FM090-0300
Face Mask Dispenser - Shield
Product Description:
Holds one box of shield masks
Keyholes for wall mounting
Stainless Steel
Primary Area for Product Usage:
• Anywhere protective equipment products are needed
Dispenses:
• Box(es) no larger than 9.00"W x 9.50"H x 4.00"D
(22.9 cm x 24.1 cm x 10.2 cm)
• Box(es) no smaller than 8.75"W x 5.50"H x 3.75"D
(22.2 cm x 14.0 cm x 9.5 cm)
Package Specifications:
• Package Quantity: 12 per case
• 16"W x 12"H x 12"D (40.6 cm x 30.5 cm x 30.5 cm)
• 16.0 lbs (7.3 kg) - approximated
Product Specifications (overall external dimensions):
• 9.06"W x 7.53"H x 4.06"D (23.0 cm x 19.1 cm x 10.3 cm)
• 1.2 lbs (0.5 kg) - approximated
Mounting Specifications:
• FB-090: Face Mask Dispenser - Shield (shown below)
• FM063-0300: Face Mask Dispenser - Tie
Product Videos:
BowmanDispensers.com/Product-Videos
7.06
.97
.50
2.00
Related Products (each sold separately):
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
FM090-0300
Installation Instructions/Characteristics & Care
Installation
Always mount dispensers securely prior to loading with product.
• Custom fit sizing with short flanges means there is maximum exposure of the box.
• Boxes may dispense from the top or front as fit provides.
Care and Construction
Stainless Steel
Material Characteristics
Designed for Long-Term, Heavy-Duty
Applications
Stainless steel is used overwhelmingly
for its corrosion and oxidation
resistance characteristics. Along with
being sturdy, stainless steel is also fire
and heat resistant.
The work-hardening properties of
stainless steel gives the material a
great strength-to-weight advantage
over other materials. It also provides
impact resistance and high toughness
in extreme temperatures.
1
Stainless steel has a bright, stain
resistant surface and pleasing
aesthetic appearance.
• Dispenser can be mounted onto a BOWMAN® door or wall hanger through the
cutout in the back.
Care and Cleaning
Stainless steel resists a variety of
common chemicals and cleaning
agents. Clean using warm water, a
gentle detergent, and soft cloth.
Standard hospital cleaning supplies
are approved for use on our stainless
steel products. Dry thoroughly to avoid
spotting. Do not use steel wool.
2
Parts included:
• Dispenser
Tools Required:
• No tools required to assemble dispenser
FM090-0300 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. FM0900300TDSa
很抱歉,暂时无法提供与“FM090-0300”相匹配的价格&库存,您可以联系我们找货
