BXRH-40S1001-B-73
BXRH-40S1001-B-73
    BRIDGELUX
    LED 照明 COB、引擎、模块 板上芯片(COB) V6 HD Thrive™ Array 白色,天然 方形
BXRH-40S1001-B-73 数据手册
PR EL ® IM INA Bridgelux V6 HD Thrive™ Array Product Data Sheet DS406 RY | | | | | | 1 BXRH-27S 30S 35S 40S 50S 57S 65S V6 HD Thrive PR Introduction EL Bridgelux Thrive™ combines unique chip, phosphor and packaging technology to closely match the spectra of natural light over the visible wavelength range. Thrive can be used in constant color point luminaires to bring full spectrum natural light indoors or in tunable white luminaires to incorporate circadian elements that may impact human well-being. The high fidelity spectral output of Thrive creates stunning environments with excellent color rendering and outstanding TM30 metrics. Thrive is available in both SMD components and LED arrays to enable a broad range of lighting applications including retail, hospitality, office, education, architectural, museums, healthcare and residential lighting. Features IM Benefits INA • Engineered spectrum to closely match natural light • Full consistent spectrum with fewer spectral spikes • CRI >95, R1-R15 >90, high Rf and Rg values • Natural and vivid color rendering • High efficacy full spectrum solution • No violet chip augmentation • Hot color targeted • Form factor consistent with existing Bridgelux COB arrays • Broad product platform availability (SMDs and COBs) • Greater energy savings, lower utility costs • Economical, high efficiency solution • Uniform and consistent white light at application conditions • Ease of design and rapid go-to-market • Enables greater design flexibility and platform color consistency RY PR Contents EL Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Spectrum Characteristics 6 Electrical Characteristics Absolute Maximum Ratings Eye Safety Product Bin Definitions Performance Curves Typical Radiation Pattern Mechanical Dimensions Packaging and Labeling Design Resources Precautions Disclaimers About Bridgelux IM 9 10 11 12 INA 13 15 16 17 19 19 19 RY 20 1 Product Feature Map PR Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series HD arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series HD family of products. EL Designed to comply with global safety standards for creepage and clearance distances Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties IM White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point INA Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux COB arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRH – 30 S 1001 – B – 7 3 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen 7 RY Array Configuration Flux Indicator 1001 = 1000 lm Minimum CRI S = Thrive CCT Bin Options 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM 2 Product Selection Guide PR The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tc= 25°C) Part Number1,6 Nominal CCT1 (K) CRI2 EL Nominal Drive Current3 (mA) Typical Vf (V) Typical Pulsed Flux4,5,6,7 Tc = 25ºC (lm) Minimum Pulsed Flux6,7,8 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) BXRH-27S1001-B-7X 2700 98 350 36.4 1147 1009 12.7 90 BXRH-27S1001-G-7X 2700 98 700 18.2 1147 1009 12.7 90 96 BXRH-30S1001-B-7X 3000 98 350 36.4 1223 1076 12.7 BXRH-30S1001-G-7X 3000 98 700 18.2 1223 1076 12.7 96 BXRH-35S1001-B-7X 3500 98 350 36.4 1287 1132 12.7 101 98 700 18.2 1287 1132 12.7 101 98 350 36.4 1338 1177 12.7 105 98 700 18.2 1338 1177 12.7 105 98 350 36.4 1401 1233 12.7 110 98 700 18.2 1401 1233 12.7 110 98 350 36.4 1401 1233 12.7 110 98 700 18.2 1401 1233 12.7 110 98 350 36.4 1414 1244 12.7 111 98 700 18.2 1414 1244 12.7 111 BXRH-35S1001-G-7X 3500 BXRH-40S1001-B-7X 4000 BXRH-40S1001-G-7X 4000 BXRH-50S1001-B-7X 5000 BXRH-50S1001-G-7X 5000 BXRH-57S1001-B-7X 5700 BXRH-57S1001-G-7X 5700 BXRH-65S1001-B-7X 6500 BXRH-65S1001-G-7X 6500 IM INA Table 2: Selection Guide, Stabilized DC Test Performance (Tc= 85°C)4,5,6 Part Number1,6 Nominal CCT1 (K) BXRE-27S1001-B-7x 2700 BXRE-27S1001-C-7x 2700 Nominal Drive Current3 (mA) Typical Vf (V) Typical DC Flux4,5,6,7 Tc = 85ºC (lm) Minimum DC Flux6,7,8,9 Tc = 85ºC (lm) Typical Power (W) Typical Efficacy (lm/W) 98 350 35.4 1032 908 12.4 83 98 700 17.7 1032 908 12.4 83 35.4 1101 969 12.4 89 17.7 1101 969 12.4 89 35.4 1158 1019 12.4 93 CRI2 BXRE-30S1001-B-7x 3000 98 350 BXRE-30S1001-C-7x 3000 98 700 BXRE-35S1001-B-7x 3500 98 350 BXRE-35S1001-C-7x 3500 98 700 BXRE-40S1001-B-7x 4000 98 350 BXRE-40S1001-C-7x 4000 98 700 BXRE-50S1001-B-74 5000 98 350 BXRE-50S1001-C-74 5000 98 700 BXRE-57S1001-B-74 5700 98 350 BXRE-57S1001-C-74 5700 98 700 BXRE-65S1001-B-74 6500 98 350 BXRE-65S1001-C-74 6500 98 700 RY 17.7 1158 1019 12.4 93 35.4 1204 1059 12.4 97 17.7 1204 1059 12.4 97 35.4 1261 1110 12.4 102 17.7 1261 1110 12.4 102 35.4 1261 1110 12.4 102 17.7 1261 1110 12.4 102 35.4 1273 1120 12.4 103 17.7 1273 1120 12.4 103 Notes for Table 1 & 2: 1. Product CCT is hot targeted at Tj= 85°C. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical values. Minimum CRI for Thrive products is 95. Bridgelux maintains a ± 3 tolerance on CRI values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents PR V Series HD Thrive LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series HD Thrive LED Arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 10 & 11 and the flux vs. current characteristics shown in Figures 12 & 13. The performance at commonly used drive currents is EL summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRH-27S1001-B-7x BXRH-27S1001-G-7x BXRH-30S1001-B-7x BXRH-30S1001-G-7x BXRH-35S1001-B-7x BXRH-35S1001-G-7x BXRH-40S1001-B-7x BXRH-40S1001-G-7x CRI 98 98 98 98 98 98 98 98 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 103 175 34.2 6.0 618 556 250 35.2 8.8 854 769 97 350 36.4 12.7 1147 1032 90 85 IM 440 37.3 16.4 1395 1255 480 37.7 18.1 1499 1349 83 350 17.1 6.0 618 556 103 500 17.6 8.8 854 769 97 700 18.2 12.7 1147 1032 90 16.4 1255 85 880 18.7 960 18.9 18.1 1499 1395 1349 83 175 34.2 6.0 659 593 110 INA 250 35.2 8.8 911 820 104 350 36.4 12.7 1223 1101 96 440 37.3 16.4 1487 1338 91 480 37.7 18.1 1598 1438 88 350 17.1 6.0 659 593 110 500 17.6 8.8 911 820 103 700 18.2 12.7 1223 1101 96 880 18.7 16.4 1487 1338 90 960 18.9 18.1 1598 1438 88 175 34.2 6.0 694 624 116 250 35.2 8.8 958 350 36.4 12.7 1287 440 37.3 16.4 1565 480 37.7 18.1 1682 350 17.1 6.0 694 500 17.6 8.8 958 700 18.2 12.7 1287 880 18.7 16.4 1565 960 18.9 18.1 1682 175 34.2 6.0 721 250 35.2 8.8 996 350 36.4 12.7 1338 440 37.3 16.4 1627 480 37.7 18.1 1748 350 17.1 6.0 721 500 17.6 8.8 996 700 18.2 12.7 1338 880 18.7 16.4 1627 960 18.9 18.1 1748 RY 863 109 1158 101 1408 95 1513 93 624 116 863 109 1158 101 1408 95 1513 93 649 121 897 113 1204 105 1464 99 1573 97 649 120 897 113 1204 105 1464 99 1573 96 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents PR Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI EL Drive Current1 (mA) BXRH-50S1001-B-7x BXRH-50S1001-G-7x BXRH-57S1001-B-7x BXRH-57S1001-G-7x BXRH-65S1001-B-7x BXRH-65S1001-G-7x 98 98 98 98 98 98 Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 126 175 34.2 6.0 755 680 250 35.2 8.8 1043 939 119 350 36.4 12.7 1401 1261 110 104 440 37.3 16.4 1703 1533 480 37.7 18.1 1831 1648 101 350 17.1 6.0 755 680 126 IM 500 17.6 8.8 1043 939 118 700 18.2 12.7 1401 1261 110 104 880 18.7 16.4 1703 1533 960 18.9 18.1 1831 1648 101 175 34.2 6.0 755 680 126 250 35.2 8.8 1043 939 119 350 36.4 12.7 1401 1261 110 104 440 37.3 16.4 1703 1533 480 37.7 18.1 1831 1648 101 350 17.1 6.0 755 680 126 INA 500 17.6 8.8 1043 939 118 700 18.2 12.7 1401 1261 110 104 880 18.7 16.4 1703 1533 960 18.9 18.1 1831 1648 101 175 34.2 6.0 762 686 127 120 250 35.2 8.8 1053 948 350 36.4 12.7 1414 1273 111 440 37.3 16.4 1719 1547 105 480 37.7 18.1 1848 1663 102 350 17.1 6.0 762 686 127 500 17.6 8.8 1053 948 120 700 18.2 12.7 1414 880 960 18.7 18.9 16.4 18.1 1719 1848 RY 1273 111 1547 1663 105 102 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Spectrum Characteristics PR Table 4: Typical Color Rendering Index and TM-30 Values at, Tc=85°C Nominal CCT1 Rf Rg R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 2700K 95 103 97 99 94 94 97 98 97 98 99 97 91 98 98 95 98 3000K 3500K 4000K 5000K 5700K 6500K EL Note for Table 4: 95 104 98 99 93 94 97 98 96 96 97 96 92 95 98 95 97 95 98 98 98 97 98 98 98 98 97 93 97 97 95 98 97 98 97 100 99 99 97 99 99 99 99 98 94 97 99 96 99 98 98 97 100 98 99 98 98 98 98 99 98 95 98 98 98 98 98 97 94 98 98 98 97 95 98 97 96 95 92 97 96 96 98 98 97 95 98 98 98 97 96 98 98 96 96 93 97 96 97 98 98 97 IM 1. Bridgelux maintains a tolerance of ± 3 on Color Rendering Index R1-R15 measurements and TM-30 measurements. Figure 1: 2700K Thrive TM-30 Graphs Figure 2: 3000K Thrive TM-30 Graphs Figure 3: 3500K Thrive TM-30 Graphs INA RY 6 Spectrum Characteristics PR Figure 4: 4000K Thrive TM-30 Graphs EL IM Figure 5: 5000K Thrive TM-30 Graphs Figure 6: 5700K Thrive TM30 Graphs Figure 7: 6500K Thrive TM-30 Graphs INA RY 7 Spectrum Characteristics PR Figure 8: Typical Color Spectrum 100% 80% 60% 40% 20% 0% 380 EL Note for Figure 8: 430 480 530 100% 2700K 3000K 3500K 4000K Relative Radiant Power(%) Relative Radiant Power (%) 120% 5000K 5700K 6500K 80% 60% 40% 20% 0% 580 630 680 730 780 350 400 450 500 550 IM 600 650 700 750 800 Wavelength(nm) Wavelength (nm) 1. Color spectra measured at nominal current for Tc = 85°C. Spectral Matching to Natural Light The lighting market is in the early stages of adoption of human-centric lighting (HCL). HCL encompasses the effects of lighting on the physical and emotional health and well-being of people. Throughout evolution, the human visual system has evolved under the natural light of sun and fire. These light sources have standardized industry spectral power definitions that describe the state of natural light. However, conventional metrics such as CCT, CRI, and TM-30 fail to adequately quantify the naturalness, or closeness of these light sources to the standardized natural spectra. Due to a lack of an industry standard metric to quantitatively measure the naturalness of a light source, Bridgelux has pioneered a new metric that takes the guesswork out of comparing LED light sources to natural light. INA Average Spectral Difference, or ASD, is calculated by measuring the absolute difference between two spectra at discrete wavelengths. These values are averaged across a wavelength range derived from the photopic response curve, or V(λ); a luminous efficiency function describing the average spectral sensitivity of human perception of brightness. The range of 425nm to 690nm was selected to remove the tails of the V(λ) gaussian distribution below 1% of the peak value at 555nm, covering 99.9% of the area under the photopic response curve. Natural light is defined following the approach of IES TM-30; black body curves for light sources of ≤4000K and the CIE standard illuminant D for light sources of ≥ 5000K. Natural light has an ASD of 0%; lower ASD values indicate a closer match to natural light. Thrive is engineered to provide the closest match to natural light available using proprietary chip, phosphor and packaging technology, resulting in an ASD between 8% to 10% for all CCTs. By comparison, standard 80, 90, and 98 CRI light sources have ASD values that are 100% to 300% larger than Thrive. To learn more about the ASD metric, please review the Bridgelux whitepaper: Average Spectral Difference, a new method to make objective comparisons of naturalness between light sources; or contact your Bridgelux sales representative. RY 8 Electrical Characteristics PR Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) EL BXRH-xxx100x-B-73 BXRH-xxx100x-G-73 Notes for Table 5: Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.36 32.8 40.2 -16.2 0.39 33.9 41.5 19.6 -8.1 0.36 16.4 20.1 20.2 -8.1 0.39 16.9 20.8 Minimum Typical Maximum 350 34.1 36.4 39.1 -16.2 480 35.2 37.7 40.4 700 17.0 18.2 960 IM 17.6 18.7 Driver Selection Voltages7 (V) 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. INA 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 50V d.c. The maximum allowable voltage across the array must be determined in the end product application. RY 9 Absolute Maximum Ratings PR Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds EL IM Maximum Drive Current3 Maximum Peak Pulsed Drive Current4 Maximum Reverse Voltage5 Notes for Table 6: BXRH-xxx100x-B-7x BXRH-xxx100x-G-7x 480mA 960mA INA 680mA 1360mA -60V -35V 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced, and product warranty will be void. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. RY 10 Eye Safety PR Table 7: Eye Safety Risk Group (RG) Classifications Part Number EL BXRH-xxx100x-B-73 BXRH-xxx100x-G-73 CCT1,3 Drive Current3 (mA) 2700K/3000K 4000K2 350 RG1 RG2 480 RG1 RG2 700 RG1 RG2 960 RG1 RG2 IM Notes for Table 7: 1. Eye safety classification for the use of Bridgelux V Series HD LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1760 lx. 3. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. INA RY 11 Product Bin Definitions PR Table 8: 2-, 3- and 4-step MacAdam Ellipse Color Bin Definitions CCT 2700K 3000K 4000K 5000K 5700K 6500K Center Point Degree EL 2-step 3-step 4-step x y Φ(°) a b a b a b 0.4578 0.4101 53.700 0.00540 0.00280 0.0081 0.0042 N/A N/A 0.4338 0.403 53.217 0.00556 0.00272 0.0083 0.0041 N/A N/A 0.3818 0.3797 53.717 0.00626 0.00268 0.0094 0.0040 N/A N/A 0.3447 0.3553 59.617 N/A N/A 0.0082 0.0035 0.0110 0.0047 0.3287 0.3417 59.060 N/A N/A 0.0074 0.0032 0.0099 0.0042 0.3123 0.3282 58.567 N/A N/A 0.0066 0.0028 0.0090 0.0038 IM Notes for Table 8: 1. Color binning at Tc=85°C INA 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Figure 9: C.I.E. 1931 Chromaticity Diagram (Color targeted at Tc=85°C) 0.44 3 SDCM 2 SDCM 2700K 0.42 3000K 4 SDCM 0.38 3 SDCM 0.37 3500K 0.36 0.4 4000K 0.35 Y Y 0.39 0.38 6500K 0.34 0.33 0.36 0.32 0.34 0.36 0.31 0.39 0.42 0.45 X 0.48 0.3 0.3 0.31 0.32 RY 5000K 5700K 0.33 0.34 0.35 0.36 0.37 X 12 Performance Curves Forward Current (mA) 500 400 300 200 100 0 32 EL 1200 33 1000 Forward Current (mA) 600 IM 34 35 Forward Voltage (Vf) 36 37 Relative Luminous Flux 120% 100% 80% 60% 40% 20% 0% 0 100 200 300 Drive Current (mA) 400 500 600 600 400 200 0 16 38 Figure 12: Typical Relative Flux vs. Current V6B HD1,2 140% 800 16.5 17 17.5 Forward Voltage (Vf) 18 18.5 19 Figure 13: Typical Relative Flux vs. Current V6G HD1,2 INA 140% 120% Relative Luminous Flux PR Figure 11: Drive Current vs. Voltage V6G HD2 Figure 10: Drive Current vs. Voltage V6B HD2 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 RY 1200 Drive Current (mA) 13 Performance Curves PR Figure 15: Typical ccx Shift vs. Case Temperature Figure 14: Typical DC Flux vs. Case Temperature Relative Luminous Flux 100% 97% 94% 91% 88% 85% 82% 0 EL 25 50 0 Warm White 0 Cool White 0.0000 ccy shift -0.0020 -0.0040 -0.0060 -0.0080 40 60 60 80 100 120 -0.0010 25°C Pulsed -0.0015 -0.0020 -0.0025 -0.0030 -0.0035 IM 75 100 125 Case Temperature (°C) 20 40 -0.0005 Neutral White Figure 16: Typical ccy Shift vs. Case Temperature 0.0020 20 0.0000 ccx shift 103% 80 100 -0.0100 -0.0120 Case Temperature (Tc) Notes for Figures 14-16: 120 -0.0040 -0.0045 -0.0050 Case Temperature (Tc) INA RY 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for warm white based on 3000K Thrive 3. Characteristics shown for neutral white based on 4000K Thrive 4. Characteristics shown for cool white based on 5000K Thrive 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 14 Typical Radiation Pattern PR Figure 17: Typical Spatial Radiation Pattern EL Notes for Figure 17: 1. Typical viewing angle is 120⁰. IM INA 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 18: Typical Polar Radiation Pattern RY 15 Mechanical Dimensions PR Figure 19: V6 HD LED Array EL Notes for Figure 16: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. IM 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. INA 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. RY 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 16 Packaging and Labeling PR Figure 20: V6 HD Packaging EL IM Notes for Figure 20: 1. Each tube holds 35 V6 HD COB arrays. INA RY 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 15.4 (W) x 8.3 (H) x 430 (L) mm. Dimensions for the anti-static bag are 75 (W) x 615 (L) x 0.075 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 17 Packaging and Labeling PR Figure 21: Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for EL Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. IM Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30S1001B 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. INA RY 18 Design Resources PR Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series HD product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series HD LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. EL Precautions IM CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN INA Do not touch the V Series HD LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series HD LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). RY MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 19 About Bridgelux: Bridging Light and Life™ PR At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. EL For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/bridgelux-inc-_2 youtube.com/user/Bridgelux WeChat ID: BridgeluxInChina IM 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com INA RY © 2020 Bridgelux, Inc. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V6 HD Thrive Array Product Data Sheet DS406 Rev. A (06/2020) 20
BXRH-40S1001-B-73 价格&库存
很抱歉,暂时无法提供与“BXRH-40S1001-B-73”相匹配的价格&库存,您可以联系我们找货
