AB45S
AB45S
    TOWARD(拓纬)
    4-SOP(0.173",4.40mm)
    固态 SPST-NO(1 Form A) 4-SOP(0.173",4.40mm)
AB45S 数据手册
36 General-Purpose 45 Series 60V . 1a/2a AEC-Q101 / Hi-Temp (105℃) Available Features RoHS Compliance Application ● Contact Form 1a / 2a ● Modem ● Load Voltage 60V ● Telephone Equipment ● Operation LED Current 3.0mA ● Security Equipment ● Load Current 200mA ● Sensing Equipment ● On-Resistance 3Ω ● Automatic Test Equipment ● Output Capacitance 20pF ● I/O Modules ● Low Off-State Leakage Current 1.0µA ● Electric Vehicle PART NO D 45 TO S MD 8 4.4±0.3 D 9.4±0.3 S 2.0±0.2 SMD6 3.4±0.2 2.0±0.2 AC AB 45 S ARD TOW 4.4±0.3 6.4±0.3 45 4.3±0.3 9.8±0.3 TO WA R SMD4 3.4±0.2 D IP 8 AC WA 45 RD F 6.4±0.3 TO F 45 AB 3.4±0.2 8.8±0.3 AA WA 45 RD F 6.4±0.3 ARD TOW 3.4±0.2 DIP6 DIP4 4.7±0.3 6.4±0.3 TO WA R 3.4±0.2 9.8±0.3 AC D 6.4±0.3 45 45 AB 3.4±0.2 TO WA R 6.4±0.3 ARD TOW 8.8±0.3 AA 4.7±0.3 SOP4 S OP 8 PACKAGE PACKING AB45 DIP-4 Tube 90pcs AA45 DIP-6 Tube 50pcs AC45 DIP-8 Tube 45pcs AB45F SMD-4 Tube 90pcs AA45F SMD-6 Tube 50pcs AC45F SMD-8 Tube 45pcs AB45S SOP-4 Tube 100pcs AC45S SOP-8 Tube 50pcs AB45F-R1 SMD-4 AA45F-R1 SMD-6 AC45F-R1 SMD-8 AB45S-R1 SOP-4 Reel 1000pcs AC45S-R1 SOP-8 * Package & PCB Layout Design, See Page 134 Terminal Identification AB45(F)(S) 1:Anode (LED) 2:Cathode (LED) 3,4:Drain (MOS FET) AA45(F) 1:Anode 2:Cathode 3:NC 4,6:Drain 5:Source (LED) (LED) AC45(F)(S) 1,3:Anode (LED) 2,4:Cathode (LED) 5,6,7,8:Drain (MOS FET) (MOS FET) (MOS FET) 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. 45 Series. REV.06/2017 37 General-Purpose Absolute Maximum Ratings 絕對最大定格 (Ambient Temperature 周圍溫度:25℃ ) Item Symbol AB45S AC45S AB45(F) AC45(F) AA45(F) Outline Package Input 輸入 Value 1CH 2CH 1CH 2CH Continuous LED Current 連續的 LED 電流 IF 50mA Peak LED Current LED 的峰值電流 (f=100 Hz,duty=1%) IFP 500mA LED Reverse Voltage 逆向的 LED 電壓 VR 5V Input Power Dissipation 容許損失 PIN 75mW Load Voltage 負荷電壓 VL 60V (AC peak or DC) 1CH Load Current 負荷電流 (mA) IL 200 200 200 200 200 Peak Load Current 峰值負荷電流 (1 ms,1 shot) (mA) IPEAK 600 600 600 600 600 Output Power Dissipation 輸出損耗 (mW) POUT 300 450 450 600 450 (mW) PT 350 500 500 650 500 I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Vrms) VI/O 1500 1500 3750 3750 3750 I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Suffix-H) (Vrms) VI/O 3750 3750 5000 5000 5000 Output 輸出 Total Power Dissipation 全損耗 Operating Temperature 使用時周圍溫度 TOPR -40℃ ~ +85℃ Storage Temperature 周圍保存溫度 TSTG -40℃ ~ +100℃ Electrical Specifications 電性規格 (Ambient Temperature 周圍溫度:25℃ ) Item Input 輸入 LED Forward Voltage LED 順向電壓 Operation LED Current LED 的動作電流 Recovery LED Voltage LED 的復位電壓 On-Resistance 導通電阻 Drain to Drain Output 輸出 VF 1.0 IF ON VF OFF 0.5 1.17 1.5 V 0.9 3.0 mA 1.0 3 RON 14 Ω 1.0 µA COUT 20 Turn-On Time 動作時間 TON 0.1 1.0 ms TOFF 0.03 0.5 ms TON 0.07 1.0 ms TOFF 0.03 0.5 ms Turn-Off Time 復位時間 I/O Insulation Resistance 輸入 / 出間的絕緣阻抗 I/O Capacitance 輸入 / 力端的靜電容量 ILEAK R I/O C I/O 109 Conditions IF=10mA V Off-State Leakage Current 開路狀態時的電流 Output Capacitance 輸出端容量 Turn-Off Time Transmission 復位時間 傳達 Turn-On Time 動作時間 Coupled 結合 Symbol MIN. TYP. MAX. Units IF=5mA,IL=Rating Time to flow is within 1sec. VL=60V pF IF=5mA IL=Rating (for SOP type) IF=10mA IL=Rating (for DIP/SMD type) Ω 1.3 pF f=1MHz 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. BRIGHT TOWARD INDUSTRIAL CO.,LTD. 45 Series. REV.06/2017 38 General-Purpose Load current Vs. Ambient temperature On resistance Vs. Ambient temperature Turn on time Vs. Ambient temperature Turn off time Vs. Ambient temperature LED operate current Vs. Ambient temperature LED Turn off current Vs. Ambient temperature LED forward voltage Vs. Ambient temperature Voltage Vs. current characteristics of output at MOS portion Off state leakage current LED forward current Vs. turn on time characteristics LED forward current Vs. turn off time characteristics Applied voltage Vs. output capacitance characteristics 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. 45 Series. REV.06/2017 134 Package & PC Board Pattern Package 包裝 Dimensions 外型尺寸圖 PC Board pattern PC 板加工圖 0.3 7.87 9.54 max. ARD TOW DIP4 (Bottom View) 15 max. 0.3 SMD4 1.3 +0.2 0.1 -0.05 0.3 8.7 1.3 ARD TOW (Top View) 7.87 9.54 max. TO WA RD 0.3 DIP6 (Bottom View) 15 max. SMD6 1.3 0.1 +0.2 -0.05 0.3 8.7 TO WA R D 1.3 0.3 (Top View) 7.87 9.54 max. TO WA R D 0.3 DIP8 (Bottom View) 15 max. 1.3 +0.2 0.1 -0.05 0.3 TO WA R D 1.3 0.3 (Top View) TO WA RD 6.3 SMD8 (Top View) 0.06 6.3 TO WA R D SOP4 1.27 SOP8 0.06 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. Package & PC Board Pattern. REV.06/2017 0.76 (Top View) 135 Packing Specifications Package Type 包裝類型 Reel shape & dimensions 圈帶形狀和尺寸 Quantity 數量 100 330 12 4.6 Tape shape & dimensions 形狀和尺寸 4 Pin SOP 2.0 100 330 16 10.4 13 1000 pcs 8 Pin SOP 2.0 80 380 1000 pcs 80 380 4 Pin SMD 1000 pcs 80 380 5.3 17 1000 pcs 1000 pcs 9.15 17 6 Pin SMD 9.9 17 8 Pin SMD 17 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. BRIGHT TOWARD INDUSTRIAL CO.,LTD. Packing Speci ications. REV.06/2017 136 Load Connecting Method Type 類型 Load 負荷 4 pin AC or DC Feature 特長 Control bi-directional signal 可控制雙向信號 AC or DC Control bi-directional signal 可控制雙向信號 B DC On-Resistance is 1/2 of A-connection 導通電阻值是 A 接法的 1/2 2-Make-contacts (Source Common) C DC On-Resistance is 1/2 of B-connection 導通電阻值是 B 接法的 1/2 A 6 pin Connection 接續方法 2 input and 2 output 2 入力和 2 出力回路 8 pin AC or DC 1 input and 2 output 1 入力和 2 出力回路 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. Load Connecting Method. REV.06/2017
AB45S 价格&库存
很抱歉,暂时无法提供与“AB45S”相匹配的价格&库存,您可以联系我们找货
