C3FSV7
C3FSV7
    CARDINALCOMPONENTS
    SMD6
    振荡器 311.04 MHz LVDS XO(标准) 3.3V 启用/禁用 6-SMD,无引线
C3FSV7 数据手册
CARDINAL COMPONENTS Telecom OC12 Oscillator Applications • 311.04 MHz Fixed Osc • LVDS Output • • • • • SDH / SONET Digital Switching Test Equipment Cellular Telephony Land Mobile Radio Series C3FSV Part Numbering Example: C3FSV Z Specifications: Min Frequency Range: Available Stability Options: Supply Voltage: Typ Max 311.04 -30 3.135 3.3 Unit MHz 30 ppm 3.465 V Operating Temperature Range Options: -10 85 °C Storage Temperature: -55 125 °C Duty Cycle: 45 55 % 10 mS Start-Up Time: 3 Aging (PPM/1st Year): Ta=25C, Vdd=3.3V Static Discharge Voltage Mil-Std 883, method 3015 ±5 2000 V Supply Current 80 Short Circuit Current ± 50 Jitter Integrated Period 3 10 Phase Noise @10KHz Offset mA 4 -122 Output Level: LVDS Packaging: Tape & Reel mA pS pS dBc/Hz Notes: Extended exposure exceeding maximum ratings may cause permanent damage and affect reliability. Operation outside of specifications is not supported. Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 http://www.cardinalxtal.com E-Mail: cardinal@cardinalxtal.com 121002-REV. 2.0 Specifications subject to change without notice. Check website for latest updates 1 CARDINAL COMPONENTS C3FSV PIN 1 2 3 4 5 6 DIMENSIONS FUNCTION N/C OE GND LVDS + LVDS Vdd ARE IN MM LEVELS TEST CIRCUIT SWITCHING TEST CIRCUIT Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 http://www.cardinalxtal.com E-Mail: cardinal@cardinalxtal.com 121002-REV. 2.0 Specifications subject to change without notice. Check website for latest updates 2
C3FSV7 价格&库存
很抱歉,暂时无法提供与“C3FSV7”相匹配的价格&库存,您可以联系我们找货
