BK211-0111
Bulk Dispenser - Single - Tall
Product Description:
Holds protective equipment or miscellaneous items in bulk
One compartment
Top loading and dispensing
Pivot hinge lid with flange to reduce dust
Keyholes for wall mounting
Clear PETG Plastic
Primary Area for Product Usage:
• Anywhere bulk items are needed
Dispenses:
• Fits any bulk items in a single compartment up to
12.00"W x 16.00"H x 5.38"D (30.5 cm x 40.6 cm x 13.7 cm)
Package Specifications:
• Package Quantity: 1 per case
• 24"L x 16"W x 6"H (61.0 cm x 40.6 cm x 15.2 cm)
• 7.0 lbs (3.2 kg) - approximated
Product Specifications (overall external dimensions):
• 12.63"W x 17.00"H x 5.75"D (32.1 cm x 43.2 cm x 14.6 cm)
• 3.2 lbs (1.5 kg) - approximated
Mounting Specifications:
2.03
12.07
8.00
R.13
(TYP)
.75
• BK212-0111: Bulk Dispenser - Double - Tall
• BK213-0111: Bulk Dispenser - Triple - Tall
• BK214-0111: Bulk Dispenser - Quad - Tall
2.10
Alternative Products (each sold separately):
R.25
(TYP)
BK212-0111
Product Videos:
BowmanDispensers.com/Product-Videos
BK213-0111
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
BK211-0111
Installation Instructions/Characteristics & Care
Installation
Always mount dispensers securely prior to loading with product.
• Flanged lid helps protect from dust and liquids.
Care and Construction
PETG Plastic
Material Characteristics
Designed for Long-Term Heavy-Duty
Applications
Copolyester resin is designed for
heavy-duty applications, and is used
by BOWMAN® Dispensers. We never
use acrylic in our products.
Copolyester (PETG) is typically 15-20
times tougher than general purpose
acrylic. PETG is made to withstand
handling and reduce losses due to
breakage.
PETG resists a variety of chemicals
and commonly used cleaning agents.
It is tough and durable (not brittle),
providing years of trouble-free
functionality and long life.
1
• Mount securely to a wall with screws approved and supplied by building
maintenance.
Clear optical characteristics mean
the viewer can see the content, read
text, and see true colors through
the material. It complies with FDA
regulations for food contact.
Care and Cleaning
Most cleaning chemicals do not
weaken the surface or cause damage
to the material. Suggested cleaning
method is to use a soft cloth, warm
water, and mild soap.
2
Parts included:
• Dispenser
Tools Required:
• No tools required to assemble dispenser
BK211-0111 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BK2110111TDSd
很抱歉,暂时无法提供与“BK211-0111”相匹配的价格&库存,您可以联系我们找货
