AA36F-R1
AA36F-R1
    TOWARD(拓纬)
    6-SMD(0.300",7.62mm)
    固态 SPST-NO(1 Form A) 6-SMD(0.300",7.62mm)
AA36F-R1 数据手册
80 Hi-A Grade ≥ 1A 36 Series 2.5A . 1a RoHS Compliance Features Application ● Contact Form 1a ● Modem ● Load Voltage 60V ● Telephone Equipment ● Operation LED Current 3.0mA ● Security Equipment ● Load Current 2.5A ● Sensing Equipment ● On-Resistance 0.07Ω ● Automatic Test Equipment ● Output Capacitance 470pF ● I/O Modules ● Low Off-State Leakage Current 1.0µA ● Electric Vehicle 3.4±0.2 8.8±0.3 DIP6 PART NO 6.4±0.3 TO AA 36 TO WA R D 6.4±0.3 AA WA 36 RD F 8.8±0.3 3.4±0.2 S MD 6 PACKAGE PACKING AA36 DIP-6 Tube 50pcs AA36F SMD-6 Tube 50pcs AA36F-R1 SMD-6 Reel 1000pcs * Package & PCB Layout Design, See Page 134 Terminal Identification AA36(F) 1:Anode 2:Cathode 3:NC 4,6:Drain 5:Source (LED) (LED) (MOS FET) (MOS FET) 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. 36 Series. REV.06/2017 81 Hi-A Grade ≥ 1A Absolute Maximum Ratings 絕對最大定格 (Ambient Temperature 周圍溫度:25℃ ) Item Input 輸入 Symbol Value Continuous LED Current 連續 LED 電流 IF 50mA Peak LED Current LED 峰值電流 (f-100 Hz,Duty=1%) IFP 500mA LED Reverse Voltage 逆向 LED 電壓 VR 5V Input Power Dissipation 輸入損耗 PIN 75mW Load Voltage 負荷電壓 VL 60V (AC peak or DC) A B C 2.5A(AC or DC) 3.5A(DC) 5.0A(DC) Load Current 負荷電流 (A) IL Peak Load Current 峰值負荷電流 (1ms,1 shot) (A) IPEAK 6.0 (mW) POUT 500 (mW) PT 550 I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Vrms) VI/O 3750 I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Suffix-H) (Vrms) VI/O 5000 Operating Temperature 使用時溫度 TOPR -40℃ ~ +85℃ Storage Temperature 保存溫度 TSTG -40℃ ~ +100℃ output 輸出 Output Power Dissipation 輸出損耗 Total Power Dissipation 全損耗 Electrical Specifications 電性規格 (Ambient Temperature 周圍溫度:25℃ ) Item LED Forward Voltage LED 順向電壓 Input 輸入 Output 輸出 VF Operation LED Current LED 動作電流 IF ON Recovery LED Voltage LED 復位電壓 VF OFF 1.0 0.5 1.37 1.5 V 1.5 3.0 mA 1.0 RON Off-State Leakage Current 開路狀態漏電流 ILEAK Output Capacitance 輸出端容量 COUT 470 TON 0.6 3.0 ms TOFF 0.04 0.5 ms 復位時間 0.07 Conditions IF=10mA V On-Resistance 導通電阻 Drain to Drain Turn-On Time Transmission 動作時間 傳達 Turn-Off Time Coupled 結合 Symbol MIN. TYP. MAX. Units IF=10mA,IL=Rating Time to flow is within 1sec. 0.1 Ω 1.0 µA IF=0mA,VL=60V pF VL=0V,f=1MHz IF=10mA,IL=Rating I/O Insulation Resistance 輸入 / 出間絕緣阻抗 RI/O I/O Capacitance 輸入 / 力端靜電容量 CI/O 5 x 109 Ω 1 pF f=1MHz 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. BRIGHT TOWARD INDUSTRIAL CO.,LTD. 36 Series. REV.06/2017 82 Hi-A Grade ≥ 1A Load current Vs. Ambient temperature On resistance Vs. Ambient temperature Turn on time Vs. Ambient temperature Turn off time Vs. Ambient temperature LED operate current Vs. Ambient temperature LED Turn off current Vs. Ambient temperature LED forward voltage Vs. Ambient temperature Voltage Vs. current characteristics of output at MOS portion Off state leakage current Vs. Load voltage characteristics LED forward current Vs. turn on time characteristics LED forward current Vs. turn off time characteristics Applied voltage Vs. output capacitance characteristics 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. 36 Series. REV.06/2017 134 Package & PC Board Pattern Package 包裝 Dimensions 外型尺寸圖 PC Board pattern PC 板加工圖 0.3 7.87 9.54 max. ARD TOW DIP4 (Bottom View) 15 max. 0.3 SMD4 1.3 +0.2 0.1 -0.05 0.3 8.7 1.3 ARD TOW (Top View) 7.87 9.54 max. TO WA RD 0.3 DIP6 (Bottom View) 15 max. SMD6 1.3 0.1 +0.2 -0.05 0.3 8.7 TO WA R D 1.3 0.3 (Top View) 7.87 9.54 max. TO WA R D 0.3 DIP8 (Bottom View) 15 max. 1.3 +0.2 0.1 -0.05 0.3 TO WA R D 1.3 0.3 (Top View) TO WA RD 6.3 SMD8 (Top View) 0.06 6.3 TO WA R D SOP4 1.27 SOP8 0.06 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. Package & PC Board Pattern. REV.06/2017 0.76 (Top View) 135 Packing Specifications Package Type 包裝類型 Reel shape & dimensions 圈帶形狀和尺寸 Quantity 數量 100 330 12 4.6 Tape shape & dimensions 形狀和尺寸 4 Pin SOP 2.0 100 330 16 10.4 13 1000 pcs 8 Pin SOP 2.0 80 380 1000 pcs 80 380 4 Pin SMD 1000 pcs 80 380 5.3 17 1000 pcs 1000 pcs 9.15 17 6 Pin SMD 9.9 17 8 Pin SMD 17 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. BRIGHT TOWARD INDUSTRIAL CO.,LTD. Packing Speci ications. REV.06/2017 136 Load Connecting Method Type 類型 Load 負荷 4 pin AC or DC Feature 特長 Control bi-directional signal 可控制雙向信號 AC or DC Control bi-directional signal 可控制雙向信號 B DC On-Resistance is 1/2 of A-connection 導通電阻值是 A 接法的 1/2 2-Make-contacts (Source Common) C DC On-Resistance is 1/2 of B-connection 導通電阻值是 B 接法的 1/2 A 6 pin Connection 接續方法 2 input and 2 output 2 入力和 2 出力回路 8 pin AC or DC 1 input and 2 output 1 入力和 2 出力回路 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. Load Connecting Method. REV.06/2017
AA36F-R1 价格&库存
很抱歉,暂时无法提供与“AA36F-R1”相匹配的价格&库存,您可以联系我们找货
