3
4
2
1
REVISIONS
.691
17.56
.187
4.75
TYP
.421
10.69
D
[.040]
1.02 TYP
.040
1.02
TYP
.230
5.84
.094
2.40
DATE
APPROVED
INITIAL RELEASE
07/24/2018
MM
1
UPDATED PART NUMBER
10/24/2018
DL
2
ADDED SHEET 2 PCB DEFINITION
2/20/2019
PV
3
ADDED SECTION VIEW
3/12/2019
PV
D
[.068]
1.73
TYP
[.375]
9.52
.028
0.71
.004
0.10
C
[.154]
3.90 TYP
SEE DETAIL A
DESCRIPTION
.003
0.07
[.312]
7.92
M7.00 X 0.75P-6g
REV.
C
.039
1.00
.0070±.0004
0.178±0.010
.012
0.31
.016
0.41
.014
0.35
B
NOTE(S):
1. These characteristics are typical and for reference.
2. DYH: 60-20012-12070
3. See sheet 2 for PCB interface definition.
DETAIL A
SCALE 20:1
MATERIAL(S):
ELECTRICAL(S):
MECHANICAL(S):
ENVIRONMENTAL(S):
Body:
Brass
Center Conductor:
Beryllium Copper
Insulator:
Insulator 1: PCTFE, white
Insulator 2: PTFE, white
RoHS Compliant
Protective Cap:
Soft PVC
Color: Blue
Impedence: 50 Ohms Nominal
Frequency Range: DC to 50 GHz
VSWR: 1.3:1 max at 50 GHz
Working Voltage: 400 Vrms max @ Sea Level
Dielectric Withstand Voltage: 500 Vrms max.
Insulation Resistance: 5000 Megaohms min.
Contact Resistance:
Initial:
Center Contact: 1.5 Milliohms max
Outer Contact: 0.8 Milliohms max
Mating Characteristics:
Interface per MIL-STD-348
Force to Engage & Disengage:
Torque: 2 inch-pounds max
Longitudinal Force: NA
Connector Durability:
500 Cycles min.
Permeability: Less than 2.0 mu.
Center Contact Retention:
Axial Force: 6 pounds min.
Radial Force: NA
Temperature Range: -65 C to +165 C
Moisture Resistance:
MIL-STD-202, Method 103, Test Condition B
Corrosion:
MIL-STD-202, Method 101, Test Condition B
Vibration:
MIL-STD-202, Method 204, Test Condition A
Shock:
MIL-STD-202, Method 213, Test Condition 1
APPROVAL INITIALS DATE
APPLICABLE CARLISLE IT DOCUMENTS TOLERANCES AND NOTES
EXCEPT AS NOTED
DRAWN
MM 07.24.18
ASSY INSTRUC
WORK STANDARD PROD INSTRUC
BY
NA
NA
NA
THIRD ANGLE
PROJECTION
CHECKED
KM 07.24.18
BY
SCALE 8:1
N O T I C E
FINISH(ES):
A
B
PROTECTION CAP
Body:
Gold Plating
Center Conductor:
Gold Plating
ENG-SW REV. E
THIS DRAWING EMBODIES A CONFIDENTIAL PROPRIETARY DESIGN
ORIGINATED BY CARLISLE INTERCONNECT TECHNOLOGIES & ALL
DESIGN, MANUFACTURING, REPRODUCTION, USE & SALE RIGHTS
REGARDING THE SAME ARE EXPRESSLY RESERVED. IT IS SUBMITTED
UNDER A CONFIDENTIAL RELATIONSHIP FOR A SPECIFIED
PURPOSE & THE RECIPIENT AGREES BY ACCEPTING THIS DRAWING
NOT SUPPLY OR DISCLOSE ANY INFORMATION REGARDING IT TO
ANY UNAUTHORIZED PERSON TO INCORPORATE IN OTHER PROJECTS ANY
SPECIAL FEATURES PECULIAR TO THIS DESIGN. ALL PATENT RIGHTS
HERETO ARE EXPRESSLY RESERVED BY CARLISLE
INTERCONNECT TECHNOLOGIES, CERRITOS, CALIFORNIA 90703.
4
3
Dongguan City, Guangdong P.R. China 523533
TITLE
DIMENSIONS ARE IN [INCHES]
MM
ANGLES 2
DESIGN
ENG
SCALE
.XX DECIMALS
.063
.XXX DECIMALS
.01
APPR BY
SIZE
2
2.40mm STRAIGHT JACK, EDGE
MOUNT (MANUAL SOLDER)
8:1
C
SUB-DIRECTORY/
_OUTLINE/
DRAWING NO.
SHEET
TMB-E4FS-1S1
1
1
OF
2
REV.
3
A
4
3
2
1
SUBSTRATE EDGE
.117
2.98
D
.020
0.50
.010
0.25 (REF)
MAY BE LOCATED
CLOSER TO EDGE
.059
1.50
.008
0.20
TYP
.020
0.50
.047
1.20
.028
0.70
.059
1.50
.018
0.46
TYP
.117
2.98
.193
4.90
.335
8.50
.032
0.82
SOLDER PASTE STENCIL
SCALE 6:1
.022
0.55
.018
0.46
TYP
.008
0.20
TYP
.063
1.60
.032
0.82
DETAIL B
C
.015
0.38
DETAIL C
SCALE 20 : 1
C
SCALE 20 : 1
B
C
.244
6.20
B
D
.010
0.25 (REF)
MAY BE LOCATED
CLOSER TO EDGE
.059
1.50
.244
6.20
CONNECTOR
KEEPOUT
CONNECTOR
KEEPOUT
.404
10.25
.020
0.50
BODY
.022
0.56
.404
10.25
.020
0.50
BODY
PIN
B
.012
0.31
PIN
LAYER 1: Cu
(0.036mm [1.4mil])
LAYER 1: Cu
(0.036mm [1.4mil])
PCB (REF)
PCB (REF)
A
LAYER 2: SUBSTRATE
(0.203mm [8.0mil])
DIELECTRIC
LAYER 2: SUBSTRATE
(0.457mm [18.0mil])
DIELECTRIC
A
PCB LAYOUT OPTION 2
0.203mm [8.0mil] THICK SUBSTRATE (LAYER 2)
PCB LAYOUT OPTION 1
PCB LAYOUT
(FOR REFERENCE ONLY)
0.457mm [18.0mil] THICK SUBSTRATE (LAYER 2)
SCALE
8:1
4
3
_XXXX\
SHEET
SIZE CAGE CODE DRAWING NO.
C
ENG-SW REV. E
SUB-DIRECTORY/
2
TMB-E4FS-1S1
1
2
OF
2
REV.
3
很抱歉,暂时无法提供与“TMB-E4FS-1S1”相匹配的价格&库存,您可以联系我们找货
