PML50RBFVW
PML50RBFVW
    VCC
    LED 面板指示器 蓝色,红色 5V ~ 28V 20mA 引线 - 5.5"(139.70mm)
PML50RBFVW 数据手册
PML50 Series 0.688” (17.5mm) Harsh Environment LED FlexVolt™ Panel Mount Indicator PML50 Series with built-in LED FlexVolt™ technology Application • Industrial • Transportation • High Humidity, Sunlight and/or rain-expose conditions • Maritime, Oil and Gas Industry • Automation and Control • High Vibration • Safety and Emergency • Pilot Instrumentation • Outdoor Applications Key Features • • • • • • • • • • • • • • • • • • • • For panel hole diameter: 0.688” (17.5mm) Low profile flat and semi dome lens options for uniform illumination Flat lens with a clear diffused lens for increased contrast visibility between on and off Semi dome lens with a white diffused lens for optimal side distance viewing Increase productivity w/color coded wiring Single colors options: Red, Green, White, Blue and Yellow Bi-color options: Red/Green, Red/Blue, Yellow/Green, Yellow/Blue and Red//Yellow Offered with two lens options: Low Profile Flat and Semi Dome Resistant to shock and vibration Flex voltage (5 VDC to 28 VDC) designed for application flexibility: one solution for several required input voltages Wide viewing angle Mounting hardware provided: lock washer and hex nut “Double D” mounting hole prevents any rotation of the indicator while the nut is being installed IP67 specification rating protects front panels against entry of dust, rain and moisture InGaN and AllnGaP Technology Visible LED in direct sunlight with UV resistance lens Long lifetime, up to 100k hours Does not require an external resistor to work For custom cable length, connectors or colors contact VCC RoHS and REACH Compliant vcclite.com | 1.800.522.5546 PML50 | 11/22 Rev 6 | Page 1 of 6 Ordering Data PML50 PML50 - Semi Dome Example: PML50RFVW Example: PML50SWFVW PML50 Series, Red Color, 5 VDC to 28 VDC PML50 Series, White Color, 5 VDC to 28 VDC, Semi Dome Lens Part Number Color Lens Terminal Voltage Luminance (mcd) PML50RFVW Red Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 950 PML50WFVW White Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 2980 PML50GFVW Green Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 3640 PML50BFVW Blue Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 270 PML50YFVW Yellow Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 2020 PML50SRFVW Red Semi Dome 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 780 PML50SWFVW White Semi Dome 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 1090 PML50SGFVW Green Semi Dome 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 1770 PML50SBFVW Blue Semi Dome 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 200 PML50SYFVW Yellow Semi Dome 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 970 PML50 - Bi-Color Example: PML50YGFVW PML50 Series, Yellow/Green Bi-Color, 5 VDC to 28 VDC Part Number Color Lens Terminal Voltage Luminance (mcd) PML50RGFVW Red/Green Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 1130/2380 PML50RBFVW Red/Blue Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 870/2373 PML50YGFVW Yellow/Green Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 1087/762 PML50YBFVW Yellow/Blue Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 762/2373 PML50RYFVW Red/Yellow Flat 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 870/394 PML50SRGFVW Red/Green Semi Dome 24 AWG 5.5” color-coded wire leads 5 VDC to 28 VDC 520/1370 Notes: Test Parameters: Voltage at 24VDC and Temperature at 25℃ or 77℉ vcclite.com | 1.800.522.5546 PML50 | 11/22 Rev 6 | Page 2 of 6 Product Dimensions Semi Dome Lens Flat Lens Recommended Mounting Hole D Mounting Hole Notes: 1. All dimensions are in inches [millimeters] 2. Tolerance is ±[0.25] 0.01 unless otherwise noted. 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. vcclite.com | 1.800.522.5546 PML50 | 11/22 Rev 6 | Page 3 of 6 Product Dimensions Semi Dome Lens 21. 4 .8 4 17. 2 .6 7 12.5 MA X .49 MA X 29.5±3 1.16±.12 11/16" - 27NS 16 .6 3 +25.4 14 0 -0 .0 +1. 0 5. 5 - 0.0 (+) RE D (-) BLAC K (+) RE D (+) GREEN BLACK (- ) 16.8 .6 6 8. 1 .3 2 12. 7 .5 0 BI-COLOR (3-LEAD WIRE) Notes: 1. All dimensions are in inches [millimeters] 2. Tolerance is ±[0.25] 0.01 unless otherwise noted. 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. vcclite.com | 1.800.522.5546 PML50 | 11/22 Rev 6 | Page 4 of 6 Product Dimensions Flat Lens 19.8 ±0.4 .78± .015 29.8 1.17 17.8 .7 0 6. 3 .248 MA X 9. 3 .3 7 11/16" - 27NS 16 .6 3 (+) RE D (-) BLAC K (+) (+) red or yellow +25.4 140 -. 0 +1. 0 5. 5 - .0 12.7 .5 0 green or blue BLACK (- ) BI-COLOR (3-LEAD WIRE) 8. 1 .3 2 16.8 .6 6 Mounting Hardware (Included for flat and semi dome lenses) 19.8 .7 8 1 .0 4 24.5 .9 6 Washer: EPDM Lock Washer: SPCC Nickel Plated 20.5 .8 1 2. 4 .0 9 Hex Nut: Brass Nickel Plated Notes: 1. All dimensions are in inches [millimeters] 2. Tolerance is ±[0.25] 0.01 unless otherwise noted. 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. vcclite.com | 1.800.522.5546 PML50 | 11/22 Rev 6 | Page 5 of 6 Product Specifications Compliances and Approvals vcclite.com | 1.800.522.5546 PML50 | 11/22 Rev 6 | Page 6 of 6
PML50RBFVW 价格&库存
很抱歉,暂时无法提供与“PML50RBFVW”相匹配的价格&库存,您可以联系我们找货
