T-2 SLIDE BASED LAMP
Data Display Products
Single-Chip
- For Detailed LED Data, See Discrete Section, MODEL 200.
1
TO ORDER, FOLLOW THE EXAMPLE:
Model
2SB
5SB
55SB
Select one BOLD component from each SHADED column in the tables below.
ANSI No. 2
ANSI No. 5
T5.5
LED
Voltage
1Model
2
3
2SB
-BCG
12H
➜Part Number 2SB-BCG12H
MEDIUM INTENSITY - TINTED ENCAPSULATION
2 LED
-BCR
-BCA
-BCG
λpk
Iv[1]
Color
(nm)
(mcd)
RED
AMB
GRN
635
583
565
120
100
80
Viewing
V/C
Angle
Table[2]
35
35
24
I
I
I
Design
Max
Vf/If
Vf/If
V/C Table I
5V/22mA
5.5V/28mA
6V/21mA
7V/27mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
HIGH INTENSITY - WATERCLEAR ENCAPSULATION
LED
-NWR
-NWO
-NWA
-NWG
-NWB
-NWW
-NWL
-NKR
-NKO
-NKA
-NKG
-NKB
-NKW
-NKL
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[2]
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
634
605
592
520
465
2800
2000
2800
2400
700
2500
1800
3600
8000
3600
10000
3000
9200
9200
30
30
30
45
45
50
50
15
15
15
15
15
I
I
I
II
II
II
II
I
I
I
II
II
II
II
634
605
592
520
465
-NFR
-NFA
-NFG
-NFB
-NFW
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[2]
RED
AMB
GRN
BLU
CWHT
634
592
520
465
75
75
75
75
75
I
I
II
II
II
780
600
780
168
280
Voltage[3]
2
5H
6H
12H
15H
24H
28H
48H
60H
120[4]
Voltage/Current
WIDE ANGLE/FLAT-TOPPED-WATERCLEAR ENCAPSULATION
LED
3
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
6V/15mA
7V/25mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/9mA
65V/10mA
120VAC/3.5mA 130VAC/4mA
SPECIALTY LEDs
LED
-RLP[5]
-ALP[5]
-GLP[5]
-LRG
Color
RED
AMB
GRN
RED/GRN
λpk
Iv[1]
Viewing
V/C
(nm)
(mcd)
Angle
Table[2]
50
50
50
60
[2]
[2]
[2]
635
583
565
660/565
2.3
2.1
2.3
90/40
[1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C); Low Power LEDs @ If = 2mA.
[2] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA.
[3] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC. For
AC operation, insert D after the Voltage (e.g. 24HD). D indicates built-in rectifier: not required for
5H or 120VAC. 120VDC operation not available.
I
Description
Low Power
Low Power
Low Power
Bi-Color
[4] Select high intensity LEDs only.
[5] Omit "H" Voltage designation (e.g. 2SB-RLP12).
Continued…
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
75
Single-Chip
2SB
5SB
55SB
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
76
Single-Chip
Wide Angle LED Lamps
2SB, NFX Series (75°)
5SB, NFX Series (75°)
55SB, NFX Series (75°)
77
很抱歉,暂时无法提供与“5SB-BCR120”相匹配的价格&库存,您可以联系我们找货
