.312" PANEL MOUNT REFLECTOR
Data Display Products
T-13/4, Water-Tight Optional
- Reflective Chrome-Plated Body - Mounting Hardware Provided
- For Detailed LED Data, See Discrete Section, MODEL 200
1 Model
PMRL200
- Maximum Panel Thickness .160"(PMRL200); .100"(PMRL200, Water-Tight)
TO ORDER, FOLLOW THE EXAMPLE:
Wires
Select one BOLD component from each numbered category in the tables below.
W
(optional)
Model
1PMRL200
Wire
W
LED
2-BCA
Voltage
3
12H
Water
Tight
4
➜Part Number PMRL200W-BCA12H
STANDARD INTENSITY - DIFFUSED ENCAPSULATION
2 LED
Color
(nm)
-BR
-BA
-BG
RED
AMB
GRN
635
583
565
Voltage/Current
λpk
Iv[1]
Viewing
V/C
(mcd)
Angle
Table[2]
60
60
60
I
I
I
14
16
10
Design
Max
Vf/If
Vf/If
V/C Table I
5V/22mA
5.5V/28mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
MEDIUM INTENSITY - TINTED ENCAPSULATION
LED
-BCR
-BCA
-BCG
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[2]
RED
AMB
GRN
635
583
565
35
35
24
I
I
I
120
100
80
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/7mA
65V/8mA
120VAC/3.5mA
130VAC/4mA
HIGH INTENSITY - WATERCLEAR ENCAPSULATION
LED
-NWR
-NWO
-NWA
-NWG
-NWB
-NWW
-NWL
-NKR
-NKO
-NKA
-NKG
-NKB
-NKW
-NKL
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[2]
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
634
605
592
520
465
2800
2000
2800
2400
700
2500
1800
3600
8000
3600
10000
3000
9200
9200
30
30
30
45
45
50
50
15
15
15
15
15
I
I
I
II
II
II
II
I
I
I
II
II
II
II
634
605
592
520
465
3
Voltage[3]
2
5H
12H
15H
24H
28H
48H
60H
120[4]
4
Water
Tight[5]
-WT
(optional)
SPECIALTY LEDs - DIFFUSED ENCAPSULATION
LED
-RLP[6]
-ALP[6]
-GLP[6]
-LRG
-RAG[7]
-GAR[7]
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
Description
RED
AMB
GRN
RED/GRN
RED/AMB/GRN
GRN/AMB/RED
635
583
565
660/565
630/565
635/565
2.3
2.1
2.3
90/40
6/6/6
5/5/5
50
50
50
60
60
50
[3]
[3]
[3]
Low Power
Low Power
Low Power
Bi-Color, Green Cathode
Tri-Color, Common Cathode
Tri-Color, Common Anode
[1] Iv = typical luminous intensity @ If = 20mA(Ta =25°C). For Low Power LEDs, If = 2mA.
[2] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA.
[3] Ta = 25°C. Voltage "2" indicates external resistor requird. Voltages 5H through 60H are VDC. For AC
operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier, not required for 5H or
120VAC. DC operation not available for 120V. Bi-Color and Tri-Color not available in AC voltages.
[4] Select high intensity LEDs only
56
I
I
I
[5] Drip-proof (not submersible), supplied with two neoprene gaskets.
[6] Omit H when selecting a voltage (e.g. PMR200-RLP12).
[7] -RAG Wire Leads: green anode/black cathode/red anode. -GAR Wire Leads: green cathode/black
anode/red cathode. Tri-Color 5 or 12 volt, omit H from part number.
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
PMRL200
Standard Wire Leads:
6.0" total length(nominal)/.50" stripped (nominal), red
anode/black cathode, 24 AWG TPB UL1061 insulation.
Contact factory for other lengths, gauges and colors.
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
57
很抱歉,暂时无法提供与“PMRL200W-BA12H”相匹配的价格&库存,您可以联系我们找货
