SN304-0713
Sign - Hand Sanitizer Station
Product Description:
• Sign - Hand Sanitizer Station
• Helps prevent the spread of infection by providing visual
indication of hand sanitizer location
• Can be used separately or in combination with a BOWMAN
Semi-Recessed Hand Sanitizer Station, RE304-0012
• Screw holes for wall mounting
• Made of White Sintra® Plastic
Primary Area for Product Usage:
• Directly above BOWMAN’s Semi-Recessed Hand Sanitizer
Station, RE304-0012
• Any area designated to have a hand sanitizer station
Package Specifications:
• Package Quantity: 12 per case
• 12″L x 10″W x 9″H (30.5 cm x 25.4 cm x 22.9 cm)
• 3.0 lbs (1.4 kg) - approximated
Product Specifications (overall external dimensions):
• 6.30″W x 6.00″H x 3.71″D (16.0 cm x 15.2 cm x 9.4 cm)
• 0.1 lbs (0.05 kg) - approximated
Mounting Specifications:
Companion Product (sold separately):
5.80
Ø.15 (4x)
.50
.50
5.00
• RE304-0012, Semi-Recessed Hand Sanitizer Dispenser (shown in
use below)
Product Videos:
BowmanDispensers.com/Product-Videos
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
SN304-0713
Installation Instructions/Characteristics & Care
Installation
• Tent shape enables view of sign from multiple angles.
• Simple illustration is easy to recognize from a distance.
Sintra® Plastic
Material Characteristics
Designed for Long-Term Applications
Sintra® plastic is a lightweight, yet
rigid, board of moderately expanded
closed-cell polyvinyl chloride (PVC).
It is dent resistant and provides an
excellent combination of rigidity and
durability.
Sintra® has a high strength-to-weight
ratio and offers excellent corrosion,
dent, and scratch resistance. It’s
resistance to moisture makes it an
excellent choice for locations prone to
high humidity. Products constructed of
Sintra® should not be located in areas
subject to high temperatures (above
140° F).
1
• Install using screws/hardware approved and supplied by building maintenance.
The surface of Sintra® has a low gloss,
matte finish.
Care and Cleaning
Sintra® can be wiped clean with a mild
cleaner or soap and lukewarm water.
Isopropyl alcohol is recommended to
remove grease or oil. Ammonia and
acetone should not be used.
Standard hospital cleaning supplies
are approved for use on our Sintra®
products.
2
Parts included:
• Sign
Tools Required:
• No tools required to assemble dispenser
SN304-0713 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. SN3040713TDSa
很抱歉,暂时无法提供与“SN304-0713”相匹配的价格&库存,您可以联系我们找货
