CD79F
THERMAL PROTECTION
FOR MOTOR WINDINGS &
TRANSFORMERS
CD79F
Thermal Protection
for Motor Windings
& Transformers
These thermal protectors operate by means of a
thermally sensitive snap action bimetal which switches
open a single pole/single throw electrical contact upon
reaching a factory calibrated response temperature.
Heat transfer occurs on all sides via conduction,
convection or radiation. The bimetal disc snaps closed
once the reset temperature has been reached.
Installation tips
Features
• Snap action accuracy
• Universal size
• Maximum switch load 22 Amps
• Very economical
• Current & temp sensitive
When installing thermal cutouts, it is important
to ensure good heat transfer. The heat sensitive
surface (base) should be placed on/near to the
heat source. Heat conducting paste or paint will
improve heat transfer.
Applications
Single Phase Motors, Generators, Convertors,
Transformers, Pumps, Heating Elements, Signal
Transmitters, Fire Detectors, Magnets, Relays,
Chokes, Coils, Power Supplies, Inverters
Examples
AC Motors, Transformers, Battery packs, Blanket
heaters, Heating appliances, Fluorescent light
ballasts, Recessed lighting fixtures, Automotive
DC Motors, Water bed heaters
Voltage
Current
(Res.)
Endurance
(No. Cycles)
120 VAC
5 Amperes
100,000
16 VDC
20 Amperes
10,000
120 VAC
22 Amperes
10,000
277 VAC
8 Amperes
10,000
It should be noted that standard version thermal
cutouts have a current-carrying housing, and
that with electrically insulated cutouts the
impaired heat transfer can alter the effective
switching temperature. This should be borne
in mind when selecting the nominal response
temperature.
With single-phase motors, the cutout should
switch the mains supply. It will then switch the
motor off if there is any undesirable heating. The
motor short circuit current will then be safely
interrupted, if this is larger than the current
rating of the cutout.
For three-phase motors, the motor current will
not be interrupted direct from the mains supply.
The cut-out installed in the windings should
switch in series with the magnetic coil of the
contactor. The electrical supply to the cutouts
should lead either singly or together from the
motor terminals so that connection with the
control circuit is possible.
Technical data
Contact arrangement
Normally Closed
Contact resistance
很抱歉,暂时无法提供与“CD79F09005A”相匹配的价格&库存,您可以联系我们找货
