AFBR-2CARxxZ
10G Ethernet SFP+ Active Optical Cable (AOC)
Product Brief
Description
Features
The Avago Technologies’ AFBR-2CARxxZ Active Optical
Cable (AOC) is part of a family of SFP+ products to serve
10Gb Ethernet (10GbE) applications. The letters “xx” of
the part number AFBR-2CARxxZ denote the cable length
in meters. The AFBR-2CARxxZ AOC enables 10GbE
equipment designs with very high port density based
on the electrical and mechanical specification enhancements to the well known SFP specifications developed
by the SFF Committee. The specifications are referred to
as “SFP+” to represent the enhancements over previous
SFP specifications. The SFP+ AOC have a cable length up
to 20m. These AOCs can be used as an alternative solution to SFP+ passive and active copper cables, while
providing improved signal integrity, longer distances,
superior electromagnetic immunity and better bit error
rate performance.
Specifications
• Proven High Reliability 850 nm technology: Avago
VCSEL transmitter and Avago PIN receiver
• Maximum power dissipation 350 mW per Active
Cable end
• Avago SFP+ package design enables equipment EMI
performance in high port density applications with
margin to Class B limits
AFBR-2CAR01Z
1 meter SFP+ Active Optical Cable
AFBR-2CAR02Z
2 meter SFP+ Active Optical Cable
AFBR-2CAR03Z
3 meter SFP+ Active Optical Cable
AFBR-2CAR05Z
5 meter SFP+ Active Optical Cable
• Electrical specifications per SFF-8431 Specifications
for Enhanced Small Form Factor Pluggable Module
SFP+
• 0 to 70 °C case temperature operating range
• Rx_LOS and Tx_DISABLE supported
• Mechanical specifications per SFF Committee SFF
8432 Improved Pluggable Formfactor “IPF”
• Compliant to Restriction on Hazardous Substances
(RoHS) per EU and China requirements
• Class 1 eye safe per requirement of EN 60825-1 2007,
EN 60825-2 A2 2010
• 1E-15 BER performance
AFBR-2CAR07Z
7 meter SFP+ Active Optical Cable
Applications
AFBR-2CAR10Z
10 meter SFP+ Active Optical Cable
AFBR-2CAR15Z
15 meter SFP+ Active Optical Cable
AFBR-2CAR20Z
20 meter SFP+ Active Optical Cable
AFCT-5016Z
SFP+ Evaluation Board
Part Numbers
Patent - www.avagotech.com/patents
1/10 Gigabit Ethernet (1/10GbE)
1/2/4/8G Fibre Channel (1/2/4/8GFC), Fibre Channel
InfiniBand (QDR/DDR/SDR)
Data Center Networking
- Converged Enhanced Ethernet Data Centers
- Data Center Bridging
• Networked storage systems
• High Performance Computing
• Proprietary Interconnects
15.2
Uncompressed
LABEL
COLOR TAG
Top - 1
2±0.1
51
Right - 1
Front - 1
2.55±0.1
65
8.6±0.1
1.4±0.1
30
Bottom - 1
Parameter
Value
R
A
N
I
IM
Key Parameters
A
T
A
D
Y
Units
Notes
Data rate per lane
From 1 to 10.3125
Gbps
Protocols
1 GbE, 10GbE
1/2/4/8/10 GFC
SDR/DDR QDR
3.3
0 - 70
850
1E-15
Two-Wire Serial
No retimer or CDR devices embedded in the module.
Allows operation at datarates below 10.3125 Gbps
Ethernet, Fibre Channel, InfiniBand, Other Protocols
and Proprietary Datarates as well
V
°C
nm
± 5%
L
E
R
P
Power Supply Voltage
Temperature Range
Wavelength
Bit Error Rate Performance
Management Interface
Laser Output Power
Power consumption per end
Mechanical Specification
Class 1
275
mW
Electrical Interface
pins
For product information and a complete list of distributors, please go to our website:
Memory Map access Page A0h only per SFF-8472
Revision 11.0
EN 60825-1 2007, EN 60825-2 A2 2010
Nominal Power
SFF-8432 Improved Pluggable Formfactor “IPF”
Can be installed in any INF-8074 or SFF-8431/2
compliant Small Form Pluggable (SFP) port
SFF Committee SFF 8431 Specifications for Enhanced 8.5
and 10 Gigabit Small Form Factor Pluggable Module “SFP+”
www.avagotech.com
Avago, Avago Technologies, and the A logo are trademarks of Avago Technologies in the United States and other countries.
Data subject to change. Copyright © 2005-2014 Avago Technologies. All rights reserved.
AV02-4473EN - March 21, 2014
很抱歉,暂时无法提供与“AFBR-2CAR07Z”相匹配的价格&库存,您可以联系我们找货
