SN003-0212
SN003-0212
    BOWMAN
    SIGN HOLDER - KS101-0029 & KS102
SN003-0212 数据手册
SN003-0212 Sign Holder Product Description: • Sign Holder for KS101-0029 & KS102-0029 Floor Stands • Holds 5.50” x 8.50” sign with a 4.50” x 8.25” visible area • Mounts vertically with attached double sided tape to a KS101-0029 or KS102-0029 (sold separately) • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere a sanitizer stand is needed • All ports of entry Package Specifications: • Package Quantity: 12 per case • 14"L x 12"W x 8.5"H (35.6 cm x 30.5 cm x 21.6 cm) • 5.0 lbs (2.3 kg) - approximated Product Specifications (overall external dimensions): • 6.00"W x 10.00"H x 0.38"D (15.2 cm x 25.4 cm x 1.0 cm) • 0.5 lbs (0.2 kg) - approximated Mounting Specifications: 10.00 • KS101-0029 - Floor Stand With Backplate (shown below) • KS102-0029 - Floor Stand With Backplate and Drip Tray 8.250 Related Products (each sold separately): 5.63 6.00 Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com SN003-0212 Sign Holder Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Peel off VHB tape backing on the back of the sign holder. • Press to top of floor stand back plate on front. (The front is the side without the L.) Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Shown on KS201-0029 (sold separately) below, sign can be inserted through the top. • Free downloadable signs are available at www.BowmanDispensers.com. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser SN003-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. SN0030212TDSa
SN003-0212 价格&库存
很抱歉,暂时无法提供与“SN003-0212”相匹配的价格&库存,您可以联系我们找货
