TM7SMSTS9MS031C
TM7SMSTS9MS031C
    TRI-STAR
    同轴电缆组件 SSMP 至 2.92mm 0.078" OD 外径同轴缆线 12.20"(310.00mm)
TM7SMSTS9MS031C 数据手册
4 3 2 D 5 2 6 7 REV. A REGION DESCRIPTION 1 PRELIMINARY RELEASE 3 4 DATE 30.Jun.20 BY Falcon 1 D CABLE LENGTH "XXX" C PART NUMBER LENGTH ( CM) TOLERANCE (mm) Max VSWR Up to 40Ghz Max insertion loss(dB) Up to 40Ghz TM7SMSTS9MS0016 16 ±5 1.35:1 1.08 TM7SMSTS9MS0046 46 ±8 1.35:1 2.50 TM7SMSTS9MS0020 20 TM7SMSTS9MS0031 ±5 31 TM7SMSTS9MS0061 ±5 61 TM7SMSTS9MS0076 ±8 76 TM7SMSTS9MS0091 ±8 91 TM7SMSTS9MS00100 ±8 100 TM7SMSTS9MS00122 ± 12 122 ± 12 1.35:1 6~30 ±1 0.5~3 4 ±0.05 ±1.5 3~6 ±0.05 ±2.5 6~30 ±0.1 400~1K ±4 ±0.1 3 4.63 1.35:1 5.03 1.35:1 6.04 7 M23053/5-304-0 5 M23053/5-305-0 3 16701078-01 LOW LOSS .078 COAXIAL CABLE TM7S-STS-00 CONN, SSMP, FEMALE, STRAIGTH, TL 4 (XX) REF. DIMENSION 1K~2K ±6 120~400 ±0.2 >2K ±8 400~1000 ±0.3 FOR REF. ONLY Falcon APPROVED: INFORMATION CONTAINED ON THIS DRAWING IS CONFIDENTIAL AND MAY ALSO CONTAIN PROPRIETARY CARLISLE/CUSTOMER INFORMATION. DRAWING CONTENT IS ONLY INTENDED FOR USE OF THE ABOVE CUSTOMER IF YOU ARE NOT THE INTENDED RECIPIENT OR AUTHORIZED EMPLOYEE OF ABOVE COMPANY NAME, YOU ARE HEREBY NOTIFIED ANY USE, DUPLICATION, RECONSTRUCTION, OR DISTRIBUTION OF 2 RC-TUBG,HTSK,3/16,BLK N/A 0.4" ADHESIVE , 1/8 HST BLACK PART NUMBER DRAWING INFORMATION IS STRICTLY PROHIBITTED. 1.2" M23053/4-101-0 ITEM DRAWN: N/A TUBG,HTSK,ID=0.315”,ADHSV,BLK, TM7S-9MS-00 CHECKED: C-TUBG,HTSK,GPO,1/8,BL ATUM-8/2-0 2 1 ISO2768-F (mm) 30~120 3.92 1.35:1 6 ISO2768-V (mm) 30-120 120~400 3.21 1.35:1 KEY DIMENSION NEED 100% INSPECTION RoHS Compliant 1.79 1.35:1 NOTE(S): 1, SOLDER PER IPC J-STD-001, USING LEAD FREE SOLDER. 2, NOMINAL TOLERANCE REFR TO ISO2768-F. 3, CABLE LENGTH TOLERANCE REFER TO ISO2768-V, AND TOLERANCE VALUE MULTIPIED BY 2. 4, WORK ORDER LABEL NOT SHOWN WILL BE ATTACHED TO CABLE . A 1.32 1.35:1 B C DESCRIPTION INTERCONNECT TECHNOLOGIES PART NUMBER: TM7SMSTS9MS00XX SIZE A4 SCALE 2:1 0.7" N/A 2.92mm MALE FOR 078 CABLE MATERIAL: N/A .5" N/A SEE TABLE N/A QTY N/A 1 1 MATERIAL Dongguan City,Guangdong P.R. China 523533 PROJECT NAME: PART NAME: B ASSY, 078, SSMP ST(F) - 2.92(M), XXcm, 2ps CABLE ASSEMBLY DO NOT SCALE DRAWING 1 REVISION: DATA: A 30.Jun.20 SHEET 1 OF 1 A
TM7SMSTS9MS031C 价格&库存
很抱歉,暂时无法提供与“TM7SMSTS9MS031C”相匹配的价格&库存,您可以联系我们找货
