SD-15
15W Single Output DC-DC Converter
Ultra Compact Modbus Gateways
series
Models MESP211D, MESP211T
www.advantech-bb.com
PRODUCT FEATURES
SPECIFICATION
MODEL
SD-15A-05
DC VOLTAGE
RATED CURRENT
OUTPUT
5V
3A
SD-15B-05
SD-15C-05
Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485
Modbus Flexibility – Serial & Ethernet, Masters & Slaves
View Messaging Status in Real Time
Ultra Compact IP30 Metal Enclosure
SD-15A-24
SD-15B-24 SD-15C-24
SD-15A-12 SD-15B-12 SD-15C-12
International Power Supply (included
12V
24V
1.25A
0.625A
CURRENT RANGE
0 ~ 3A
0 ~ 1.25A
0 ~ 0.625A
RATED POWER
15W
15W
15W
RIPPLE & NOISE (max.) Note.2
100mVp-p
VOLTAGE ADJ.RANGE
4.75~5.5VDC
Models MESP211D and MESP211T, Vlinx™ series Modbus Gateways, connect
±2.0%
VOLTAGE TOLERANCE Note.3
Modbus devices to Ethernet networks and let you monitor and control Modbus
±0.5%
LINE REGULATION
120mVp-p
10.8~13.2VDC
ORDERING
INFORMATION
±1.0%
±0.3%
MODEL
NUMBER
devices from anywhere on the Ethernet LAN or WAN. Supporting up to 16
±0.5%
±0.3%
LOAD REGULATION
MESP211D
masters and 32 slaves, these gateways feature an auto-detecting 10/100
SETUP, RISE ,HOLD UP TIME
2.5s, 25ms,--- 12VDC/24VDC/48VDC atMESP211T
full load
Ethernet copper RJ-45 port and a serial port that supports RS-232/422/485
VOLTAGE RANGE
A: 9.2 ~18VDC
B:18 ~ 36VDC
C:36~72VDC
communications viaEFFICIENCY(Typ.)
a DB9 male or a terminal block connection.
PROTOCOL
RS-232/422/485
RS-232/422/485
150mVp-p
21.6~26.4VDC
±1.0%
SERIAL
ETHERNET
±0.2%
PORT
PORT
±0.2%
DB9 Male
1
Removable
1
Terminal Block
ETHERNET
CONNECTOR
RJ45
RJ45
79%
78%
70%
77%
76%
76%
75%
72%
1.9A/12VDC
0.9A/24VDC
0.45A/48VDC
The product is built for use in industrial environments
a heavy-duty
105with
~160%
rated outputmetal
power
ACCESSORIES
OVER
LOAD or DIN rail mountable (with optional adapters).
enclosure that is panel
(standard)
Protection type : Hiccup mode, recoversSMI6-12-V-P5
automatically -after
fault Power
condition
is removed
Included
Supply,
12 VDC 6 Watt, 5MM Plug, International AC Input,
PROTECTION
The product
can be supplied with a DC power source
ranging
from
10
to
30
International
AC
Blades
13.8~
16.2V
27.6 ~ 32.4V
5.75 ~ 6.75V
VDC and features aOVER
barrelVOLTAGE
connector. A power supply
is included.
Protection
type : Shut off o/p voltage, clamping
by
zener
diode
DRAD35 - Optional DIN rail adapter clip (pair)
68%
INPUT
DC CURRENT(Typ.)
WORKING TEMP.
-10 ~ +60℃ (Refer to "Derating Curve")232NM9 - Optional mull modem crossover cable
EMC EMISSION
Compliance to EN55032(CISPR32)
Ease of Use
WORKING HUMIDITY
20 ~ 90% RH non-condensing
Configuration,
upgrades
and monitoring
of the serial-20
server
are 10
simple,
~ +85℃,
~ 95%easy
RH
STORAGE
TEMP., HUMIDITY
ENVIRONMENT
tasks with Vlinx Manager
Software.
It
installs
on
your
PC
giving
access
±0.03%/℃ (0 ~ 50℃)to
TEMP. COEFFICIENT
the serial server via VIBRATION
your desktop. Remotely manage
Modbus
Gateway
10the
~ 500Hz,
2G 10min./1cycle,
60min.each along X, Y, Z axes
over a LAN or WAN WITHSTAND
via the build-in
web
server.
This
is
helpful
for
off-site
I/P-O/P:1.5KVAC I/P-FG:1KVAC O/P-FG:0.5KVAC
VOLTAGE
SAFETY &andISOLATION
troubleshooting
can be done
with an ordinary web
browser.
I/P-O/P,I/P-FG,O/P-FG:100M
Ohms / 500VDC / 25℃/ 70% RH
RESISTANCE
EMC
(Note 4)
Software Support EMC IMMUNITY
Compliance to EN61000-4-2,3,4,6,8, EN55024, light industry level, criteria A
Windows XP (32/64MTBF
bit), 2003 Server (32/64 bit), Vista
32/64
2008 Server 652.5K hrs min.(SD-15B)
644.2K
hrsbit),
min.(SD-15A)
653.5K Hrs min.(SD-15C)
(32/64 OTHERS
bit), WindowsDIMENSION
7 (32/64 bit), Windows 8 (32/6478*51*28mm
bit), Windows
10 (32/64
(L*W*H)
0.18Kg,60 PCS/11.8Kg
PACKING
bit).
NOTE
MIL-HDBK-217F (25℃)
File Name:SD-15-SPEC 2017-07-14
All product specifications are subject to change without notice.
MESP211D & MESP211T_3617ds
orders@advantech-bb.com
support@advantech-bb.com
Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104
European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
SD-15
Mechanical Specification
Case No. 931A
series
Unit:mm
7.62
1
2
4
2-M3 L=4
25.4
6 .6 2
51
3
5
+V ADJ.
LED
55
10.5
78
14max.
Pin No.
4
5
Assignment
DC INPUT V+
DC INPUT VFG
Assignment
DC OUTPUT +V
DC OUTPUT -V
2-M3 L=6
14
Pin No.
1
2
3
28
Terminal Pin No. Assignment
66.5
Block Diagram
2.75
fosc : 96KHz
POWER
SWITCHING
EMI
FILTER
I/P
PWM
CONTROL
OLP
RECTIFIERS
FILTER
+V
-V
DETECTION
CIRCUIT
Derating Curve
100
80
LOAD (%)
60
40
-10
40
50
45
60
55
(HORIZONTAL)
(VERTICAL)
AMBIENT TEMPERATURE (℃)
很抱歉,暂时无法提供与“BB-SD-15C-12”相匹配的价格&库存,您可以联系我们找货
