AA58F
AA58F
    TOWARD(拓纬)
    6-SMD(0.300",7.62mm)
    固态 SPST-NO(1 Form A) 6-SMD(0.300",7.62mm)
AA58F 数据手册
58 series 1800V·1a (SiC MOSFET) AEC-Q101 Certified Application Specification Contact Form 1a Battery Management System (BMS) Load Voltage 1800 V Energy Storage System (ESS) Operation LED Current 5.0 mA Automatic Test Equipment (ATE) Load Current 30 mA High Voltage Switching 0 On-Resistance Output Capacitance 10 pF Low Off-State Leakage Current 1 uA/10 uA ( Tested at 1500 VDC / 1800 VDC) Features High Voltage with Low On-Resistance Fast Reverse Recovery High Avalanche Ruggedness Steady Leakage Current at High Temperature Output Creepage Distance 3.8 mm Input / Output Clearance Distance 7.3 mm Input / Output Creepage Distance 8.9 mm Terminal Identification AA58(F) PART NO 1:Anode (LED) 2:Cathode (LED) 3:NC PACKAGE PACKING AA5 DIP6-5 Tube 50pcs AA5 F SMD6-5 Tube 50pcs AA5 F-R1 SMD6-5 Reel 1000pcs 4,6:Drain (MOSFET) Dimensions & PC Board pattern 15 max. 0.3 1.3 + 0. 2 0.1- 0.0 5 8.7 1.3 0.3 (Top View) 58 Series. REV.23-04-01 Absolute Maximum Ratings 絕對最大定格(Ambient Temperature 周圍溫度:25℃ ) Item Symbol Value Continuous LED Current 連續LED 電流 IF 50mA Input Peak LED Current LED 峰值電流(f =100 Hz,Duty=1%) IFP 500mA 輸入 LED Reverse Voltage 逆向LED 電壓 VR 5V Input Power Dissipation 輸入損耗 PIN 75mW Load Voltage 負荷電壓 VL 1800V (AC peak or DC) Load Current 負荷電流 (mA) IL 30 Peak Load Current 峰值負荷電流(10ms,1shot) (mA) IPEAK 80 (mW) POUT 450 (mW) PT 500 I/O Breakdown Voltage 輸入 /出力間絕緣電壓 (Vrms) VI/O 3750 I/O Breakdown Voltage 輸入 /出力間絕緣電壓 (Suffix-H) (Vrms) VI/O 5000 Operating Temperature 使用時溫度 TOPR -40℃ ~ +105℃ Storage Temperature 保存溫度 TSTG -40℃ ~ +125℃ output 輸出 Output Power Dissipation 輸出損耗 Total Power Dissipation 全損耗 Electrical Specifications 電性規格 (Ambient Temperature 周圍溫度:25℃ ) Item LED Forward Voltage LED 順向電壓 Input Operation LED Current 輸入 LED 動作電流 Recovery LED Voltage LED 復位電壓 On-Resistance 導通電阻 Drain to Drain (tested within 1 sec.) Output 輸出 Off-State Leakage Current 開路狀態漏電流 Output Capacitance 輸出端容量 Turn-On Time Transmission 動作時間 傳達 Turn-Off Time 復位時間 I/O Insulation Resistance Coupled 結合 輸入/ 出間絕緣阻抗 I/O Capacitance 輸入/ 力端靜電容量 Symbol MIN. TYP. MAX. Units VF 1.0 IF ON VF OFF 0.5 RON 1.33 1.5 V 2.0 5.0 mA 1.2 Conditions IF=10mA V 120 200 Ω 100 180 Ω 10 µA VL=1800V 1 µA VL=1500V pF VL=0V,f=1MHz ILEAK COUT 10 TON 0.2 3.0 IF=10mA,IL=Rating IF=10mA,IL=5 mA ms IF=10mA,IL=Rating TOFF RI/O CI/O 0.06 1.0 ms Ω 1010 1.3 pF f=1MHz BRIGHT TOWARD INDUSTRIAL CO.,LTD. 58 Series. REV.23-04-01 AA58 Reference Data Load Current Vs. Ambient temperature 50 300 20 10 0.80 Turn on time (ms) On resistance (Ω) 30 200 150 100 50 0 0 -40 -10 20 50 80 110 -40 -10 20 50 80 Ambient temperature (℃) Ambient temperature (℃) Turn off time Vs. Ambient temperature LED operate current Vs. Ambient temperature 1.00 5.0 0.60 0.50 0.40 0.30 0.20 0.10 0.00 20 50 80 Ambient temperature (℃) 4.0 3.0 2.0 1.0 0.0 110 -10 20 50 80 Ambient temperature (℃) Current, A 1.4 -4 -3 -2 -1 0 1 2 3 4 5 0.8 80 110 -0.03 Turn on time Vs. LED forward current characteristics 1000 Turn off time (μs) Turn on time (μs) 800 600 400 200 0 10 20 30 40 LED forward current (mA) 50 50 80 110 Off state leakage Current Vs. load voltage 1.E-08 1.E-09 0 300 600 900 1,200 1,500 1,800 Load volage (V) Output capacitance Vs. applied voltage 20 150 100 50 16 12 8 4 0 0 20 1.E-10 Turn off time Vs. LED forward current characteristics 200 -10 Ambient temperature (℃) 1.E-07 Voltage, V Output capacitance (pF) 50 0.5 1.E-06 -0.02 20 1.0 0.02 1.0 Ambient temperature (℃) 110 1.5 0.03 -0.01 -10 80 2.0 1.E-05 0.01 -5 -40 50 LED turn off current Vs. Ambient temperature -40 0 1.2 20 Ambient temperature (℃) 2.5 110 Current Vs. voltage characteristics of output at MOS portion 1.6 -10 0.0 -40 LED forward voltage Vs. Ambient temperature 1.8 LED forward voltage (V) -10 0.20 3.0 Off state leakage current (A) -40 0.40 -40 LED turn off current (mA) LED operate current (mA) Turn off time (ms) 0.70 0.60 0.00 110 0.90 0.80 Turn on time Vs. Ambient temperature 1.00 250 40 Load Current(mA) On resistance Vs. Ambient temperature 0 10 20 30 40 LED forward current (mA) 50 0 0 10 20 30 Applied Volage (V) BRIGHT TOWARD INDUSTRIAL CO.,LTD. 58 Series. REV.23-04-01 40
AA58F 价格&库存
很抱歉,暂时无法提供与“AA58F”相匹配的价格&库存,您可以联系我们找货
