B7530
B7530
    BOTRON
    鞋跟带(遮护脚底部) 统一尺寸 1 MOhms 黄色
B7530 数据手册
Botron B7500 Technical Data Sheet Cup design: The cup of the Ergo One Heel Grounder is a symmetrical design that can be reversed when put on. It also features a dual layer rubber with a non-marking inside and a conductive rubber outside. As with all of our static control heel grounders the Ergo One Series has a 1.5” wide rubber, securing both at the back and underneath the heel. Its 7.5” length rubber provides enough cup volume to fit comfortably on those with larger shoe sizes. Product Notes and Features 1) 7” Stretch Hook and Loop for Comfort Fit 2) 1Meg, 2Meg or No Resistor Applications 1 Fastening System: This is standard hook and loop velcro system. Measuring .75 wide by 7” in length its ergonomic design is for both comfort and practicality. Grounding: Our ESD heel grounders come standard with a conductive 18” ribbon. All resistors are built in and are available in 1meg or 2meg applications, also available in no resistor. 3) 1.5” x 7.5” Cup w/ Non-Marking Interior 4) 18” Conductive Nylon Ribbon 3 2 PROPERTIES SPECIFICATIONS Cup Design: Sole Interior: Sole Exterior: Ribbon: Charge Decay: Thickness: Resistor: 1.5” x 7.5” Two Layer Rubber Non-Marking Rubber Conductive Rubber 5x103 18” Conductive Nylon
B7530 价格&库存
很抱歉,暂时无法提供与“B7530”相匹配的价格&库存,您可以联系我们找货
