T-31/4 MINIATURE LAMP
Data Display Products
Single-Chip - For Small Lens Applications
- For Detailed LED Data, See Discrete Section, MODEL 200
1
TO ORDER, FOLLOW THE EXAMPLE:
Model[1]
MB400
MBL400
MF400
MFL400
MS400
MSL400
Select one BOLD component from each SHADED column in the tables below.
Bayonet
Bayonet
Flange
Flange
Screw
Screw
LED
1Model
2 -NWG
3Voltage
MS400
24H
➜Part Number MS400-NWG24H
HIGH INTENSITY-WATERCLEAR ENCAPSULATION
2 LED
-NWR
-NWO
-NWA
-NWG
-NWB
-NWW
-NWL
-NKR
-NKO
-NKA
-NKG
-NKB
-NKW
-NKL
λpk
Iv[2]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
634
605
592
520
465
2800
2000
2800
2400
700
2500
1800
3600
8000
3600
10000
3000
9200
9200
30
30
30
45
45
50
50
15
15
15
15
15
I
I
I
II
II
II
II
I
I
I
II
II
II
II
634
605
592
520
465
WIDE ANGLE/FLAT-TOPPED-WATERCOLOR ENCAPSULATION
LED
-NFR
-NFA
-NFG
-NFB
-NFW
λpk
Iv[2]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
BLU
WHT
634
592
520
465
75
75
75
75
75
I
I
II
II
II
780
600
780
168
280
[1] All Models are center anode. Insert C after Model for center cathode (e.g. MBL400C).
[2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C).
[3] See Voltage/Current table for design specifications.
3
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table I
5V/22mA
5.5V/28mA
7V/27mA
6V/21mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
26V/20mA
24V/17mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
Voltage[4]
2
5H
6H
12H
15H
24H
28H
48H
60H
120
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
6V/15mA
7V/25mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
[4] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC.
For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier: not required for
5H or 120VAC. For 120VDC, insert DC after Voltage (e.g. 120DC).
Continued…
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
69
MB400
MBL400
MF400
MFL400
MS400
MSL400
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
70
Wide Angle LED Lamps
MB400, NFX Series (75°)
MBL400, NFX Series (75°)
MF400, NFX Series (75°)
MFL400, NFX Series (75°)
MS400, NFX Series (75°)
MSL400, NFX Series (75°)
71
很抱歉,暂时无法提供与“MB400-NFB5H”相匹配的价格&库存,您可以联系我们找货
