120MBL-O-CA
120MBL-O-CA
    VCC
    LED REPLAC. T-3 1/4 BAYONET AMBE
120MBL-O-CA 数据手册
PowerLine LEDs SOLID STATE ALTERNATIVES TO INCANDESCENT BULBS FOR INDUSTRIAL PLANTS AND UTILITIES Available on-line at www.powerlineleds.com PowerLine LEDs Since 1970, DDP has pioneered the development of LED lamps as replacements for incandescent bulbs. The advantages that solid-state LEDs offer are particularly suitable for the utility industry where numerous lamps provide critical indication in control panels. Burned-out incandescent bulbs require costly maintenance and may create safety concerns. Replacing incandescent bulbs with PowerLine® LED lamps will provide many years of maintenance-free operation. This catalog represents our products designed specifically for the unique needs of the power generation, transmission and distribution industries. We offer a comprehensive product line to provide direct replacement of almost any indicator lamp being used without modification to existing equipment. Since many stations have unique requirements, DDP engineers have also developed many modified versions of our standard LED lamps. INTRODUCTION INTRODUCTION If you don't find the lamp you need in this catalog, please call our technical support number: (800) 421-6815 or e-mail: techsupport@datadisplay.com www.powerlineleds.com Our applications engineers are available for technical assistance and to provide samples for evaluation. We look forward to working with you. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP I PowerLine LEDs TABLE OF CONTENTS Page Application Notes...........................................................................................1-3 Ordering Information............................................................................................4 TABLE OF CONTENTS Lamp Cross-Reference........................................................................................5 T-1 3⁄4 Sub-Miniature Lamps..................................................................................6 • Flange Base • Groove Base • Wedge Base T-2 Slide Based Lamps..................................................................................... 7 • Slide Base #3 • Slide Base #5 T-2 120 Volt Lamps................................................................................................8 • 120PC Replacement • 120PSB Replacement 24E / 24X Replacement Lamps and Lenses................................................9-10 • For GE ET-5, ET-6 and Westinghouse Minalite Sockets www.powerlineleds.com 1835 and 1819 Replacement Lamps and Lenses ....................................11-12 • For GE ET-16 Socket II 16mm Pilot Light and LED Lamp.......................................................................13 T- 3 1⁄4 Bayonet Based Lamps.............................................................................14 S-6 Lamps...........................................................................................................15 • Screw Base • Double Contact Bayonet Base Custom LED Annunciator Retrofit Lamps.......................................................16 Limited Warranty.................................................................................................17 www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP PowerLine LEDs APPLICATION NOTES Average Life Failure Mode Lifetime affected by on/off operation Resistant to shock and vibration Operating temperature Power consumption Susceptible to cold filament inrush current PowerLine® LED Lamp Up to 100,000 hours Predictable No Yes Low Low No Incandescent Bulb 2,000 hours Unpredictable Yes No High High Yes The primary benefit of PowerLine® LED technology is the tremendous cost savings for the user by eliminating replacement costs, lowering power consumption, and reducing operating temperatures. Long Life The most compelling advantage of using PowerLine® LED lamps is a predictable life. LEDs are solid-state devices and, by definition, control current without heated filaments. When used within its design parameters, a PowerLine® LED lamp will operate upwards of 100,000 hours (or 10 years). Furthermore, LED lifetime is not shortened by turning the lamp on and off. APPLICATION NOTES PowerLine® LED lamps are designed as drop-in replacements and offer several advantages over incandescent bulbs. Incandescent Bulb catastrophic failure after 2,000 hours of operation *Bulb life varies based on shock, vibration and number of on/off cycles LIFE (HOURS) The life of an incandescent bulb is unpredictable - subject to catastrophic failure due to shock, vibration, or cold filament inrush current. Initial powering of a control panel with numerous incandescent bulbs will generally result in several failures. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP www.powerlineleds.com LIGHT OUTPUT Led Lamp Gradual degradation over 100,000 hours of operation 1 PowerLine LEDs APPLICATION NOTES Cooler Operating Temperatures APPLICATION NOTES Since incandescent bulbs generate light by heating a filament, they also heat the lenses they illuminate. This causes discoloration and eventual melting of the control panel lenses. PowerLine® LED lamps generate much less heat than the incandescent bulbs they replace. Furthermore, heat is dissipated through the base of the LED lamp, keeping the lens cooler. DDP LED INCANDESCENT Heat Dissipation Comparison With the extended use of incandescent bulbs, lens melting and discoloration is very common. We offer replacement lenses for many industry-standard sockets. Please refer to page 10. Power Consumption LEDs generally draw much lower current than incandescent bulbs. www.powerlineleds.com Incandescent Bulb 2 PowerLine® LED Lamp 6S6/120V 50mA 6S6L120-CWX 11mA 120PSB 25mA 120PSBL-NWX 5.8mA 387 40mA 387LP-X 16mA 1819 40mA 1819L-X-CX 17mA While lower power consumption reduces operating costs, it also reduces wear on other components in the circuit such as transformers, batteries and power converters. Cold Filament Inrush When cold, an incandescent filament draws ten times as much current as it does during normal operation. The initial powering of hundreds of incandescent bulbs simultaneously causes significant voltage surges that lead to lamp failures. PowerLine® LED lamps are designed with series resistors to limit the operating current, resulting in no cold filament current variation. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP PowerLine LEDs APPLICATION NOTES Shunt Resistor Cost Savings Based on an average incandescent bulb life of three months, converting to PowerLine® LEDs will pay for itself in material costs alone within the first year. This payback period takes into account only the cost of the incandescent bulb. It does not take into account the labor cost associated with changing bulbs, power savings, operating downtime, incandescent bulb inventory and ordering costs, and other significant factors. The following graph depicts the average cost of replacing a $3.25 1835 incandescent bulb in one socket four times a year. The cost of the bi-polar 1835LS2 is fixed at $11.00 for ten years. For a facility with only 1,000 lamps, the material savings alone would be approximately $2,000 after the first year! APPLICATION NOTES Residual current as low as .25mA may cause the LED to illuminate dimly in the off state, PowerLine® LEDs are designed with a built-in shunt resistor to bleed-off transient current. There are several sources of leakage current in a circuit. Transient voltage from a relay or discharge from a capacitor creates circuit noise. Also, inherent in the design of some programmable logic controllers (PLCs), is a triac protective circuit that may supply up to 5mA of leakage current in the off state. $90 $70 1835 Incandescent Bulb Unit Price $3.25 (avg) Annual Replacements: 4 $60 $50 $40 $30 1835LS2 LED Lamp Unit Price $11.00 each Annual Replacements: 0 10.15 Months Payback $20 $10 $0 0 1 2 3 4 5 6 7 8 9 10 Years www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP www.powerlineleds.com Annual lamp cost per socket $80 3 PowerLine LEDs ORDERING INFORMATION Free Samples To evaluate PowerLine® LED lamps in your application, we will send free samples of any product. ORDERING INFORMATION Ordering Information 1. Model Number - Locate the incandescent bulb number you are replacing and the corresponding PowerLine® LED lamp number in the Lamp Cross-Reference on page 5. For example: INCANDESCENT LAMP # PowerLine® LED PART # PAGE # 1835LS2-X-CX 1835LS3-X-CX 1835 11 2. Voltage - Verify your operating voltage and series resistor (if applicable) to select the appropriate cross. For example: INPUT VOLTAGE SERIES RESISTOR 48DC PowerLine® LED PART # MAXIMUM VOLTAGE 200 Ω 56 1835LS2-X-CX 3. Color - Select the LED color to match the color of your lens. There are no “clear” LED lamps. www.powerlineleds.com White LED lamps will generally not work as a universal replacement behind colored lenses. 4 LED COLOR CODE EMITTED COLOR -R-CR -A-CA -G-CG -B-CB -W-CW Red Amber Green Blue White Used to illuminate the following lenses Red Amber Yellow Green Blue White Clear * * * * * * * * * * * * * * * * 4. Request Samples - Phone, fax, or e-mail us the part number and we will provide a free sample for your evaluation. The PowerLine® LED part number in the example above is 1835LS2-R-CR. If you have any questions, please call DDP at (800) 421-6815 or e-mail techsupport@datadisplay.com. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP PowerLine LEDs PowerLine® LED PART # INCANDESCENT LAMP # PowerLine® LED PART # 3S6/120V 6S6LS120-CWX 15 755 47LS-X-CX 14 6S6/120V 6S6LS120-CWX 15 757 1819LS-X-CX 14 6S6DC/120V 6S6DCLS120-CWX 15 1815 1815LS-X-CX 14 6S6/130V 6S6LS130-CWX 15 1819LS-X-CX 14 1819LS2-X-CX 11 PAGE # 1819 PAGE # 6S6DC/130V 6S6DCLS130-CWX 15 6S6/155V 6S6LS155-CWX 15 1820 1819LS-X-CX 14 6PSB 6PSBLS-X1 7 1829 1819LS-X-CX 14 24E / 24X 24LS Series 9 1835 1835LS Series 11 24PSB 24PSBLS-X1 7 1843 1819LS-X-CX 14 28PSB 28PSBLS-X1 7 1847 47LS-X-CX 14 28MB 1819LS-X-CX 14 1866 47LS-X-CX 14 44 47LS-X-CX 14 7341 387LP-X 6 47 47LS-X-CX 14 48PSB 48PSBLS-X1 7 48X 48LS4-X1 7 55C2 55CLS2-X1 7 85 85LS-X1 6 86 86LS-X1 6 120MB 120MBLS-X-CX 14 120PC 120PCLS-NWX 8 120PSB 120PSBLS-NWX 8 327 387LP-X 6 330 382LP-X 6 345 345LP-X 6 350 350LP-X 6 370 370LP-X 6 376 387LP-X 6 382 382LP-X 6 385 387LP-X 6 386 386LP-X 6 387 387LP-X 6 388 388LP-X 6 394 394LP-X 6 www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP LAMP CROSS-REFERENCE INCANDESCENT LAMP # www.powerlineleds.com LAMP CROSS-REFERENCE 5 www.powerlineleds.com T-13⁄4 MINIATURE LAMPS PowerLine LEDs 6 T-13⁄4 MINIATURE LAMPS INCANDESCENT LAMP # PowerLine® PART # WITH SHUNT RESISTOR APPLIED VOLTAGE MAXIMUM VOLTAGE FIG # 85 86 327 330 345 350 370 376 382 385 386 387 388 394 7341 85LS-X1 86LS-X1 387LP-X 382LP-X 345LP-X 350LP-X 370LP-X 387LP-X 382LP-X 387LP-X 386LP-X 387LP-X 388LP-X 394LP-X 387LP-X 28AC/DC 6AC/DC 28AC/DC 14AC/DC 6AC/DC 6AC/DC 18AC/DC 28AC/DC 14AC/DC 28AC/DC 14AC/DC 28AC/DC 28AC/DC 12AC/DC 28AC/DC 30 7 30 15.5 7 7 20 30 15.5 30 16 30 30 13 30 3 3 1 1 1 1 1 1 1 1 2 1 2 1 1 LED COLOR CODE EMITTED COLOR -R -A -G -B -W Red Amber Green Blue White Flange Base Figure 1 Used to illuminate the following lenses Red Amber Yellow Green Blue White Clear * * * * * * * * * * * * * * * Groove Base Figure 2 Wedge Base Figure 3 All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP INCANDESCENT LAMP # PowerLine® PART # STANDARD PowerLine® PART # WITH SHUNT RESISTOR APPLIED VOLTAGE MAXIMUM VOLTAGE BI-POLAR FIG # 6PSB 6PSBL-X1 6PSBLS-X1 6AC/DC 7  1 24PSB 24PSBL-X1 24PSBLS-X1 24AC/DC 26  1 28PSB 28PSBL-X1 28PSBLS-X1 28AC/DC 30  1 48PSB 48PSBL-X1 48PSBLS-X1 48AC/DC 52  1 48X 48L2-X1 48LS2-X1 48DC 52 48L4-X1 48LS4-X1 48AC/DC 52  2 55CL2-X1 55CLS2-X1 55AC/DC 60  2 LED COLOR CODE EMITTED COLOR -R1 -O1 -A1 -G1 -B1 -W1 Red Orange Amber Green Blue White Figure 1 Slide Base #5 Used to illuminate the following lenses Red Orange Amber Yellow Green Blue * * * * * * * White Clear * * * * * * * * * * * * Figure 2 Slide Base #3 www.powerlineleds.com 55C2 2 T-2 SLIDE BASED LAMPS PowerLine LEDs T-2 SLIDE BASED LAMPS All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP 7 www.powerlineleds.com T-2 120 VOLT LAMPS PowerLine LEDs 8 T-2 120 VOLT LAMPS INCANDESCENT LAMP # PowerLine® PART # STANDARD PowerLine® PART # WITH SHUNT RESISTOR APPLIED VOLTAGE MAXIMUM VOLTAGE FIG # 120PC 120PCL-NWX 120PCLS-NWX 120AC/DC 130 1 120PSB 120PSBL-NWX 120PSBLS-NWX 120AC/DC 130 2 LED COLOR CODE EMITTED COLOR -NWR -NWO -NWA -NWG -NWB -NWW Red Orange Amber Green Blue White Used to illuminate the following lenses Red Orange Amber Yellow Green Blue White Clear * * * * * * * * * * * * * * * * * * * 120PCL Figure 1 120PSBL Figure 2 All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP The PowerLine® 24LS series LED lamps are designed as drop-in replacements for the industry-standard 24E and 24X incandescent bulbs. Several models are available designed specifically for operation in GE ET-5, ET-6 and Westinghouse Minalite sockets. No modification to input voltage or series resistance is required. ET-5 socket not included To select a PowerLine® LED lamp: 1. Identify your input voltage and series resistor from the chart below. Series resistor values are usually marked on the socket. 2. Select the appropriate PowerLine® LED part number. 3. Replace “X1” in the part number with the color code (see LED color code chart below) INPUT VOLTAGE SERIES RESISTOR MAXIMUM PowerLine® LED VOLTAGE PART # BI-POLAR 130AC/DC 48DC 3.2KΩ 900Ω 140 56 24LS4-X1 YES 130DC 24DC 48DC 600DC 3.2KΩ 110Ω 900Ω 20KΩ 140 26 56 650 24LS2-X1 NO 130DC 2KΩ 140 24LS8-X1 YES 67AC 115AC 230AC 250AC 460AC 575AC 1.5KΩ 2.8KΩ 6.3KΩ 7.2KΩ 13KΩ 17KΩ 75 125 250 280 500 630 24LS10-X1 YES 125DC 250DC Dim/Bright 140 280 24LS12-X1 YES 115AC 230AC Dim/Bright 125 250 24LS16-X1 YES LED COLOR CODE EMITTED COLOR -R1 -O1 -A1 -G1 -B1 -W1 Red Orange Amber Green Blue White 24LS Series Slide Base #3 Used to illuminate the following lenses Red Orange Amber Yellow Green Blue * * * * * * * White Clear * * * * * * * * * * * * www.powerlineleds.com • Replaces 24E and 24X incandescent bulbs • For GE ET-5, ET-6 and Westinghouse Minalite Socket • Built-in shunt resistor to clamp noise current • Bi-polar (optional) • High-intensity • Up to 100,000-hour life • Shock and vibration resistant T-2 SLIDE BASED LAMPS 24LS SERIES PowerLine LEDs T-2 SLIDE BASED LAMPS 24LS SERIES All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP 9 PowerLine LEDs REPLACEMENT LENSES REPLACEMENT LENSES - GE ET-5 - GE ET-6 - Westinghouse Minalite SOCKET MODEL NUMBER PowerLine® LENS PART # DIFFUSION COLOR FIG# BB3-CR Clear Red 1 BB3-CA Clear Amber 1 BB3-CY Clear Yellow 1 BB3-CG Clear Green 1 BB3-CB Clear Blue 1 GE ET-5 & ET-6 BB3-CW Westinghouse Minalite Water Clear Translucent White 1 BB2-CR Clear Red 2 BB2-CA Clear Amber 2 BB2-CG Clear Green 2 BB2-CW www.powerlineleds.com BB2-NW 10 BB3 Figure 1 1 BB3-NW Water Clear Translucent 2 White 2 BB2 Figure 2 All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP The PowerLine® 1835LS and 1819LS2 series LED lamps are designed specifically for the GE ET-16 socket. Several models are available to operate with industry-standard voltages and series resistor combinations. ET-16 socket not included To select a PowerLine® LED lamp: 1. Identify your input voltage and series resistor from the chart below. Series resistor values are usually marked on the ceramic case at the back of the socket. 2. Select the appropriate PowerLine® LED part number. 3. Replace “X-CX” in the part number with the color code (see LED color code chart below). INPUT VOLTAGE SERIES RESISTOR MAXIMUM VOLTAGE PowerLine® LED PART # 24DC 10Ω 28 1819LS2-X-CX 48DC 200Ω 56 1835LS2-X-CX 100-140DC 250DC 70AC 120AC 125AC 240AC 2KΩ 5.1KΩ 750Ω 1.9KΩ 2.7KΩ 4.8KΩ 140 280 76 130 140 260 1835LS3-X-CX 100-140DC 5.1KΩ 140 1835LS9-X-CX 125DC Dim/Bright 140 1835LS4-X-CX 48DC Dim/Bright 52 1835LS6-X-CX LED COLOR CODE EMITTED COLOR -R-CR -A-CA -G-CG -B-CB -W-CW Red Amber Green Blue White 1835LS/1819LS2 Series for GE ET-16 Used to illuminate the following lenses Red Amber Yellow Green Blue * * * * * White Clear * * * * * * * * * * www.powerlineleds.com • Replaces 1835 and 1819 incandescent bulbs • For GE ET-16 Socket • No modification to series resistor required • Built-in shunt resistor to clamp noise current • Bi-polar • High-intensity • Up to 100,000-hour life • Shock and vibration resistant T-31⁄4 BAYONET LAMPS FOR GE ET-16 SOCKETS PowerLine LEDs T-31⁄4 BAYONET BASED LAMPS DESIGNED FOR GE ET-16 SOCKETS All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP 11 www.powerlineleds.com REPLACEMENT LENSES FOR GE ET-16 SOCKET PowerLine LEDs 12 SOCKET MODEL NUMBER GE ET-16 REPLACEMENT LENSES FOR GE ET-16 SOCKET PowerLine® LENS PART # DIFFUSION BB4-CR BB4-CA COLOR FIG# Clear Red 1 Clear Amber 1 BB4-CY Clear Yellow 1 BB4-CG Clear Green 1 BB4-CB Clear Blue 1 BB4-CW Water Clear 1 BB4-NR Translucent Red 1 BB4-NA Translucent Amber 1 BB4-NY Translucent Yellow 1 BB4-NG Translucent Green 1 BB4-NW Translucent White 1 BB4 Figure 1 All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP • UL Listed for Type 1, 2, 3, 3R, 4/4X, 12 and 13 • Includes bayonet-based LED lamp and Lexan™ lens • Mounts in 16mm (5/8”) hole • Self-lifting captive wire clamps • 24V, 48V and 120V • Choice of five colors The PowerLine® PL16 Pilot Light features polyester construction for superior corrosion resistance, moisture rejection and electrical insulation. All units are supplied with #6 terminal screws with self-lifting captive wire clamps to accommodate #22 through two #12 AWG wires per terminal. Nickel-plated clamp rings are ideal for corrosive environments. All units mount in a round 16mm (5/8”) hole and are directly interchangeable with competitor units. To select a PowerLine® Pilot Light: 1. Identify your input voltage from the chart below. 2. Select the appropriate PowerLine® LED part number. INPUT VOLTAGE MAXIMUM VOLTAGE PowerLine® LED PART # COLOR 24AC/DC 26 PL16-R24-CR Red 24AC/DC 26 PL16-A24-CA Amber 24AC/DC 26 PL16-G24-CG Green 24AC/DC 26 PL16-B24-CB Blue 24AC/DC 26 PL16-W24-CW White 48AC/DC 52 PL16-R48-CR Red 48AC/DC 52 PL16-A48-CA Amber 48AC/DC 52 PL16-G48-CG Green 48AC/DC 52 PL16-B48-CB Blue 48AC/DC 52 PL16-W48-CW White 120AC/DC 140 PL16-R120-CR Red 120AC/DC 140 PL16-A120-CA Amber 120AC/DC 140 PL16-G120-CG Green 120AC/DC 140 PL16-B120-CB Blue 120AC/DC 140 PL16-W120-CW White LED Lamp for PL-16 Pilot Light (included) 16mm PILOT LIGHT AND LED LAMP PowerLine LEDs www.powerlineleds.com 16mm PILOT LIGHT AND LED LAMP (REPLACES GE ET-16 SOCKET) All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP 13 PowerLine LEDs T-31⁄4 MINIATURE BAYONET www.powerlineleds.com T-31⁄4 MINIATURE BAYONET BASED LAMPS BASED LAMPS 14 - Miniature Bayonet Base Bi-Polar Built-in shunt resistor (optional) High Intensity Up to 100,000-hour life Shock and vibration resistant INCANDESCENT LAMP # PowerLine® PART # STANDARD PowerLine® PART # WITH SHUNT RESISTOR MAXIMUM VOLTAGE APPLIED VOLTAGE 28MB 44 47 51 120MB 755 757 1815 1819 1820 1829 1843 1847 1866 1819L-X-CX 47L-X-CX 47L-X-CX 51L-X-CX 120MBL-X-CX 47L-X-CX 1819L-X-CX 1815L-X-CX 1819L-X-CX 1819L-X-CX 1819L-X-CX 1819L-X-CX 47L-X-CX 47L-X-CX 1819LS-X-CX 47LS-X-CX 47LS-X-CX 51LS-X-CX 120MBLS-X-CX 47LS-X-CX 1819LS-X-CX 1815LS-X-CX 1819LS-X-CX 1819LS-X-CX 1819LS-X-CX 1819LS-X-CX 47LS-X-CX 47LS-X-CX 30 7 7 9 130 7 30 14 30 30 30 30 7 7 28AC/DC 6AC/DC 6AC/DC 8AC/DC 120AC/DC 6AC/DC 28AC/DC 12AC/DC 28AC/DC 28AC/DC 28AC/DC 28AC/DC 6AC/DC 6AC/DC LED COLOR CODE EMITTED COLOR -R-CR -A-CA -G-CG -B-CB -W-CW Red Amber Green Blue White Used to illuminate the following lenses Red Amber Yellow Green Blue White Clear * * * * * * * * * * * * * * * All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP PowerLine LEDs S-6 LAMPS Candelabra Screw Base Double-Contact Bayonet Base Built-in shunt resistor (optional) Bi-Polar High-Intensity Up to 100,000-hour life Shock and vibration resistant INCANDESCENT LAMP # PowerLine® PART # STANDARD PowerLine® PART # WITH SHUNT RESISTOR APPLIED VOLTAGE 3S6/120V 6S6L120-CWX 6S6LS120-CWX 120AC/DC 130 1 6S6/30V 6S6L30-CWX 6S6LS30-CWX 30AC/DC 33 1 6S6/120V 6S6L120-CWX 6S6LS120-CWX 120AC/DC 130 1 6S6DC/120V 6S6DCL120-CWX 6S6DCLS120-CWX 120AC/DC 130 2 6S6/130V 6S6L130-CWX 6S6LS130-CWX 130AC/DC 140 1 6S6DC/130 6S6DCL130-CWX 6S6DCLS130-CWX 130AC/DC 140 2 6S6/155V 6S6L155-CWX 6S6LS155-CWX 155AC/DC 165 1 EMITTED COLOR -CWR -CWO -CWA -CWG -CWB -CWW Red Orange Amber Green Blue White Used to illuminate the following lenses Red Orange Amber Yellow Green Blue * * * * * * * 6S6L Figure 1 White Clear * * * * * * * * * * * * 6S6DCL Figure 2 www.powerlineleds.com LED COLOR CODE MAXIMUM FIG # VOLTAGE S6-LAMPS - All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice. www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP 15 CUSTOM LED ANNUNCIATOR RETROFIT LAMPS • LED solutions to backlight almost any annunciator panel • Multiple voltage options • White or colored LEDs to match lenses • Up to 100,000 hour life • LED lamps operate at cooler temperatures compared to incandescents. Increase efficiency and eliminate downtime. Check and monitor processes more effectively. Accurately identify warning signs with confidence. DDP offers various LED retrofit options for unique annunciator applications. LED lamps can be designed to match almost any voltage and color combinations. We have experienced applications engineers who can assist you in replacing incandescent bulbs with more reliable LED lamp retrofits. Call us to discuss your requirements. www.powerlineleds.com CUSTOM LED ANNUNCIATOR RETROFIT LAMPS PowerLine LEDs 16 www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP PowerLine LEDs All of our products are warranted against defects of manufacture for 3 years from date of purchase providing they have been subjected to normal use and service. Any replacement will be made at no charge except for necessary shipping charges. Returns shall be effected as follows: (1) call factory for a return authorization number, and (2) return products with authorization number prominently displayed, freight prepaid, to DDP at the address listed. This warranty is expressly in lieu of all other warranties expressed or implied and does not extend in any way to consequential or incidental damage, including injury to persons or damage to property. www.powerlineleds.com The terms of this warranty may not be amended, altered or extended except by an instrument in writing executed by an officer of DDP. LIMITED WARRANTY LIMITED WARRANTY www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP 17 NOTES www.powerlineleds.com NOTES PowerLine LEDs 18 www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP DDP 445 South Douglas St. El Segundo, CA 90245-4630 Toll Free 800-421-6815 Tel. 310-640-0442 Fax 310-640-7639 www.powerlineleds.com
120MBL-O-CA 价格&库存
很抱歉,暂时无法提供与“120MBL-O-CA”相匹配的价格&库存,您可以联系我们找货
