Technical Data Sheet
BRADY B681 HIGH PERFORMANCE PRESSURE SENSITIVE PIPE MARKER
TDS No. B681
Effective Date: 11/15/2010
Description:
Brady B681 High Performance PSA Pipemarker is a surface printed polyester label with a polyester overlaminate.
Details:
Use:
Brady B681 is designed for use on stainless steel, B120 Fiberglass, and any other surfaces for pipemarkers. B681 is
designed for use in Pulp and Paper and Petrochemical environments where excellent chemical and abrasion resistance is
required. It can be used indoors and outdoors.
Special Properties:
Excellent chemical resistance. Can be applied down to 0°F (18°C).
Adhesive Type:
Acrylic pressure sensitive
Substrate Type:
Polyester film with a polyester overlaminate
Standard Material Colors:
Blue, green, red and yellow
Standard Legend Colors:
White and black
Thickness (PSTC33):
Total: 0.005 in. (0.13mm)
Adhesive Properties:
Adhesion to Steel (PSTC1)
15 Minute Dwell (Avg.) 70 oz/in. (76 N/100mm)
Ultimate Dwell (72 Hrs.) (Avg.) 108 oz/in. (118 N/100mm)
Tack (ASTM D 2979) (Avg.) 1170 g (11 N)
Drop Shear (PSTC7) (Avg.) 20 Hrs.
Abrasion Resistance (Method 5306 of U.S. Federal Test Method Std. No. 191A):
CS17 wheels, 1000 g wts.
Polyester laminate withstands up to 1000 cycles.
Gloss:
120 Gardner Units
Minimum Application Temperature:
0°F (18°C)
Service Temperature:
40°F to 230°F (40°C to 110°C)
Average Outdoor Durability:
58 years (Average expected outdoor life of product will depend on user definition of failure and climatic conditions.)
Chemical Resistance:
REAGENT
30% Sulfuric Acid
10% Sulfuric Acid
30% HCI
10% HCI
50% NaOH
10% NaOH
Methyl Ethyl Ketone
Acetone
1,1,1Trichloroethane
Methanol
IPA (Isopropanol)
ASTM #3 Oil
SAE 20 Oil
Alconox®
Toluene
Mineral Spirits
Glacial Acetic Acid
5% Acetic Acid
Diesel Fuel
Heptane
10% Ammonia
Kerosene
Water
20% Sodium Carbonate
2% Sodium Carbonate
10% NaCl
Bleach
7 DAY IMMERSION
NE
NE
NE
NE
F
F
F
F
F
F
F
NE
NE
NE
F
F
NE
NE
F
F
NE
F
NE
NE
NE
NE
NE
DIP TEST
NE
NE
NE
NE
NE
NE
F
F
F
NE
NE
NE
NE
NE
F
NE
NE
NE
NE
F
NE
NE
NE
NE
NE
NE
NE
RUB TEST
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE
NE = No Effect
NT = Not Tested
F = Failed (affected Sample)
7 Day Immersion: Immersed in reagent for 7 days.
Dip Test: Five 10 minute dips in reagent with 30 minute recovery.
Rub Test: Rubbed sample for 1 minute with swab soaked in reagent.
Product testing, customer feedback, and history of similar products, support a customer performance expectation of at least two
years from the date of receipt for this product as long as this product is stored in its original packaging in an environment
below 80°F (27°C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it
remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional
testing protocols that will qualify a product's fitness for use in their actual applications.
Trademarks:
Alconox® is a registered trademark of Alconox Co.
Signmark® is a registered trademark of Brady Worldwide, Inc.
ASTM: American Society for Testing and Materials (U.S.A.)
PSTC: Pressure Sensitive Tape Council (U.S.A.)
SAE: Society of Automotive Engineers (U.S.A.)
All S.I. Units (metric) are mathematically derived from the U.S. Conventional
Units.
Note: All values shown are averages and should not be used for specification purposes.
Test data and test results contained in this document are for general information only and shall not be relied upon by Brady
customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to
develop specifications or performance criteria for specific product applications should contact Brady for further information.
Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to
manufacture this product or based on results of testing using recognized analytical methods performed by a third party,
independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and
assumes no liability in connection with the use of this information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their
adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and
workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have
been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers.
This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of
merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no
circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection
with the use, or inability to use, Brady's products.
Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved
Material may not be reproduced or distributed in any form without written permission.
Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 4143586600 | Fax: 8002922289
很抱歉,暂时无法提供与“5765-HPHV”相匹配的价格&库存,您可以联系我们找货
