Control/HMI
i3-C
iCube: All-in-One Control Solution
Intelligence raised by the power of three!
FREE
Config
uration
Softwa
re
MODBUS
PLRs
Features
i3-A
LCD
Monitors
PC Touch
Panels
OIT Touch
Panels
PLCs
i3-B
The Power of i3:
• 3 screen options
• 3 built-in I/O options
• 3 communication options
• 3 solutions in one (HMI, PLC and open bus connectivity)
• 3-year warranty
• Programmable function keys
• 2 communication ports RS232/RS485
• Embedded Ethernet with Webserver (i3C only)
• GSM modem for SMS/Data or Ethernet (options)
• Micro SD up to 2GB (option)
• Digital and analog I/O (up to 42 points)
• Expansion I/O (options)
• 4 high-speed counters (10Khz Max)
• PID control (up to 32 loops)
• Alarm / Recipe / Animation / Bitmaps
• Floating Point Math
• Real Time Clock
• 20+ Protocols (Modbus, AB DF1, Mitsubishi, GE Fanuc, etc.)
• 256KB RAM (Ladder), 1MB Graphical
• IP65 (NEMA4) CE, cUL, UL, Class 1 Div 2 (A & B versions)
• Free configuration software
• Input power: 10-30 VDC supply
• Class 1, Div 2
Advantages of an Integrated Solution
The iCube has capitalized on the progress made in microprocessor technology by condensing traditional control components
into a single, compact unit - reducing manufacturing costs, overall power consumption of control solutions and application
development time. Allows standardization to a single controller fitting most applications and greater flexibility for future
development.
The i3 controller offers the benefit of a full PLC - all the timers, math and complex functions as most standard PLC's - combined
with PID, temperature and process control, on-board I/O, and expandability. The color HMI is a fantastic interface offering 1,040
custom screens supporting a variety of bit maps, and animation. i3 controllers also have expandable options: Ethernet and
GSM/GPRS modem communications, optional built-in web server for the color touch screen controllers. Free configuration
manager included - straight-forward programming software used for programming logic and screens.
Model No.
Screen
Keys
MicroSD
Card
Solid State
Digital Outputs
Relay Digital
Outputs Inputs
Analog
Inputs
Universal
Analog Inputs
Analog
Outputs
2
2
2
2
2
2
Temperature
Controllers
KVM
IP Switch
Fanless PCs
i3 - "A" Version - Monochrome Graphical Screen and Keys - W/ MicroSD function (96.0W x 96.0H x 75.5D mm)
i3A12X/10A01-SOOF
2.25" Monotone 128x64
Y
12
1
i3A12X/20B05-SOHF
Y
16
6
24
2
i3A12X/13C14-SOHF
Y
12
12
i3 - "B" Version - Monochrome Graphical Touchscreen - W/ MicroSD function (96.0W x 96.0H x 75.5D mm)
i3B12Y/10D03-SCHF
3.5" Monotone 160x128
5
Y
12
4
i3B12Y/20B05-SCHF
5
Y
16
6
24
2
i3B12Y/13C14-SCHF
5
Y
12
12
i3 - "C" Version - 32 bit Color Graphical Touchscreen - W/ MicroSD function (186.1W x 143.6H x 77.0D mm)
i3C12Z/10D03-SCHF
5.7" 32k Color 320x240
6
Y
12
4
i3C12Z/20B05-SCHF
6
Y
16
6
24
2
i3C12Z/13C14-SCHF
6
Y
12
12
i3 - Serial Expansion Modules - DIN-Rail Mounted
You May Also Need…
Model No.
Description
Model No.
Description
IOS/M04ITX-D1
4 Channel TC input
i3-E
Ethernet Attachment
IOS/M08BDR-D1
8 Channel Digital I/O - 4 inputs + 4 Relay outputs
i3-MA
GSM/GPRS Modem Attachment
IOS/M12BDD-D2
12 Channel Digital I/O - 4 inputs + 8 Trn outputs
i3PC45
Programming Cable 9-pin female to RJ-45
IOS/M04IPX-D1
4 Channel RTD input
PC501
USB-Serial converter
IOS/M08ICX-D1
8 Channel DC current input
IOS/M12IDX-D1
12 Channel Digital Inputs
IOS/M04OXA-D1
4 channel Analog output 14bit, 0-10/4-20mA
www.bb-elec.com
815.433.5100
很抱歉,暂时无法提供与“IOS/M12IDX-D1”相匹配的价格&库存,您可以联系我们找货
