PD100-0212
PD100-0212
    BOWMAN
    PROTECTIVE WEAR DISPENSER - UNIV
PD100-0212 数据手册
PD100-0212 Protection Dispenser - Universal Boxed Product Description: • Protection Dispenser - Universal Boxed • Dispenses Shoe Covers/Wipes/Caps/Other • Holds over 50 different boxes of bouffant and surgeons caps, along with shoe dispensers from all major manufacturers • Keyholes for wall mounting • Made of Quartz Beige ABS Plastic Primary Area for Product Usage: • Patient care areas: O.R. dressing rooms, surgery centers, labs, interventional radiology, ICU, clinics • Any location where PPE supplies are used for isolation and staff protection Dispenses: Most major manufacturers’ standard size boxed shoe covers and surgical caps: • Boxes no larger than 12.00”W x 10.00”H x 7.38”D (30.5 cm x 25.4 cm x 18.7 cm) • Boxes no smaller than 9.13”W x 10.00”H x 5.00”D (23.2 cm x 25.4 cm x 12.7 cm) Package Specifications: PATENT PENDING • Package Quantity: 4 per case • 20”L x 16”W x 12”H (50.8 cm x 40.6 cm x 30.5 cm) • 9.0 lbs (4.1 kg) - approximated Alternative Products (each sold separately): • PD200-0212, Protection Dispenser - Large - Universal Boxed • PD300-0212, Protection Dispenser - Universal Boxed Product Specifications (overall external dimensions): • 12.25”W x 10.13”H x 7.63”D (31.1 cm x 25.7 cm x 19.4 cm) • 1.80 lbs (0.8 kg) - approximated Mounting Specifications: PD200-0212 Product Videos: BowmanDispensers.com/Product-Videos PD300-0212 1.75 7.37 .75 R.13 (TYP) R.25 (TYP) (TYP) 8.00 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PD100-0212 Protection Dispenser - Universal Boxed Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Spring design provides secure fit for a wide assortment of boxed products. • Open configuration allows dispensing of product through top or front. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PD100-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PD1000212TDSc
PD100-0212 价格&库存
很抱歉,暂时无法提供与“PD100-0212”相匹配的价格&库存,您可以联系我们找货
