3846C002
3846C002
    CANON(佳能)
    CPGA180
    2.7MP 19UM 2160X1280 MONO
3846C002 数据手册
19μm Ultra High Sensitivity CMOS Sensor 35MMFHDXS_A Product Sheet The 35MMFHDXS_A CMOS sensor delivers high-sensitivity, low-noise imaging performance, even in exceptionally low-light environments. The sensor’s pixels and readout circuitry employ new technologies that reduce noise, which tends to increase as pixel size increases. High sensitivity and increased well depth have been achieved through a larger pixel size of 19μm x 19μm (square) with proprietary device design technologies. It is available with an RGB color filter or in monochrome. Wide Angle of View With a full readout resolution of 2160×1280, as compared to the 1920×1080 imaging area of full HD, this CMOS sensor enables use in applications requiring large image capture areas such as astronomy. This added resolution also provides an option for a 6:4 aspect ratio (1920×1280) needed in surveillance applications and an option for a 1:1 aspect ratio (1280×1280) needed in industrial applications. Vertical Resolution (total lines) Max Frame Rate 1280 98 1080 115 720 165 360 300 Readout Position and Frame Rate Control The vertical readout start position can be specified to allow flexibility in both frame rate and resolution depending on the application and required performance level. Horizontal cropping must be performed in post processing. Moreover, when a high resolution is not required, vertical blanking can reduce power consumption. Low Dark Current Canon has incorporated technology within this sensor to reduce dark current during long exposure times. This enables clean imaging over long exposures where only the faintest of light is present. 35MMFHDXS_A 19μm Ultra High Sensitivity CMOS Sensor Specifications Product Sheet Quantum Efficiency Plot - RGB & Mono 35MMFHDXSCA 35MMFHDXSMA Filter Type RGB Monochrome Sensitivity (e/lx/sec @gain x1) 1,100,000 (green) 2,100,000 Sensor Size 41.04mm x 24.32mm Number of Effective Pixels 2160h x 1280v Pixel Size 19μm x 19μm Scan Type Progressive Scan Shutter Rolling Shutter Maximum Frame Rate (All Pixels) 98 fps Register Control Type Three Wire Serial Communication Package Type 180 pin ceramic PGA Saturation 61,000e @gain x1 Conversion Gain 5.6 μV/e @gain x1 Dark Random Noise (Room Temp) 2.2e rms @gain x16 Dark Current (-20° C) 0.003 e/sec Dark Current (Room Temp) 60 e/sec Drive Frequency 16 ch x 21 MHz (Recommended) Readout Simultaneous reading of vertical 4 lines Output Format 16 Channel Analog Outputs (Differential) Column Amplifier Gains x1, x2, x4, x8, x16 Power Consumption 1.7W Typ. (@ all pixels readout at 60 fps) Power Supply Voltage 5.0 V, 3.3 V Package Size (External Electrodes Not Included) Pixel Arrangement Effective Pixels 2160 1360 1280 60 OUT13 OUT14 OUT15 OUT16 G B G B Vertical Scan Direction Part Number OUT9 OUT10 OUT11 OUT12 R G R G OUT5 G OUT6 B OUT7 G OUT8 B OUT1 R OUT2 G OUT3 R OUT4 G 72 - OB 8 - PED 2220 60.9mm x 44.6mm x 3.57mm Horizontal Scan Direction Three Wire Serial Communication Vscan Power Pixel External Driving Signals Hscan Amplifier 16 Analog Outputs (Differential) Applications • Astronomy • Surveillance • Security • Industrial • Machine Vision • Life Sciences • Medical For more information visit https://canon-cmos-sensors.com All specifications based on Canon’s testing standards and subject to change without notice. ©2019 Canon USA, Inc. v4.1
3846C002 价格&库存
很抱歉,暂时无法提供与“3846C002”相匹配的价格&库存,您可以联系我们找货
