GL143-0212
Glove Box Dispenser - Quad
Product Description:
Holds four boxes of gloves
Keyholes for wall mounting
Quartz Beige ABS Plastic
Primary Area for Product Usage:
• Anywhere gloves are needed
Dispenses:
• Box(es) no larger than 10.00"W x 5.50"H x 3.75"D
(25.4 cm x 14.0 cm x 9.5 cm)
• Box(es) no smaller than 9.00"W x 4.50"H x 3.00"D
(22.9 cm x 11.4 cm x 7.6 cm)
Package Specifications:
• Package Quantity: 2 per case
• 20"L x 16"W x 12"H (50.8 cm x 40.6 cm x 30.5 cm)
• 6.0 lbs (2.7 kg) - approximated
Product Specifications (overall external dimensions):
• 20.10"W x 11.30"H x 3.95"D (51.1 cm x 28.7 cm x 10.0 cm)
• 2.1 lbs (0.9 kg) - approximated
Mounting Specifications:
Related Products (each sold separately):
18.05
2.05
1.15
• GL143-0111: Glove Box Dispenser - Quad (shown below)
10.80
.75
R.13 (2x)
R.25 (2x)
Ø.25
(2x)
Product Videos:
BowmanDispensers.com/Product-Videos
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
GL143-0212
Installation Instructions/Characteristics & Care
Installation
Always mount dispensers securely prior to loading with product.
• Open on both sides for left or right loading.
Care and Construction
ABS Plastic
Material Characteristics
Designed for Long-Term, Heavy-Duty
Applications
The combination of copolymers
(Acrylonitrile, Butadiene, and Styrene)
gives ABS an excellent combination of
strength, rigidity, and toughness.
ABS is chemical, stress-crack resistant,
dimensionally stable, and will hold
up to long-term use. It possesses
high strength and performance
characteristics at a reasonable cost.
1
• Mount securely to a wall with screws approved and supplied by building
maintenance.
• Ensure bottom is level prior to mounting with lower screws.
Care and Cleaning
Use mild soap and water to clean.
Petroleum-based oils, solvents, and
paints should not be used.
Standard hospital cleaning supplies are
approved for use on our ABS plastic
products.
2
Parts included:
• Dispenser
Tools Required:
• No tools required to assemble dispenser
GL143-0212 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL1430212TDSb
很抱歉,暂时无法提供与“GL143-0212”相匹配的价格&库存,您可以联系我们找货
