GL033-0613
GL033-0613
    BOWMAN
    GLOVE BOX DISPENSER - TRIPLE
GL033-0613 数据手册
GL033-0613* Glove Box Dispenser - Triple Product Description: • • • • • Glove Box Dispenser - Triple 2 each per pack Holds three boxes of gloves Slot holes for vertical or horizontal wall mounting White Coated-Wire Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.31"W x 10.00"H x 3.75"D (13.5 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.75"W x 8.25"H x 2.75"D (11.4 cm x 21.0 cm x 7.0 cm) Package Specifications: • Package Quantity: 6 per case • 14"L x 9"W x 18"H (35.6 cm x 22.9 cm x 14.7 cm) • 9.0 lbs (4.1 kg) - approximated Product Specifications (overall external dimensions): • 16.32"W x 8.16"H x 3.75"D (41.5 cm x 20.7 cm x 9.5 cm) • 1.3 lbs (0.6 kg) - approximated Mounting Specifications: * Imported 16.32 Related Products (each sold separately): 2.16 12.00 2.50 4.00 8.00 1.25 • GL011-0613 : Glove Box Dispenser - Single - Coated Wire • GL022-0613 : Glove Box Dispenser - Double - Coated Wire • GL044-0613 : Glove Box Dispenser - Quad - Coated Wire R. 25 (8x) GL011-0613 Product Videos: GL022-0613 BowmanDispensers.com/Product-Videos GL044-0613 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL033-0613* Glove Box Dispenser - Triple Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Unique design allows same dispenser to be mounted vertically or horizontally. Care and Construction Coated-Wire Material Characteristics Designed for Long-Term, Heavy-Duty Applications Dispensers made of wire provide a cost effective alternative and a simple solution for holding glove boxes. Our wire dispensers are made of heavy gauge wire to retain their shape and withstand normal use. Wire dispensers come in a variety of sizes to fit your needs. Each of our new wire glove box dispensers can be mounted either horizontally or vertically. Single, double, triple, and quad glove box dispensers with their alternative mounting options ensure you have gloves when and where you need them. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning The coated finish resists common chemicals and can be wiped clean with soap and water. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GL033-0613 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL0330613TDSa
GL033-0613 价格&库存
很抱歉,暂时无法提供与“GL033-0613”相匹配的价格&库存,您可以联系我们找货
