Thermal Cut-Off 250 Vac
L50N 1) 5/10/20/25A
L50NG900 (max. 184 °C)
L10N 1) 3/8A
Thermal
Cut-Off
HDMV, HDMH 15A 2)
L10N
HDMV
L10N
L50NG902 (max. 184°C)
HDMH
L10NG911
L50NG913 (max. 240°C)
Plastic or
metal housing
temperature rating (°C)
type
Tf
Th
Tm
Tm
Tf
type
Th
Tm
78
DM
62
250
71
L10N
55
175
90
DM
68
250
72
L50N
99
DM
83
250
77
L50N
L10N
55
175
110
DM
86
250
84
L50N
120
DM
96
250
85
L10N
55
175
130
DM
112
250
90
L10N
60
175
140
DM
125
250
93
L50N
150
DM
135
250
98
L50N
170
DM 1)
145
250
100
L50N
L10N
70
175
182
DM
163
250
104
L50N
190
DM
170
250
108
L10N
78
175
110
L50N
117
L50N
118
L10N
88
175
121
L50N
128
L50N
130
L10N
100
175
140
L10N
110
175
144
L50N
150
L10N
120
175
152
L50N
For Ratings see
SDFS/SDFL 15A
165
L10N
135
175
167
L50N
172
L50N
184
L50N
190
L50N
192
L50N
205
L50N 3)
216
L50N
3)
229
L50N 3)
240
L50N 3)
tolerance (K)
wire
1)
Th
type
0 / -5
0 / -7
see chart below
see chart below
6.3 x 0.8 mm
type
lead
code
temperature max.
operating voltage
max.
diameter
insulation
L10N
stranded white
L330
200 °C
600 V
0.90 mm
AWG24 / 0.24 mm2
3557
L10N G911
stranded white
L340
200 °C
600 V
1.26 mm
AWG20 / 0.61 mm2
3557
L50N
stranded white
L350
200 °C
600 V
1.50 mm
AWG18 / 0.96 mm2
3557
L50N
solid yellow
L440
200 °C
300 V
1.51 mm
AWG20 / 0.81 mm
1332
not approved
2)
UL approved only
3)
Tf >200°C on request
Applications
- Household appliances
- Electronic appliances
- Fan heaters
- Transformers
- Automotive industry
Benefits
0 / -5
cross section
diameter
UL style
Deviations from standard types on request.
8415 Mountain Sights Avenue • Montreal (Quebec), H4P 2B8, Canada
Tel: (514) 739-3274 • 1-800-561-7207 • Fax: (514) 739-2902 • E-mail: sales@cantherm.com
Website: www.cantherm.com | Division of Microtherm
2016/SEPT THERMAL CUTOFF
HDM
L10
L50
MTEF
MTHF
MTKF
MTML
MTNF
MTR1
MTS1
MTTF
MTYF
MWS
SDF
S3M
- Small compact design
- Broad product line
- Dust-proof design
- Customer-specific design
MTKF 1A
ceramic
housing
MTTF 1/2A
size B (00): 38
size B (01): 68
MTYF 4/5A
size B (00): 38
size B (01): 68
size B (00): 38
size B (01): 68
temperature rating ( C)
o
Tf
type
Th
Tm
type
Th
Tm
65
K06F
55
200
T06F
50
200
76
T0F
55
200
Y06 1)
Th
Tm
45
200
Y0F
55
200
type
MTNF
Tf
Functioning open temperature.
Th
Holding temperature:
Maximum continuous exposure temperature
during operation.
Tm
Maximum overshoot temperature:
Above this temperature the TCO might
conduct again.
plastic
housing
1A
size E (S): 36
size E (L): 68
All current ratings relate to resistive loads.
MTML 1A
MTHF 2A
MTEF 3A
housing: white
size E (S): 36
size E (L): 68
size E (S): 36
size E (L): 65
Tm
type
Th
Tm
type
N06F 1)
Th
Th
Tm
65
50
200
H06F
50
200
E06F
50
200
76
N0F
50
200
H0F
50
200
E0F
55
200
86
N1F
60
200
H1F
60
200
E1F
65
200
102
N2F
75
200
L10
75
165
H2F
75
200
E2F
70
200
115
N3F
95
200
L20
85
165
H3F
95
200
E3F
90
200
L30
90
165
200
H4F
100
200
E4F
95
200
Tf
type
Th
Tm
type
86
T1F
60
200
Y1F
60
200
102
K2F
80
200
T2F
75
200
Y2F
70
200
115
K3F
99
200
T3F
95
200
Y3F
90
200
127
K4F
110
200
T4F
110
200
Y4F
100
200
133
K13F
110
200
T13F
105
200
Y13F
100
200
125
136
K5F
115
200
T5F
105
200
Y5F
105
200
127
N4F
139
K6F
120
200
T6F
120
200
Y6F
115
200
130
L33
100
165
145
K7F
125
200
Y7F
125
200
133
N13F
105
200
H13F 1)
100
200
E13F
95
200
105
tolerance (K)
0 / -10
0 / -10
0 / -10
136
N5F
100
200
H5F
100
200
E5F
95
200
wire (mm)
Ø 0.53
Ø 0.53
Ø 0.70
139
N6F
110
200
H6F
110
200
E6F
105
200
145
N7F
125
200
H7F
110
200
E7F
115
200
S3M7 5A
S3M4 10A
metal
housing
SDFS/SDFL 15A
size A (00): 63.8
size A (01): 82.9
S3M5 20A
size B (S): 25.4
size B (L): 35
S3M8 25A
size A (00): 63.8
size A (01): 82.9
tolerance (K)
0 / -10
0 / -10
0 / -10
0 / -10
wire (mm)
Ø 0.53
Ø 0.52
Ø 0.55
Ø 0.70
MTR1 3A 2)
MTS1 5A
MWS1 15A
MWS2 20A
size A (00): 63.8
size A (01): 82.9
temperature rating (oC)
Tf
type
Th
Tm
type
Th
Tm
type
Th
Tm(VDE)
Tm(UL)
type
Th
Tm
type
Th
Tm
66
DF
42
110
130
70
E7F
55
125
E4A
55
130
E5A
55
175
E8A
45
175
72
E4A
57
100
DF
50
115
110
E5A
57
175
E8A
47
175
77
E7F
62
125
E4A
62
125
DF
55
120
110
E5A
62
200
E8A
52
200
84
E7F
69
125
E4A
69
125
DF
60
125
114
E5A
69
200
E8A
59
200
91
DF
67
135
121
93
E7F
78
140
E4A
78
140
E5A
78
215
E8A
68
215
98
E7F
83
140
E4A
83
140
DF
76
140
130
E5A
83
215
E8A
73
215
100
E7F
85
130
E4A
85
140
DF
78
135
250
E5A
85
215
104
E4A
89
150
DF
80
150
150
E5A
89
225
E8A
79
225
110
E7F
95
140
E4A
95
150
DF
86
140
140
E5A
95
225
E8A
85
225
117
E7F
102
150
E4A
102
160
E5A
102
235
E8A
92
235
119
DF
95
170
170
121
E7F
106
150
E4A
106
160
E5A
106
235
E8A
96
235
128
E7F
113
150
E4A
113
205
DF
106
155
155
E5A
113
235
E8A
103
235
141
DF
117
171
171
144
E7F
129
175
E4A
129
240
DF
120
250
250
E5A
129
250
E8A
119
250
152
E7F
137
175
E4A
137
205
DF
128
176
175
E5A
137
250
E8A
127
250
167
E7F
152
200
E4A
152
240
E5A
152
285
E8A
142
285
170
DF
146
300
190
172
E7F
157
200
E4A
157
240
E5A
157
350
184
E7F
169
200
E4A
169
210
DF
160
300
214
E5A
169
350
E8A
159
350
190
E7F
175
270
E4A
175
310
E5A
175
350
192
E4A
177
210
DF
162
290
222
E5A
177
350
E8A
167
350
205
E4A
189
310
E5A
189
375
216
E4A
200
375
DF 1)
191
241
E5A
200
375
228
DF
193
300
300
229
E4A
200
375
E5A
200
375
E8A
200
375
240
E4A
200
450
DF
200
290
260
E5A
200
375
E8A
200
375
tolerance (K)
wire (mm)
1)
VDE approved only
0 / -5
0 / -5
0 / -5
0 / -5
0 / -5
Ø 0.57
Ø 1.0
Ø 1.02 / AWG18
Ø 1.0
Ø 1.0
i
Tape + Reel, cut and bent on request
plastic
housing
Tf
type
Th
Tm
type
Th
Tm
type
Th
Tm
type
Th
98
R-95
70
180
100
S95 3)
70
180
S95H 3)
70
180
S95 3)
70
180
108
R-105
80
180
110
S105 2)
130
R-125
100
180
143
150 (not RoHS compliant)
2)
S138 2)
S125
80
180
S105H 2)
100
180
3)
110
180
S145H 3)
S125H
80
180
S105 3)
80
180
100
180
120
180
S145 3)
120
180
tolerance (K)
0 / -10
0 / -10
0 / -10
0 / -10
wire (mm)
Ø 0.60
Ø 0.70
Ø 1.20
Ø 1.60
1)
VDE approved only
2)
UL approved only
3)
Tm
not approved
Ordering example
S3M4 E4A 00 121
temperature Tf
construction / code: 00 / S (one side short); 01 / L (both sides long)
type (manufacturer designation)
sales name
很抱歉,暂时无法提供与“MTR1 R125”相匹配的价格&库存,您可以联系我们找货
