PD300-0212
PD300-0212
    BOWMAN
    PROTECTIVE WEAR DISPENSER - UNIV
PD300-0212 数据手册
PD300-0212 Protection Dispenser - Universal Boxed Product Description: • Protection Dispenser - Universal Boxed • Dispenses Shoe Covers/Caps/Other • Holds a variety of boxed bouffant caps, surgeons’ caps, and shoe covers from many major manufacturers • Three-way keyholes for wall mounting horizontally or vertically • Made of Quartz Beige ABS Plastic Mounted vertically Primary Area for Product Usage: • Patient care areas: OR dressing rooms, surgery centers, labs, interventional radiology, ICU, clinics Dispenses: Many sizes of boxed protection apparel: • Boxes no larger than 13.45”W x 12.00”H x 6.70”D (34.2 cm x 30.5 cm x 17.0 cm) • Boxes no smaller than 11.25”W x 4.00”H x 5.25”D (28.6 cm x 10.2 cm x 13.3 cm) Package Specifications: • Package Quantity: 4 per case • 18”L x 16”W x 10”H (45.7 cm x 40.6 cm x 25.4 cm) • 6.0 lbs (2.7 kg) - approximated Product Specifications (overall external dimensions): • 13.70”W x 5.73”H x 6.95”D (34.8 cm x 14.6 cm x 17.7 cm) • 1.0 lbs (0.5 kg) - approximated PATENT PENDING Mounting Specifications: Alternative Products (each sold separately): R.13 (TYP) 2.85 8.00 R. 25 (TYP) 3.00 1.00 .75 (TYP) • PD100-0212, Protection Dispenser - Universal Boxed • PD200-0212, Protection Dispenser - Universal Boxed PD100-0212 Product Videos: BowmanDispensers.com/Product-Videos PD200-0212 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PD300-0212 Protection Dispenser - Universal Boxed Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Spring design provides secure fit for a wide assortment of boxed products. • Open configuration allows dispensing of product through top or front. • Three-way keyhole design enables dispenser to be mounted either horizontally or vertically (to load from the right or left side) to accommodate confined spaces. • Note: boxes exceeding the height of the dispenser should only be mounted horizontally. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PD3000212 Installation/Characteristics& & Care PD300-0212 -- Installation/Characteristics Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PD3000212TDSc
PD300-0212 价格&库存
很抱歉,暂时无法提供与“PD300-0212”相匹配的价格&库存,您可以联系我们找货
