3
4
2
1
REVISIONS
.684
17.38
.180
4.57
.421
10.69
D
.276
7.00
.110
2.79
.250
6.35
A
.531
13.50
REV.
DESCRIPTION
DATE
APPROVED
INITIL RELEASE
07/03/2018
MM
1
UPDATED PART NUMBER
10/24/2018
DL
2
ADDED SHEET 2 PCB DEFINITION
2/20/2019
PV
3
ADDED SECTION VIEW
3/7/2019
PV
4
ADDED SHEET 3
3/19/2019
PV
5
REVISED MODEL
11/19/2019
PV
D
.375
9.53
A
M7.00x0.75P-6g
.094
2.40
.001
0.03
.115
2.93
C
C
.531
13.50
.025
0.64
.110
2.80
#1-72 UNF-2A
.010
0.25
.039
1.00
.012
0.31
.250
6.35
#1-72 UNF-2B
.065
1.65
.208
5.28
.033
0.85
SCREW
.002
0.06
.014
0.35
.0070±.0004
0.178±0.010
.028
0.71
LOCKING BLOCK
B
NOTE(S):
1. These characteristics are typical and for reference.
2. DYH: 60-20009-44070
3. See sheets 2 and 3 for PCB definition.
SECTION A-A
SCALE 20 : 1
MATERIAL(S):
ELECTRICAL(S):
MECHANICAL(S):
ENVIRONMENTAL(S):
Body:
Stainless Steel
Center Conductor:
Beryllium Copper
Insulator:
Insulator 1: PCTFE, white
Insulator 2: PTFE, white
RoHS Compliant
Protective Cap:
Soft PVC
Color: Blue
Impedence: 50 Ohms Nominal
Frequency Range: DC to 50 GHz
VSWR: 1.3:1 max at 50 GHz
Working Voltage: 400 Vrms max @ Sea Level
Dielectric Withstand Voltage: 500 Vrms max.
Insulation Resistance: 5000 Megaohms min.
Contact Resistance:
Initial:
Center Contact: 1.5 Milliohms max
Outer Contact: 0.8 Milliohms max
Mating Characteristics:
Interface per MIL-STD-348
Force to Engage & Disengage:
Torque: 2 inch-pounds max
Longitudinal Force: NA
Connector Durability:
500 Cycles min.
Permeability: Less than 2.0 mu.
Center Contact Retention:
Axial Force: 6 pounds min.
Radial Force: NA
Temperature Range: -65 C to +165 C
Moisture Resistance:
MIL-STD-202, Method 103, Test Condition B
Corrosion:
MIL-STD-202, Method 101, Test Condition B
Vibration:
MIL-STD-202, Method 204, Test Condition A
Shock:
MIL-STD-202, Method 213, Test Condition 1
APPLICABLE CARLISLE IT DOCUMENTS TOLERANCES AND NOTES APPROVAL INITIALS DATE
EXCEPT AS NOTED
DRAWN
ASSY INSTRUC
PROD INSTRUC
MM 07.03.18
BY
NA
NA
NA
THIRD ANGLE
PROJECTION
CHECKED
KM 07.03.18
BY
SCALE 5:1
N O T I C E
FINISH(ES):
A
B
PROTECTION CAP
WORK STANDARD
Body:
Passivated
Center Conductor:
Gold Plating
ENG-SW REV. E
THIS DRAWING EMBODIES A CONFIDENTIAL PROPRIETARY DESIGN
ORIGINATED BY CARLISLE INTERCONNECT TECHNOLOGIES & ALL
DESIGN, MANUFACTURING, REPRODUCTION, USE & SALE RIGHTS
REGARDING THE SAME ARE EXPRESSLY RESERVED. IT IS SUBMITTED
UNDER A CONFIDENTIAL RELATIONSHIP FOR A SPECIFIED
PURPOSE & THE RECIPIENT AGREES BY ACCEPTING THIS DRAWING
NOT SUPPLY OR DISCLOSE ANY INFORMATION REGARDING IT TO
ANY UNAUTHORIZED PERSON TO INCORPORATE IN OTHER PROJECTS ANY
SPECIAL FEATURES PECULIAR TO THIS DESIGN. ALL PATENT RIGHTS
HERETO ARE EXPRESSLY RESERVED BY CARLISLE
INTERCONNECT TECHNOLOGIES, CERRITOS, CALIFORNIA 90703.
4
3
DIMENSIONS ARE IN [INCHES]
MM
ANGLES 2
.XX DECIMALS
.063
.XXX DECIMALS
.01
2
Dongguan City, Guangdong P.R. China 523533
TITLE
DESIGN
ENG
SCALE
APPR BY
SIZE
2.40mm STRAIGHT JACK, EDGE
MOUNT (SOLDERLESS)
5:1
C
SUB-DIRECTORY/
_OUTLINE/
DRAWING NO.
SHEET
TMB-E4F2-1L1
1
1
OF
3
REV.
5
A
3
4
.117
2.98
2
1
.117
2.98
.010
0.25 (REF)
MAY BE LOCATED
CLOSER TO EDGE
.059
1.50
D
.008
0.20
TYP
.059
1.50
.022
0.55
.015
0.38
DETAIL B
.375
9.53
DETAIL C
SCALE 20 : 1
.079
2X 1.99
THRU UNPLATED
B
.110
2.79
.180
4.57
.008
0.20
.032
0.82
SCALE 20 : 1
.079
2X 1.99
THRU UNPLATED
D
.018
0.46
TYP
.018
0.46
TYP
.032
0.82
C
.010
0.25 (REF)
MAY BE LOCATED
CLOSER TO EDGE
.375
9.53
C
C
.110
2.79
.180
4.57
B
.539
13.68
CONNECTOR
OUTLINE
.020
0.50
.539
13.68
CONNECTOR
OUTLINE
.021
0.53
.020
0.50
PIN
.011
0.27
B
PIN
BODY
BODY
LAYER 1: Cu
(0.036mm [1.4mil])
LAYER 1: Cu
(0.036mm [1.4mil])
DIELECTRIC
LAYER 2: SUBSTRATE
(0.203mm [8.0mil] THICK)
DIELECTRIC
LAYER 2: SUBSTRATE
(0.457mm [18.0mil])
PCB (REF)
PCB (REF)
A
PCB LAYOUT OPTION 1
PCB LAYOUT
Standard board stackup
(Reference)
0.457mm [18.0mil] THICK SUBSTRATE (LAYER 2)
ENG-SW REV. E
4
A
PCB LAYOUT OPTION 2
3
0.203mm [8.0mil] THICK SUBSTRATE (LAYER 2)
SCALE
10:1
SUB-DIRECTORY/
SHEET
SIZE CAGE CODE DRAWING NO.
C
2
TMB-E4F2-1L1
1
2
OF
3
REV.
5
3
4
.052
1.32
.010
0.25
TYP
D
2
.010
0.25 (REF)
MAY BE LOCATED
CLOSER TO EDGE
F
E
E
.012
0.31
.020
0.50
PIN
F
.0146
0.371
PCB (REF)
SECTION F-F
PIN
.0250
0.635
.0157
0.399
DIELECTRIC
SCALE 25:1
PCB (REF)
SECTION J-J
.0250
0.635
LAYER 3 (Cu)
ROTATED 90 CCW
Interface to connector
LAYER 1: Cu (0.030mm [1.2mil])
LAYER 2: SUBSTRATE (0.076mm [3.0mil])
LAYER 3: Cu (0.018mm [0.7mil])
LAYER 4: SUBSTRATE (0.152mm [6.0mil])
ROTATED 90 CCW
PCB 9mil Option
C
.010
0.25 (REF)
MAY BE LOCATED
CLOSER TO EDGE
J
H
0.246mm [9.7mil] Dielectric
SUBSTRATE LAYERS 2 AND 4
.079
2X 1.99
THRU UNPLATED
.052
1.32
.010
0.25
TYP
SECTION E-E
H
.018
0.46
TYP
See Detail D for 9mil option
See Detail G for 15mil option
J
B
.180
4.57
D
BODY
DETAIL D
.0097
0.246
DIELECTRIC
.018
0.46
.020
0.50
.018
0.46
TYP
BODY
C
1
.0195
0.495
.110
2.79
.0299
0.759
B
DETAIL G
SCALE 25:1
.0300
0.762
LAYER 3 (Cu)
LAYER 4: SUBSTRATE (0.305mm [12.0mil])
CONNECTOR
OUTLINE
.375
9.53
SECTION H-H
.539
13.68
A
PCB 15mil Option
MOUNTING PATTERN
PCB LAYOUT
Non-standard board stackup
(Reference)
ENG-SW REV. E
4
3
A
0.399mm [15.7mil] Dielectric
SCALE
10:1
SUB-DIRECTORY/
SHEET
C
2
TMB-E4F2-1L1
1
3
OF
3
REV.
5
很抱歉,暂时无法提供与“TMB-E4F2-1L1”相匹配的价格&库存,您可以联系我们找货
