LPR & LPV Rigid Light Pipe New Product Announcement
This product features an innovative black adapter design that surrounds the LED and channels the light
directly to the lens, eliminating light bleed at the source. Light bleed from the LED can cause false readings
and muted or blended colors if other LEDs are present. Light bleed can also weaken the light intensity
making it less visible at its destination point.
This series is available in two configurations to accommodate most application requirements and they are
available in a range of sizes and lens styles.
LPV Series
This vertical rigid light pipe is an innovative
solution that provides zero light bleed at the LED.
• Zero light Bleed at the Source
• High Vibration Environments
• Easy Installation
• Lens Diameters: 2mm, 3mm, 4mm
• Lens Styles: Flat, Dome
• Height Ranges: 0.800” – 1.250”
• Industry Use: Datacom, Energy & Utility,
Audio/Video, Security, Healthcare
LPR Series
This right angle rigid light pipe is an innovative
•High Vibration Environments
• Easy Installation
• Lens Diameters: 3mm, 4mm, 5mm
• Length Ranges: 0.700” – 3.000”
For application assistance, product specs or to request a sample visit bivar.com or email us at sales@bivar.com.
4 Thomas | Irvine, CA 92618 | 800.767.3652
www.bivar.com
很抱歉,暂时无法提供与“LPR4-0800-0700FP”相匹配的价格&库存,您可以联系我们找货
