HDTB-6
HDTB-6
    C3CONTROLS
    HIGH DNSTY TB - 6 POINT ASSEMBLY
HDTB-6 数据手册
TB nema 300 310 miniature 1100 miniature series HIGH DENSITY TERMINAL BLOCKS TB TB TB SERIES PRODUCT PROFILE series high density c3controls’ new line of High Density Terminal Blocks are both innovative and userfriendly. They are available in multiple terminal points from 4, 6, and 12 in a single molded housing, are simple to install, and carry an electrical rating of 30A @ 600V AC (UL/CSA) and 30A @ 750V AC (IEC). ENGINEERED TO HANDLE YOUR MOST COMPLEX WIRING APPLICATIONS. Proven Our high density terminal blocks meet UL and CSA standards, and are RoHS compliant. Multiple Wire Sizes High density terminal blocks accommodate #18 to #10 AWG wires (0.34 – 4mm2). UNIQUE PRODUCT LINE FEATURES 1. Multiple terminal points: 4, 6, or 12 in a single molded housing. Wide Range of Operation A wide range of 4, 6, and 12 point circuit terminal blocks in a single molded housing rated for 600V, 30A continuous service. 2. Convenient c3controls high density terminal blocks are directly interchangeable with GE CR151 terminal blocks. Out of the box and ready to install! Screws come in the backed out position with convenient spring-return open terminals for easy wiring. 3. Rugged, corrosive resistant materials and 8 - 32 terminal screws. Wiring to the terminal blocks is made easy by unobstructed access to terminals and with screws in the fully backed-out position. 4. Integrated 35mm DIN Rail snap and panel mounting geometry Wiring Made Easy 5. Integrated IP20 guarded terminals prevent accidental contact. 6. Large marking strip available that can be hand marked or custom printed with a plotter. Heavy-Duty Construction We mold our terminal block housings from unbreakable thermoplastic and we use quality zinc plated brass and electrolytic copper for our metal parts for excellent conductivity and to minimize corrosion. Quick Identification Terminal markers are available and can be hand marked or custom printed. Easy to Install Available panel mounting or 35mm DIN rail mounting for easy assembly. Time Savings Individual blocks can be quickly and easily added or removed without disturbing adjacent blocks. Only a screwdriver is required for removal. Lifetime Warranty* Every product is backed by our lifetime warranty—unmatched in the industry—bringing you quality components that perform in the most demanding applications. Guaranteed Same-Day Shipping* Product availability reduces inventory, and improves cash-flow— saving you money. With c3controls any order for standard catalog items received by 6:00pm ET is guaranteed to ship same-day. Advantage Pricing Our approach to product development, manufacturing, and focus on servicing the OEM and Electrical Equipment Builder reduces cost. The result—the best value in the industry. 5 4 1 2 6 3 *See c3controls Terms & Conditions THE BEST ELECTRICAL CONTROLS BUSINESS ON THE PLANET! 724.775.7926 | www.c3controls.com series TB series TB HIGH DENSITY TERMINAL BLOCKS high density SPECIFICATIONS DIMENSIONS HDTB-4 HDTB-6 HDTB-4 HDTB-12 1-5/16" (32.5mm) 1-3/16" (30.0mm) 1-1/8" (28.4mm) UNITS UL 1059 File #: E145984 Voltage Rating V 600 600 600 Maximum Current A 30 30 30 AWG #18 - #10 #18 - #10 #18 - #10 1-1/8" (28.4mm) Wire Strip Length in. 5/16 5/16 5/16 Tightening Torque lb-in. 7-12 (max. 18-20) 7-12 (max. 18-20) 7-12 (max. 18-20) ROHS COMPLIANCE For RoHS compliance documentation by product, refer to www.c3controls.com. 2-3/8" (60.5mm) 1-3/16" (30.0mm) PANEL MOUNT USING #8 MACHINE SCREW 1-5/16" (32.5mm) 2-3/8" (60.5mm) 1-3/16" (30.0mm) 1-3/4" (44.4mm) 1-5/16" (32.5mm) 1-5/16" (32.5mm) 1-3/16" (30.0mm) PANEL MOUNT USING #8 MACHINE SCREW 1-5/16" (32.5mm) PANEL MOUNT USING 3-1/2" (88.9mm) #8 MACHINE SCREW 1-3/16" (30.0mm) 2-1/4" (57.2mm) 3-1/2" (88.9mm) 1-3/4" (44.4mm) 1-3/4" (44.4mm) 1-3/16" (30.0mm) 1-3/16" (30.0mm) 2-1/4" (57.2mm) 1-3/4" (44.4mm) 1-5/16" (32.5mm) 2-1/4" (57.2mm) PANEL MOUNT USING #8 MACHINE SCREW 3-1/2" (88.9mm) PANEL MOUNT USING #8 MACHINE SCREW 3-1/2" (88.9mm) 5-5/8" (142.8mm) 1-3/4" (44.4mm) 1-5/16" (32.5mm) 5-5/8" (142.8mm) 5-5/8" (142.8mm) 1-3/16" (30.0mm) HDTBMS-6 PANEL MOUNT USING #8 MACHINE SCREW 1-5/16" (32.5mm) PANEL MOUNT USING 6-7/8"(10.8mm) (174.8mm) 3-1/16" (78.2mm) 7/16" #8 MACHINE SCREW 1-3/16" (30.0mm) PANEL MOUNT USING #8 MACHINE SCREW 6-7/8" (174.8mm) PANEL MOUNT USING #8 MACHINE SCREW 6-7/8" (174.8mm) PANEL MOUNT USING #8 MACHINE SCREW 3-1/2" (88.9mm) 1-5/16" (3 1-3/16" (30.0mm) 1-5/16" (32.5mm) 6-7/8" (174.8mm) 1-3/4" (44.4mm) 1-3/4" (44.4mm) 1-3/4" (44.4mm) 1-3/16" (30.0mm) 1-5/16" (32.5mm) 1-3/16" (30.0mm) 2" (50.5mm) 1-3/16" (30.0mm) 5-5/8" (142.8mm) HDTB-12 1-5/16" (32.5mm) 2-1/4" (57.2mm) 7/16" (10.8mm) HDTBMS-4 PANEL MOUNT USING 5-5/8" (142.8mm) #8 MACHINE SCREW 3-1/2" (88.9mm) 1-3/4" (44.4mm) PANEL MOUNT USING #8 MACHINE SCREW 1-3/4" (44.4mm) 2-3/8" (60.5mm) 1-5/16" (32.5mm) PANEL MOUNT USING 2-1/4" (57.2mm) #8 MACHINE SCREW 2-3/8" (60.5mm) HDTB-6 1-3/16" (30.0mm) PANEL MOUNT USING 1-5/16" (32.5mm) #8 MACHINE SCREW PANEL MOUNT USING #8 MACHINE SCREW 2-3/8" (60.5mm) 2-1/4" (57.2mm) For complete ratings and detailed specifications refer to www.c3controls.com. 1-1/8" (28.4mm) 1-5/16" (32.5mm) 1-3/16" USING (30.0mm) PANEL MOUNT #8 MACHINE SCREW 1-1/8" (28.4mm) 2-3/8" (60.5mm) 1-3/4" (44.4mm) Wire Range 1-3/4" (44.4mm) UL 1059 File #: E145984 1-5/16" (32.5mm) 1-3/16" (30.0mm) 1-1/8" (28.4mm) 1-3/4" (44.4mm) UL 1059 File #: E145984 1-3/4" (44.4mm) 12 Circuit Terminal Block 1-3/4" (44.4mm) 6 Circuit Terminal Block 1-3/4" (44.4mm) Certifications 4 Circuit Terminal Block 1-3/4" (44.4mm) SPECIFICATIONS 1-5/16" (32.5mm) 1-3/16" (30.0mm) 1-1/8" (28.4mm) PANEL MOUNT USING #8 MACHINE SCREW 6-7/8" (174.8mm) 1-5/16" (32.5mm) 1-3/16" (30.0mm) 1-3/4" (44.4mm) 5-5/8" (142.8mm) 6-7/8" (174.8mm) PANEL MOUNT USING #8 MACHINE SCREW CERTIFICATIONS Conformity to Standards: Certifications: UL 1059 CSA C22.2 No. 65, 188 IEC 60947-1, 60947-7 UL File #: E145984 (Guide XCFR2, XCFR8) CE Marked (per EU Low Voltage Directive 2006/95/EC and RoHS Directive 2011/65/EU) Visit www.c3controls.com to download product certifications. Copyright © 2019 c3controls. All Rights Reserved. REVISION 08.2019
HDTB-6 价格&库存
很抱歉,暂时无法提供与“HDTB-6”相匹配的价格&库存,您可以联系我们找货
