AA52F
AA52F
    TOWARD(拓纬)
    6-SMD(0.300",7.62mm)
    固态 SPST-NO(1 Form A) 6-SMD(0.300",7.62mm)
AA52F 数据手册
TOWARD 52 series 1700V·1a (SiC MOSFET) Features Application ● Contact Form 1a ● High Voltage Switching ● Load Voltage 1700V ● Automatic Test Equipment ● Operation LED Current 5.0mA ● Battery Management System ● Load Current 350mA ● Electric Vehicle ● On-Resistance 2.2Ω ● Output Capacitance 135pF 10uA ● Low Off-State Leakage Current D 6.4± 0.3 F 52 AA AA 52 6.4± 0.3 D 3.4± 0.2 TO WA R PART NO 8.8± 0.3 TO WA R 8.8± 0.3 D IP - 5 3.4± 0.2 S MD - 5 PACKAGE PACKING AA52 DIP6-5 AA52F SMD6-5 Tube 50pcs AA52F-R1 SMD6-5 Reel 1000pcs Tube 50pcs Terminal Identification AA52(F) 1:Anode (LED) 2:Cathode (LED) 3:NC 4,6:Drain (MOSFET) Dimensions & PC Board pattern 15 max. 0.3 1.3 + 0. 2 0.1- 0.0 5 8.7 1.3 0.3 (Top View) 52 Series. REV.23-04-01 Absolute Maximum Ratings 絕對最大定格(Ambient Temperature 周圍溫度:25℃ ) Item Symbol Value Continuous LED Current 連續LED 電流 IF 50mA Input Peak LED Current LED 峰值電流(f =100 Hz,Duty=1%) IFP 500mA 輸入 LED Reverse Voltage 逆向LED 電壓 VR 5V Input Power Dissipation 輸入損耗 PIN 75mW Load Voltage 負荷電壓 VL 1700V (AC peak or DC) Load Current 負荷電流 (mA) IL 350 Peak Load Current 峰值負荷電流(1ms,1shot) (mA) IPEAK 1000 (mW) POUT 450 (mW) PT 500 I/O Breakdown Voltage 輸入 /出力間絕緣電壓 (VAC) VI/O 3750 I/O Breakdown Voltage 輸入 /出力間絕緣電壓 (Suffix-H) (VAC) VI/O 5000 output 輸出 Output Power Dissipation 輸出損耗 Total Power Dissipation 全損耗 Operating Temperature 使用時溫度 TOPR Storage Temperature 保存溫度 TSTG -40℃ ~ +85℃ -40℃ ~ +100℃ Electrical Specifications 電性規格 (Ambient Temperature 周圍溫度:25℃ ) Item LED Forward Voltage LED 順向電壓 Input Operation LED Current 輸入 LED 動作電流 Recovery LED Voltage LED 復位電壓 On-Resistance 導通電阻 Drain to Drain Output 輸出 Off-State Leakage Current 開路狀態漏電流 Output Capacitance 輸出端容量 Turn-On Time Transmission 動作時間 傳達 Turn-Off Time 復位時間 I/O Insulation Resistance Coupled 結合 輸入/ 出間絕緣阻抗 I/O Capacitance 輸入/ 力端靜電容量 Symbol MIN. TYP. MAX. Units VF 1.0 IF ON VF OFF 0.5 RON 1.33 1.5 V 2.0 5.0 mA 1.2 2.2 ILEAK COUT 135 TON 0.7 Conditions IF=10mA V IF=10mA,IL=Rating (within 1sec.) 3.5 Ω 10 µA VL=1700V pF VL=0V,f=1MHz 3.0 ms IF=10mA,IL=Rating TOFF RI/O CI/O 0.05 1.0 ms Ω 1010 1.3 pF f=1MHz BRIGHT TOWARD INDUSTRIAL CO.,LTD. 52 Series. REV.23-04-01 AA52 Reference Data Load Current Vs. Ambient temperature 400 On resistance Vs. Ambient temperature 5.00 Turn on time Vs. Ambient temperature 2.5 2.0 4.00 300 250 Turn on time (ms) On resistance (Ω) Load Current(mA) 350 3.00 200 2.00 150 100 1.00 1.5 1.0 0.5 50 -40 -20 0 20 40 80 85 100 60 0.00 -40 -15 Turn off time Vs. Ambient temperature 0.1 0.0 -40 10 35 60 Ambient temperature (℃) -40 3.0 2.0 1.0 0.0 85 -15 10 35 60 Current, A 0.2 -0.4 1.0 0 0.4 0.8 -0.2 1.0 0.5 -40 60 85 -0.4 Turn on time Vs. LED forward current characteristics 900 600 300 0 10 20 30 40 LED forward current (mA) 50 1.E-10 1.E-11 75 50 25 10 20 30 40 LED forward current (mA) 200 400 600 800 1,000 Load volage (V) Output capacitance Vs. applied voltage 200 0 85 1.E-09 0 0 0 60 1.E-12 100 Turn off time (μs) Turn on time (μs) 1200 35 1.E-08 Turn off time Vs. LED forward current characteristics 125 10 1.E-07 Voltage, V Output capacitance (pF) 1500 35 -15 Ambient temperature (℃) Off state leakage Current Vs. load voltage 1.E-06 0.8 10 85 1.5 0.4 0 Ambient temperature (℃) 60 2.0 Current Vs. voltage characteristics of output at MOS portion -0.8 -15 35 2.5 85 Ambient temperature (℃) 1.2 -40 10 Ambient temperature (℃) 0.0 -40 1.4 -15 LED turn off current Vs. Ambient temperature 3.0 4.0 LED forward voltage Vs. Ambient temperature 1.6 LED forward voltage (V) -15 0.0 85 LED turn off current (mA) LED operate current (mA) Turn off time (ms) 0.2 60 LED operate current Vs. Ambient temperature 5.0 0.3 35 Ambient temperature (℃) Ambient temperature (℃) 0.4 10 Off state leakage current (A) 0 50 160 120 80 40 0 0 10 20 30 40 Applied Volage (V) BRIGHT TOWARD INDUSTRIAL CO.,LTD. 52 Series. REV.23-04-01
AA52F 价格&库存
很抱歉,暂时无法提供与“AA52F”相匹配的价格&库存,您可以联系我们找货
