Botron B496201 Technical Data Sheet
Overview:
Botron’s B496201 Intelligent Air DC-Ionizer Benchtop
Ionizer is internet ready and monitored with a built-in LED
screen. The B496201 is a high frequency unit that provides
both reliability and performance. It’s lightweight and
compact design combined with an adjustable blowing
angle makes it a versatile bench top application. Comes
with Auto Ion Balance, Abnormal HV monitoring
system and Self Cleaning Emitter Points.
Product Notes and Features
• DC Technology
• Variable Speed Control
• Internet Ready
• Monitored Software
PERFORMANCE
• Self-Cleaning
Ion balance +/- 5v
Positive decay times range from (sec) 0.9 at 1’ to 2.8 at 3’
Negative decay times range from (sec) 1.1 at 1’ to 3.6 at 3’
*All results are based according to EOS/ESD-STM 3.1-2000.
*Results may vary based on test conditions.
PROPERTIES
SPECIFICATIONS
Power supply:
Current consumption:
Output HV:
Air volume:
Noise level:
Temperature:
Humidity:
Ozone:
Indicators:
Controls:
Mounting:
Emitter:
Dimensions:
Weight:
110V/220V 50/60Hz
12W
AC2200V - 68KHz
< 2.5 m³ /min
60dB at 3’
0 – 40 C
20 – 70% RH
< 0.03ppm
LCD Display
On/Off switch, Speed Control
Adjustable stand/bracket
Tungsten Alloy
9.8”H x 6”W x 3.3”D
4 lbs
1 of 2
APPLICATIONS
OPERATION
As with all of Botron’s ionization units, the B496201 is
designed neutralize electrostatic charge in personal
bench top environments, sensitive materials assembly,
packaging, clean room and laboratories. The unit can be
mounted but is not limited to the underside of shelving,
ceilings and walls.
Power on unit and adjust air flow for maximum
neutralization.
Aim unit at the area or items to be neutralized.
INSTALLATION
PART NUMBERS
1. Remove contents from package.
2. Mount the ionizer in desired position.
3. Make sure there are no obstructions between the target
area and ionizer.
4. Install power cord securely.
5. Turn switch on.
6. Adjust air flow accordingly.
B496201 Intelligent Benchtop Ionizer
B496202 Intelligent 2 Fan Overhead Ionizer
B496203 Intelligent 3 Fan Overhead Ionizer
MAINTENANCE
Botron’s Intelligent Ionizers are equipped with a self
cleaning mechanism that operates when starting up and
powering down. The display will indicate if further cleaning
is needed if the ion balance appears less stable.
Botron Company Inc. | 21601 N. 21st Ave. Phoenix AZ 85027 | Ph# 623-582-6700 | Fax# 623-582-6776
Disclaimer. All statements of technical information are believed to be true and are based upon tests we
believe to be reliable. The proper use and application for this product must be the responsibility of the user.
The statements herein shall have no force or effect.
2 of 2
很抱歉,暂时无法提供与“B496201”相匹配的价格&库存,您可以联系我们找货
