STATUS 5 Register Addr: 0xA6 STATUS 5 Bit Bit Name Default 7:4 reserved 0 Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Access Bit Description reserved 67 │ 45 Document Feedback Addr: 0xA6 STATUS 5 Bit Bit Name Default Access 3 SINT_FD 0 R 2 SINT_SMUX 0 R 1:0 reserved 0 AS7341 Register Description Bit Description Flicker Detect interrupt. If SIEN_FD is set, indicates that the FD_STATUS register status has changed SMUX operation interrupt. Indicates that SMUX command execution has finished. reserved STATUS 6 Register (Address 0xA7) Figure 66: STATUS 6 Register Addr: 0xA7 STATUS 6 Bit Default Bit Name Access Bit Description FIFO Buffer Overflow. 7 FIFO_OV 0 R Indicates that the FIFO buffer overflowed and information has been lost. Bit is automatically cleared when the FIFO buffer is read 6 reserved 0 R reserved 5 OVTEMP 0 R 4 FD_TRIG 0 R 3 reserved 0 2 SP_TRIG 0 R 1 SAI_ACTIVE 0 R Over Temperature Detected. Indicates the device temperature is too high. Write 1 to clear this bit. Flicker Detect Trigger Error. Indicates that there is a timing error that prevents flicker detect from working correctly. reserved Spectral Trigger Error. Indicates that there is a timing error. The WTIME is too short for the selected ATIME. Sleep after Interrupt Active. Indicates that the device is in SLEEP due to an interrupt. To exit SLEEP mode, clear this bit. Initialization Busy. 0 INT_BUSY Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0 R Indicates that the device is initializing. This bit will remain 1 for about 300μs after power on. Do not interact with the device until initialization is complete. 67 │ 46 Document Feedback AS7341 Register Description FD_STATUS Register (Address 0xDB) Figure 67: FD STATUS Register Addr: 0xDB FD_STATUS Bit Bit Name Default 7:6 reserved 5 FD_MEASUREMENT_ VALID Access Bit Description reserved Flicker Detection Measurement Valid. 0 R Indicates that flicker detection measurement is complete. Write 1 to this bit to clear this field. Flicker Saturation Detected. 4 3 2 FD_SATURATION_ DETECTED FD_120HZ_FLICKER_ VALID FD_100HZ_FLICKER_ VALID 0 R 0 R 0 R Indicates that saturation occurred during the last flicker detection measurement, and the result may not be valid. Write 1 to this bit to clear this field. Flicker Detection 120Hz Flicker Valid. Indicates that the 120Hz flicker detection calculation is valid. Write 1 to this bit to clear this field. Flicker Detection 100Hz Flicker Valid. Indicates that the 100Hz flicker detection calculation is valid. Write 1 to this bit to clear this field. Flicker Detected at 120Hz. 1 FD_120HZ_FLICKER 0 R 0 FD_100HZ_FLICKER 0 R Indicates if an ambient light source is flickering at 120Hz. Flicker Detected at 100Hz. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Indicates if an ambient light source is flickering at 100Hz. 67 │ 47 Document Feedback 10.2.7 AS7341 Register Description Spectral Data and Status The ASTATUS register is mapped to register address 0x60 and 0x94. It provides saturation and gain status associated to each set of spectral data. Reading the ASTATUS register (0x60 or 0x94) latches all 12 spectral data bytes to that status read. Reading these bytes consecutively (0x60 to 0x6F or 0x94 to 0xA0) ensures that the data is concurrent. All spectral data are stored as 16-bit values. If flicker detection is enabled, spectral channel five (CH5 ADC) is used for the flicker detection function and CH5_DATA will read “0”. The ASTATUS and spectral data registers are read only. In SPM or SYNS mode, it is recommended to use the ASTATUS register 0x94 and spectral data register 0x94 to 0xA0. In SYND mode, it is possible to use register 0x60 to 0x6F for easier implementation. ASTATUS Register (Address 0x60 or 0x94) Figure 68: ASTATUS Register Addr: 0x60 and 0x94 ASTATUS Bit Bit Name Default Access 7 ASAT_STATUS 0 R, SC Indicates if the latched data is affected by analog or digital saturation. 6:4 reserved 0 R reserved Bit Description Saturation Status. Gain Status. 3:0 AGAIN_STATUS 0 R, SC Indicates the gain applied for the spectral data latched to this ASTATUS read. The gain from this status read is required to calculate spectral results if AGC is enabled. CH0_DATA Register (Address 0x95/0x96) Figure 69: CH0_DATA_L Register Addr: 0x95 CH0_DATA_L Bit Bit Name Default Access Bit Description 7:0 CH0_DATA_L 0 R CH0 ADC data – low byte Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 48 Document Feedback AS7341 Register Description Figure 70: CH0_DATA_H Register Addr: 0x96 CH0_DATA_H Bit Bit Name Default Access Bit Description 7:0 CH0_DATA_H 0 R CH0 ADC data – high byte CH1_DATA Register (Address 0x97/0x98) Figure 71: CH1_DATA_L Register Addr: 0x97 CH1_DATA_L Bit Bit Name Default Access Bit Description 7:0 CH1_DATA_L 0 R CH1 ADC data – low byte Figure 72: CH1_DATA_H Register Addr: 0x98 CH1_DATA_H Bit Bit Name Default Access Bit Description 7:0 CH1_DATA_H 0 R CH1 ADC data – high byte CH2_DATA Register (Address 0x99/0x9A) Figure 73: CH2_DATA_L Register Addr: 0x99 CH2_DATA_L Bit Bit Name Default Access Bit Description 7:0 CH2_DATA_L 0 R CH2 ADC data – low byte Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 49 Document Feedback AS7341 Register Description Figure 74: CH2_DATA_H Register Addr: 0x9A CH2_DATA_H Bit Bit Name Default Access Bit Description 7:0 CH2_DATA_H 0 R CH2 ADC data – high byte CH3_DATA Register (Address 0x9B/0x9C) Figure 75: CH3_DATA_L Register Addr: 0x9B CH3_DATA_L Bit Bit Name Default Access Bit Description 7:0 CH3_DATA_L 0 R CH3 ADC data – low byte Figure 76: CH3_DATA_H Register Addr: 0x9C CH3_DATA_H Bit Bit Name Default Access Bit Description 7:0 CH3_DATA_H 0 R CH3 ADC data – high byte CH4_DATA Register (Address 0x9D/0x9E) Figure 77: CH4_DATA_L Register Addr: 0x9D CH4_DATA_L Bit Bit Name Default Access Bit Description 7:0 CH4_DATA_L 0 R CH4 ADC data – low byte Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 50 Document Feedback AS7341 Register Description Figure 78: CH4_DATA_H Register Addr: 0x9E CH4_DATA_H Bit Bit Name Default Access Bit Description 7:0 CH4_DATA_H 0 R CH4 ADC data – high byte CH5_DATA Register (Address 0x9F/0xA0) Figure 79: CH5_DATA_L Register Addr: 0x9F CH5_DATA_L Bit Bit Name Default Access Bit Description 7:0 CH5_DATA_L 0 R CH5 ADC data – low byte Figure 80: CH5_DATA_H Register 10.2.8 Addr: 0xA0 CH5_DATA_H Bit Bit Name Default Access Bit Description 7:0 CH5_DATA_H 0 R CH5 ADC data – high byte Access Bit Description Miscellaneous Configuration CFG0 Register (Address 0xA9) Figure 81: CFG 0 Register Addr: 0xA9 CFG0 Bit Bit Name Default 7:6 reserved 0 5 LOW_POWER 0 reserved Low Power Idle. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 RW When asserted, the device will automatically run in a low power mode whenever all functions are in wait states or disabled. 67 │ 51 Document Feedback Addr: 0xA9 CFG0 Bit Default Bit Name Access AS7341 Register Description Bit Description Register Bank Access 0: Register access to register 0x80 and above 4 REG_BANK 0 RW 1: Register access to register 0x60 to 0x74 Note: Bit needs to be set to access registers 0x60 to 0x74. If registers 0x80 and above needs to be accessed bit needs to be set to “0”. 3 reserved 0 2 WLONG 0 1:0 reserved 0 reserved RW Trigger Long. Increases the WTIME setting by a factor of 16. reserved CFG3 Register (Address 0xAC) Figure 82: CFG 3 Register Addr: 0xAC CFG3 Bit Bit Name Default 7:5 reserved 0 Access Bit Description reserved Sleep after interrupt. 4 SAI 0 3:0 reserved 0xC Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 RW If set, the oscillator is turned off whenever an interrupt is active. SAI_ACTIVE is set in this event. To activate the oscillator again, clear all interrupts and clear the SAI_ACTIVE bit. reserved 67 │ 52 Document Feedback AS7341 Register Description CFG6 Register (Address 0xAF) Figure 83: CFG 6 Register Addr: 0xAF CFG6 Bit Default Bit Name Access Bit Description SMUX command. Selects the SMUX command to execute when setting SMUXEN gets set. Do not change during ongoing SMUX operation. 4:3 SMUX_CMD 2 RW VALUE SMUX_CMD 0 ROM code initialization of SMUX 1 Read SMUX configuration to RAM from SMUX chain 2 Write SMUX configuration from RAM to SMUX chain 3 Reserved, do not use CFG9 Register (Address 0xB2) Figure 84: CFG 9 Register Addr: 0xB2 CFG9 Bit Bit Name Default 7 reserved 0 6 SIEN_FD 0 5 reserved 4 SIEN_SMUX 3:0 reserved Access Bit Description reserved System Interrupt Flicker Detection. RW Enables system interrupt when flicker detection status change has occurred. reserved System Interrupt SMUX Operation. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0 RW Enables system interrupt when SMUX command has finished reserved 67 │ 53 Document Feedback AS7341 Register Description PERS Register (Address 0xBD) Figure 85: PERS Register Addr: 0xBD PERS Bit Bit Name Default 7:4 reserved 0 Access Bit Description reserved Spectral Interrupt Persistence. Defines a filter for the number of consecutive occurrences that spectral data must remain outside the threshold range between SP_TH_L and SP_TH_H before an interrupt is generated. The spectral data channel used for the persistence filter is set by SP_TH_CHANNEL. Any sample that is inside the threshold range resets the counter to 0. 3:0 APERS Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 0 RW VALUE CHANNEL 0 Every spectral cycle generates an interrupt 1 1 2 2 3 3 4 5 5 10 … 5 x (APERS – 3) 14 55 15 60 67 │ 54 Document Feedback 10.2.9 AS7341 Register Description FIFO Buffer Data and Status The FIFO buffer is used to poll spectral data with fewer I²C read and write transactions. The FIFO buffer is 256 bytes of RAM containing 128 two-byte datasets. If the FIFO overflows (i.e. 129 datasets before host reads data from the FIFO buffer), an overflow flag will be set and new data will be lost. The Host acquires data by reading addresses: 0xFE – 0xFF. The register address pointer automatically wraps from 0xFF to 0xFE as data are read. Data can be read one byte at a time or in blocks, (there is no block-read length limit). When reading single bytes, the internal FIFO read pointer and the FIFO Buffer Level, FIFO_LVL, are updated each time register 0xFF is read. For block-reads, the internal FIFO read pointer and the FIFO Buffer Level, FIFO_LVL update for each two-byte entry. If the FIFO continues to be accessed after FIFO_LVL = 0, the device will return 0 for all data. The FINT interrupt indicates when there is valid data in the FIFO buffer. The amount of unread data is indicated by the FIFO_LVL. FIFO_MAP Register (Address 0xFC) Figure 86: FIFO_MAP Register Addr: 0xFC FIFO_MAP Bit Bit Name Default 7 reserved 0 Access Bit Description reserved FIFO write CH5 Data. 6 FIFO_WRITE_CH5_DATA 0 RW If set, CH5 data is written to the FIFO Buffer. (two bytes per sample) Note: If flicker detection is enabled, this bit is ignored. Refer to register 0xD7 for FDEN=”1”. FIFO write CH4 Data. 5 FIFO_WRITE_CH4_DATA 0 RW 4 FIFO_WRITE_CH3_DATA 0 RW 3 FIFO_WRITE_CH2_DATA 0 RW 2 FIFO_WRITE_CH1_DATA 0 RW 1 FIFO_WRITE_CH0_DATA 0 RW If set, CH4 data is written to the FIFO Buffer. (two bytes per sample) FIFO write CH3 Data. If set, CH3 data is written to the FIFO Buffer. (two bytes per sample) FIFO write CH2 Data. If set, CH2 data is written to the FIFO Buffer. (two bytes per sample) FIFO write CH1 Data. If set, CH1 data is written to the FIFO Buffer. (two bytes per sample) FIFO write CH0 Data. If set, CH0 data is written to the FIFO Buffer. (two bytes per sample) FIFO write Status. 0 FIFO_WRITE_ASTATUS 0 RW If set, ASTATUS (one byte per sample) is written to the FIFO Buffer. In case SP_AGC_ENABLE = 1, ASTATUS should be written to FIFO buffer. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 55 Document Feedback AS7341 Register Description FIFO_CFG0 Register (Address 0xD7) Figure 87: FIFO_CFG0 Register Addr: 0xD7 FIFO_CFG0 Bit Default Bit Name Access Bit Description FIFO write Flicker Detection 7 FIFO_WRITE_FD 0 R/W If set flicker raw data is written into FIFO (two bytes per sample) Note: This bit is ignored if flicker detection is disabled. Refer to register 0xFC for FDEN=”0”. 6:0 reserved 0100001 Reserved, do not change FIFO_LVL Register (Address 0xFD) Figure 88: FIFO_LVL Register Addr: 0xFD FIFO_LVL Bit Default Bit Name Access Bit Description FIFO Buffer Level. 7:0 FIFO_LVL 0 R Indicates the number of entries (each are 2 bytes) available in the FIFO buffer waiting for readout. The FIFO RAM is 256byte, the FIFO_LVL range is from 0 entries to 128 entries. FDATA Register (Address 0xFE and 0xFF) Figure 89: FDATA Register Addr: 0xFE FDATA Bit Bit Name Default Access Bit Description 7:0 FDATA 0 R FIFO Buffer Data Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 56 Document Feedback AS7341 Register Description Figure 90: FDATA Register Addr: 0xFF FDATA Bit Bit Name Default Access Bit Description 15:8 FDATA 0 R FIFO Buffer Data Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 57 Document Feedback 11 AS7341 Application Information Application Information Figure 91 shows an example how AS7341 can be utilized to interface to an external InGaAs photodiode. GPIO2 is mapped to an internal ADC. 11.1 Schematic Figure 91: Application Example with External InGaAs Detector 2.7V–5.5V VCC 25-40V LX AS1340 EN FB GND Filter tuning PGND GND AS7341 GPIO InGaAS-Anode 1.8V light source 8CH VIS NIR/CLE AR SCL SDA MCU 350-100 0nm sensor INT LOW-MIR InGaAs sensor 1.55–1.85µm NIR C13272-02 CASE InGaAS-Cathode light in NTC1 UP-MIR VDD NTC2 1.8V LDR ligh t in reflective surface Temperature supervision Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 58 Document Feedback 11.2 AS7341 Application Information PCB Pad Layout Figure 92: Recommended PCB Pad Layout (1) (2) (3) All dimensions are in millimeters. Dimension tolerances are 0.05mm unless otherwise noted. This drawing is subject to change without notice. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 59 Document Feedback 11.3 AS7341 Application Information Application Optical Requirements For optimal performance, an achromatic diffuser shall be placed above the device aperture. The recommended solution is a bulk diffuser that meets the minimum recommended scattering characteristic shown below. For more details refer to the optical design guide or contact ams. Figure 93: Diffuser Characteristics Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 60 Document Feedback 12 AS7341 Package Drawings & Markings Package Drawings & Markings Figure 94: OLGA8 Package Outline Drawing RoHS (1) (2) (3) (4) Green All dimensions are in millimeters. Angles in degrees. Dimensioning and tolerance conform to ASME Y14.5M-1994. This package contains no lead (Pb). This drawing is subject to change without notice. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 61 Document Feedback 13 AS7341 Tape & Reel Information Tape & Reel Information Figure 95: AS7341 OLGA8 Tape Dimensions (1) (2) All dimensions are in millimeters. Angles in degrees. This drawing is subject to change without notice. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 62 Document Feedback AS7341 Tape & Reel Information Figure 96: AS7341 OLGA8 Reel Dimensions (1) (2) All dimensions are in millimeters. Angles in degrees. This drawing is subject to change without notice. Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 67 │ 63 Document Feedback 14 AS7341 Soldering & Storage Information Soldering & Storage Information Figure 97: Solder Reflow Profile Graph Figure 98: Solder Reflow Profile Parameter Reference Average temperature gradient in preheating Device 2.5 °C/s Soak time tsoak 2 to 3 minutes Time above 217 °C (T1) t1 Max 60 s Time above 230 °C (T2) t2 Max 50 s Time above Tpeak – 10 °C (T3) t3 Max 10 s Peak temperature in reflow Tpeak 260 °C Temperature gradient in cooling Datasheet • CONFIDENTIAL DS000504 • v2-00 • 2019-Apr-16 Max −5 °C/s 67 │ 64 Document Feedback 14.1 Storage Information 14.1.1 Moisture Sensitivity AS7341 Soldering & Storage Information Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is baked prior to being dry packed for shipping. Devices are dry packed in a sealed aluminized envelope called a moisture-barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. 14.1.2 Shelf Life The calculated shelf life of the device in an unopened moisture barrier bag is 12 months from the date code on the bag when stored under the following conditions: ● ● ● Shelf Life: 12 months Ambient Temperature:
AS7341-DLGM 价格&库存
很抱歉,暂时无法提供与“AS7341-DLGM”相匹配的价格&库存,您可以联系我们找货
AS7341-DLGM
  • 500+49.50394500+5.99216
  • 1000+46.203731000+5.59269
库存:1116
