GL010-0223
GL010-0223
    BOWMAN
    GLOVE BOX DISPENSER - SINGLE
GL010-0223 数据手册
GL010-0223 BOWMAN Signature Series - Glove Box Dispenser - Single ® Product Description: • • • • Glove Box Dispenser - Single Holds one box of gloves Three-way keyholes for vertical or horizontal wall mounting BOWMAN® Signature Series - Maple Fauxwood ABS Plastic Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.50"W x 10.00"H x 3.75"D (14.0 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.50"W x 9.00"H x 3.00"D (11.4 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 12 per case • 18"L x 16"W x 10"H (45.7 cm x 40.6 cm x 25.4 cm) • 11.0 lbs (5.0 kg) - approximated Product Specifications (overall external dimensions): • 5.75"W x 10.13"H x 4.00"D (14.6 cm x 25.7 cm x 10.2 cm) • 0.8 lbs (0.4 kg) - approximated Mounting Specifications: 3.75 Related Products (each sold separately): .50 (TYP.) R.25 (TYP.) 7.50 .50 (TYP.) • GL010-0233: BOWMAN® Signature Series - Glove Box Dispenser Cherry Fauxwood (shown below) R.13 (TYP.) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL010-0223 BOWMAN Signature Series - Glove Box Dispenser - Single ® Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Front cutout allows for a wide variety of box dispensing perforations. Care and Construction Fauxwood ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GL010-0223 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL0100223TDSa
GL010-0223 价格&库存
很抱歉,暂时无法提供与“GL010-0223”相匹配的价格&库存,您可以联系我们找货
