BXRV-TR-2750G-2000-A-15
    BRIDGELUX
    SIP4
    LED VESTA WHITE WARM 3850K 4SMD
BXRV-TR-2750G-2000-A-15 数据手册
Bridgelux Vesta™ Series Tunable White 13mm Array ® Product Data Sheet DS153 Vesta™ Series Introduction Vesta™ Series Tunable White Array products deliver adaptable light in a solid state lighting package. Vesta™ Series products tap into the powerful mediums of light and color to influence experience, well-being, and human emotion. They allow designers to mimic daylight to increase productivity and well-being, retailers to influence shopper behavior and fixture manufacturers to simulate the familiar glow and dimming of incandescent lamps. This high flux density light source is designed to support a wide range of high quality directional luminaires and replacement lamps for commercial and residential applications. Lighting system designs incorporating these LED arrays deliver comparable performance to 150 Watt incandescentbased luminaires, while increasing system level efficacy and prolonging service life. Typical luminaire and lamp types appropriate for this family include replacement lamps, down lights, wall packs and accent, spot and track lights. Features • Tuning range from 2700K-5000K • Efficacy of 103 lm/W typical • Uniform, high quality illumination • Minimum 90 CRI option • More energy efficient than incandescent, halogen and fluorescent lamps • Industry standardized dimensions • Flux packages from 1090 to 2275 lumens typical Benefits • Superior color mixing enabled by chip-scale package (CSP) • Compact system design resulting from high lumen density of CSPs • High quality, true color reproduction • Reliable operation facilitated by high conductivity substrates • Enhanced optical control • Uniform, consistent white light Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Electrical Characteristics 4 Absolute Maximum Ratings 5 Performance Curves 6 Typical Radiation Pattern 8 Typical Color Spectrum 9 Mechanical Dimensions 10 Color Binning Information 11 Packaging and Labeling 12 Design Resources 13 Precautions 13 Disclaimers 13 About Bridgelux 14 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the Vesta Series family of products. Fully engineered substrate for consistent thermal, mechanical and optical properties Polarity symbols Solder Pads (Cool White) Case Temperature (Tc) Measurement Point CSP Solder Pads (Warm White) Designed to comply with global safety standards for creepage and clearance distances Product Nomenclature The part number designation for Bridgelux VestaTM Series arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 - 12131415 – 16 - 17 18 BXRV TR – 2750 G - 2000 – A – 1 5 Product Family CCT Bin Options 5 = 5 SDCM Tunable White Array Nominal CCT 27 = 2,700K 50 = 5,000K Gen. 1 Array Configuration A = 25W Minimum CRI G = 90 CRI Form Factor Designator 2000 = 13mm LES 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Measurement Data Part Number BXRV-TR-2750G-2000-A-15 CRI Drive Current (mA) 2700 90 700 35.3 24.7 5000 90 700 36.3 25.4 2 Typical Vf Tc=25°C (V) Typical Power Tc=25°C (W) Nominal CCT1 (K) Typical Pulsed Flux3,4,5 Tc=25°C (lm) Minimum Pulsed Flux Tc=25°C8 (lm) 88 2180 1960 1960 103 2600 2340 2290 Typical Efficacy Tc=25°C (lm/W) Typical DC Flux Tc=85°C6,7 (lm) Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. Minimum R9 value for 90 CRI products is 50, Bridgelux maintains a ±3 tolerance on all R9 values. 3. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 4. Typical performance values are provided as a reference only and are not a guarantee of performance. 5. Bridgelux maintains a ±7% tolerance on flux measurements. 6. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Electrical Characteristics Table 2: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 7 Part Number CCT 2700 BXRV-TR-2750G-2000-A-15 5000 Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5 Rj-c (ºC/W) -23.5 Driver Selection Voltages6 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.42 31.3 40.2 -23.5 0.49 33.4 42.9 -25.9 0.42 31.3 40.2 0.49 33.4 42.9 Minimum Typical Maximum 700 33.2 35.3 37.4 1400 35.3 37.6 39.9 700 34.1 36.3 38.5 1400 36.6 38.9 41.2 -25.9 Notes for Table 2: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 6. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 7. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 45V d.c. The maximum allowable voltage across the array must be determined in the end product application. 4 Absolute Maximum Ratings Table 3: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds Maximum Drive Current3 1400mA Maximum Peak Pulsed Drive Current4 2000mA Maximum Reverse Voltage5 -60V Notes for Table 3: 1. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. See Bridgelux Application Note for more information. 3. Please refer to Figure 8 for drive current derating curve. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 5 Performance Curves Figure 1: Forward Voltage vs. Forward Current, Tc=25°C 1600 Figure 2: Relative Flux vs. Drive Current, Tc=25°C 2700K 5000K 1400 200% Relative Luminous Flux (%) 1200 Forward Current (mA) 2700K 180% 5000K 160% 1000 800 600 400 140% 120% 100% 80% 60% 40% 200 20% 0 30.0 32.0 34.0 36.0 Forward Voltage (V) 38.0 0% 40.0 0 600 800 1000 1200 1400 1600 Figure 4: Relative Voltage vs. Case Temperature 104% 102% 2700K 2700K 102% 101% 5000K 100% 25°C Pulsed 5000K 25°C Pulsed 100% 98% 99% 96% Relative Voltage (V) Relative Luminous Flux (%) 400 Drive Current (mA) Figure 3: Relative Flux vs. Case Temperature 94% 92% 90% 88% 98% 97% 96% 95% 86% 94% 84% 15 35 55 75 Case Temperature (°C) 95 93% 115 0 20 40 60 80 Case Temperature (°C) 100 120 Figure 6: Color shift vs. Forward Current Figure 5: CCT vs. Warm White Current Ratio 5200 0.42 5000K Cool White 700mA 0.41 4700 0.40 4200 0.39 CCY CCT (K) 200 3700 0.38 3200 0.37 2700 2700K 0.36 2200 0.0 0.2 0.4 0.6 0.8 1.0 1.2 Warm White 700mA 0.35 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 CCX Warm White Current Ratio 6 Performance Curves Figure 7: Relative Flux vs. Warm White Current Ratio Figure 8: Derating Curve 1600 105% 5000K 1400 95% 1200 90% 1000 Current (mA) Relative Flux 100% 85% 2700K 80% 75% 70% 1050 mA 800 600 400 200 65% 0 60% 0.0 0.2 0.4 0.6 0.8 Warm White Current Ratio 1.0 1.2 25 45 65 85 105 125 Case Temperature (˚C) 7 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 Angular Displacement (⁰) 30 40 50 60 70 80 90 Notes for Figure 9: 1. Typical viewing angle is 130⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 10: Typical Polar Radiation Pattern -30⁰ -15⁰ 15⁰ 30⁰ 100% 90% -45⁰ 80% 45⁰ 70% 60% -60⁰ 50% 60⁰ 40% 30% -75⁰ 20% 75⁰ 10% -90⁰ 0% 90⁰ 8 Typical Color Spectrum Figure 11: Typical Color Spectrum 120% 5000K 2700K Relative Spectral Power Distribution (%) 100% 80% 60% 40% 20% 0% 380 430 480 530 580 Wavelength (nm) 630 680 730 780 Note for Figure 11: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 9 Mechanical Dimensions Figure 12: Drawing for Vesta Series Tunable White 13mm Array Notes for Figure 12: 1. Solder pads are labeled “+” to denote positive polarity and “-” to denote negative polarity. 2. Drawings are not to scale. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, tolerances are ± 0.10mm. 5. The optical center of the LED array is nominally defined by the mechanical center of the array. 6. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes for product handling, mounting and heat sink recommendations. 10 Color Binning Information Figure 13: Graph of Test Bins in xy Color Space 0.4600 0.4400 0.4200 0.4000 y 2700K 0.3800 0.3600 0.3400 5000K 0.3200 Black Body Curve 0.3000 0.3000 5 SDCM 0.3400 0.3800 0.4200 0.4600 0.5000 x Note: Pulsed Test Conditions, Tc = 25°C Table 4: Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc=85°C) Bin Code 2700K 5000K 5 (5SDCM) (2670K - 2850K) (4815K - 5270K) Center Point (x,y) (0.4578, 0.4101) (0.3447, 0.3553) 11 Packaging and Labeling Figure 14: VestaTM Series Tunable White 13mm Packaging and Labeling Tube label Bag label Box label Notes for Figure 14: 1. Each tube holds 25 VestaTM Series Tunable White 13mm arrays. 2. Two tubes are sealed in an anti-static bag. Ten such bags are placed in a box and shipped. Depending on quantities ordered, a bigger shipping box, containing four boxes will be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 15.4 (W) x 8.3(H) x 500 (L) mm. Dimensions for the anti-static bag are75 (W) x 615 (L) x 3.1 (T) mm and that of a shipping box are 58.7 x 13.3 x 7.9 cm. 12 Design DesignResources Resources Application Notes Optical Source Models Vesta Series Tunable White arrays are intended for use in dry, indoor applications. For outdoor applications and any environment where there is extended exposure to elevated humidity levels (such as bathrooms, etc.), the end-use fixture should offer protection equivalent to an IP54 or better rating. Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vesta Series product family of LED array products. For a list of resources under development, visit www.bridgelux.com. 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux Vesta Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. LM80 LM80 testing is ongoing. Please contact your Bridgelux sales representative for more information. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vesta Series is in accordance with IEC/TR62778 specification EN62471 for the assessment of blue light hazard to light source and luminaires. Vesta Series Tunable White arrays are classified as Risk Group 1 when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the Vesta Series LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vesta Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vesta Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers STANDARD TEST CONDITIONS MINOR PRODUCT CHANGE POLICY Unless otherwise stated, array testing is performed at the nominal drive current. The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 13 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Blvd Fremont, CA 94538 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2017 Bridgelux, Inc. All rights reserved 2017. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc, and Vesta Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vesta Series Tunable White 13mm Array Product Data Sheet DS153 Rev. A (07/2017) 14
BXRV-TR-2750G-2000-A-15 价格&库存
很抱歉,暂时无法提供与“BXRV-TR-2750G-2000-A-15”相匹配的价格&库存,您可以联系我们找货
