BK313-0300
Bulk Dispenser - Tall Triple Bin
Product Description:
• Bulk Dispenser - Tall Triple Bin
• Holds a variety of protective apparel or other miscellaneous
items in three compartments
• Top loading, front dispensing
• Hinged lid
• Keyholes for wall mounting
• Made of Stainless Steel
Primary Area for Product Usage:
• O.R. dressing areas, outside O.R. rooms, emergency rooms,
operating rooms, labor and delivery, and burn units
• Surgical areas, interventional radiology, areas with a scrub sink
• Clean rooms, food service areas, or anywhere bulk items are
needed
Dispenses:
• Fits miscellaneous bulk items in each compartment, up to
6.00″W x 15.80″H x 5.43″D (15.2 cm x 40.1 cm x 13.8 cm)
Package Specifications:
• Package Quantity: 1 per case
• 24″L x 8″W x 24″H (61.0 cm x 20.3 cm x 61.0 cm)
• 12.0 lbs (5.4 kg) - approximated
Product Specifications (overall external dimensions):
• 18.21″W x 17.04″H x 5.75″D (46.2 cm x 43.3 cm x 14.6 cm)
• 9.8 lbs (4.4 kg) - approximated
Mounting Specifications:
2.03
14.00
R.13 (2x)
R.25 (2x)
13.25
.67
• BK001-0300, Bulk Dispenser - Tall Single Bin
• BK312-0300, Bulk Dispenser - Tall Double Bin
• BK314-0300, Bulk Dispenser - Tall Quad Bin (not pictured)
.75
Alternative Products (each sold separately):
R.13 (2x)
BK001-0300
Product Videos:
BowmanDispensers.com/Product-Videos
BK312-0300
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
BK313-0300
Installation Instructions/Characteristics & Care
Installation
Always mount dispensers securely prior to loading with product.
• Product is loaded from the top, then can be dispensed through the top or bottom
front.
Care and Construction
Stainless Steel
Material Characteristics
Designed for Long-Term Heavy-Duty
Applications
Stainless steel is used overwhelmingly
for its corrosion and oxidation
resistance characteristics. Along with
being sturdy, stainless steel is also fire
and heat resistant.
The work-hardening properties of
stainless steel gives the material a
great strength-to-weight advantage
over other materials. It also provides
impact resistance and high toughness
in extreme temperatures.
1
Stainless steel has a bright, stain
resistant surface and pleasing
aesthetic appearance.
• Mount securely to a wall with screws approved and supplied by building
maintenance.
Care and Cleaning
Stainless steel resists a variety of
common chemicals and cleaning
agents. Clean using warm water, a
gentle detergent, and soft cloth.
Standard hospital cleaning supplies
are approved for use on our stainless
steel products. Dry thoroughly to avoid
spotting. Do not use steel wool.
2
Parts included:
• Dispenser
Tools Required:
• No tools required to assemble dispenser
BK313-0300 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BK3130300TDSb
很抱歉,暂时无法提供与“BK313-0300”相匹配的价格&库存,您可以联系我们找货
