GL003-0413
GL003-0413
    BOWMAN
    GLOVE BOX DISPENSER - TRIPLE - D
GL003-0413 数据手册
GL003-0413 Glove Box Dispenser - Triple with Dividers Product Description: • • • • Glove Box Dispenser - Triple with Dividers Holds three boxes of gloves Two-way keyholes for vertical or horizontal wall mounting White Powder-Coated Steel Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.24"W x 10.00"H x 3.75"D (13.3 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.25"W x 9.00"H x 3.00"D (10.8 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 4 per case • 18"L x 16"W x 10"H (45.7 cm x 40.6 cm x 25.4 cm) • 13.0 lbs (5.9 kg) - approximated Product Specifications (overall external dimensions): • 15.87"W x 10.03"H x 3.81"D (40.3 cm x 25.5 cm x 9.7 cm) • 2.3 lbs (1.0 kg) - approximated Mounting Specifications: 1.38 Related Products (each sold separately): .75 (TYP.) R.13 (TYP.) R.25 (4x) 7.00 .75 1.50 • GL002-0413: Glove Box Dispenser - Double with Dividers • GL004-0413: Glove Box Dispenser - Quad with Dividers (shown below) 13.12 Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL003-0413 Glove Box Dispenser - Triple with Dividers Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Dividers keep boxes separate for easy removal and stocking even when mounted horizontally. Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. Our powder-coated steel dispensers and stands provide long-lasting products that hold up well in tough environments. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning The powder-coated finish resists common chemicals and cleaning agents and can be easily wiped clean with soap and water. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GL003-0413 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL0030413TDSa
GL003-0413 价格&库存
很抱歉,暂时无法提供与“GL003-0413”相匹配的价格&库存,您可以联系我们找货
