GS-073
GS-073
    BOWMAN
    GLOVE BOX DISPENSER - SINGLE - L
GS-073 数据手册
GS-073 Glove Box Dispenser - Single Product Description: • Glove Box Dispenser - Single - Large Capacity with Flexible Spring • Holds one large capacity box of gloves • Two-way keyholes for vertical or horizontal wall mounting • Stainless Steel Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 6.44"W x 10.00"H x 3.75"D (16.4 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 5.00"W x 9.00"H x 3.00"D (12.7 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 12 per case • 20"W x 16"H x 12"D (50.8 cm x 40.6 cm x 30.5 cm) • 24 lbs (10.9 kg) - approximated Product Specifications (overall external dimensions) : • 6.50"W x 9.96"H x 3.80"D (16.5 cm x 25.3 cm x 9.7 cm) • 1.5 lbs (0.7 kg) - approximated Mounting Specifications: Related Products (each sold separately): .75 1.38 3.25 7.86 .75 (2x) • GS-108: Glove Box Dispenser - Double - Space Saver (shown below) • GS-109: Glove Box Dispenser - Triple - Space Saver R.13 (TYP.) R.25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GS-073 Glove Box Dispenser - Single Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction Stainless Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications By its nature, stainless steel is resistant to corrosion and oxidation, yet the bright, easily maintained surface provides a modern and attractive appearance. Stainless steel is used overwhelmingly for its corrosion resistance characteristics. Along with being sturdy, stainless steel is also fire and heat resistant. Stainless steel has work-hardening properties, giving the material a great strength-to-weight advantage over other materials. It also provides impact resistance and high toughness in extreme temperatures. 1 • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. Care and Cleaning Stainless steel resists a variety of common chemicals and cleaning agents. Clean using warm water, a gentle detergent, and soft cloth. Dry thoroughly to avoid spotting. Do not use steel wool. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GS-073 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GS073TDSa
GS-073 价格&库存
很抱歉,暂时无法提供与“GS-073”相匹配的价格&库存,您可以联系我们找货
