GL134-0412
Glove Box Dispenser - Single - Hanger
Product Description:
Holds one box of gloves
Bracket fits rails or edges up to .25” thick
Quartz Beige Powder-Coated Steel
Primary Area for Product Usage:
• Anywhere gloves are needed
Dispenses:
• Boxes no larger than 5.60”W x 10.00”H x 3.50”D
(14.2 cm x 25.4 cm x 8.9 cm)
• Boxes no smaller than 4.25”W x 8.00”H x 2.75”D
(10.8 cm x 20.3 cm x 7.0 cm)
Package Specifications:
• Package Quantity: 12 per case
• 20”L x 16”W x 12”H (50.8 cm x 40.6 cm x 30.5 cm)
• 19.0 lbs (8.6 kg) - approximated
Product Specifications (overall external dimensions):
• 5.66”W x 11.14”H x 4.08”D (14.4 cm x 28.3 cm x 10.4 cm)
• 1.4 lbs (0.6 kg) - approximated
Mounting Specifications:
In Use:
• Shown mounted to a cart rail (below)
.25 IML
1.56
.47
5.51
Product Videos:
BowmanDispensers.com/Product-Videos
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
GL134-0412
Glove Box Dispenser - Single - Cart Mount
Installation Instructions/Characteristics & Care
Installation
Always mount dispensers securely prior to loading with product.
• Attach bracket to dispenser, using the 4-40 x 1/4" Phillips screws with tooth lock
washers and 4-40 acorn nuts.
Care and Construction
Powder-Coated Steel
Material Characteristics
Designed for Long-Term, Heavy-Duty
Applications
Dispensers and stands made
of powder coated steel are both
attractive and functional, providing
years of service. Our powder coated
steel dispensers and stands provide
long-lasting products that hold up well
in tough environments.
Powder coated steel is ideal for
dispensers used in a healthcare or an
industrial setting. It is impact resistant
and is not effected by extremes in
temperature.
1
• Bracket can be used to attach to the rail or top edge of a cart.
Care and Cleaning
The powder coated finish resists
common chemicals and cleaning
agents and can be easily wiped clean
with soap and water.
2
Parts included:
• Dispenser
• Bracket
• (2x) Steel Flat Screws - 4-40 x 1/4”
• (2x) Steel Tooth Lock Washers - 4-40
• (2x) Steel Acorn Nuts - 4-40
Tools Required:
• Flat Screwdriver
• 1/4" Nut Driver or small wrench/pliers
GL134-0412 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2020 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL1340412TDSa
GL1340412TDSa
很抱歉,暂时无法提供与“GL134-0412”相匹配的价格&库存,您可以联系我们找货
