134-1019-441
    CINCH
    同轴连接器(RF) - 适配器 SMA 插头,公引脚 至 SMP 插头,公引脚 50 欧姆
134-1019-441 数据手册
PART NUMBER ITEM BODY 134-1019-441 BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL .00005 MIN OVER COPPER PL .00005 MIN 1 ITEM 2 CONTACT ITEM 3 INSULATOR 4 ITEM COUPLING NUT 5 ITEM COUPLING SPRING BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL .00005 MIN OVER COPPER PL .00005 MIN TEFLON BRASS GOLD PL .00001 MIN OVER NICKEL PL .00005 MIN OVER COPPER PL .00005 MIN BERYLLIUM COPPER UNPLATED REV ECO DATE 1 2  3  INITIAL RELEASE  EC-1906003  EC-1908012   21FEB2019  04JUN2019  29AUG2019  .621 5 HEX  .218  REF 1 2 3 NOTES:    4 1. ELECTRICAL SPECIFICATIONS:     1.1 IMPEDANCE: 50 OHMS   1.2 FREQUENCY RANGE: 0-26.5 GHz   1.3 VSWR: 1.20 MAX. 0-20 GHz             1.25 MAX. 20-26.5 GHz   1.4 WORKING VOLTAGE: 335 VRMS MAX AT SEA LEVEL   1.5 DIELECTRIC WITHSTANDING VOLTAGE: 1000 VRMS MIN AT SEA LEVEL   1.6 INSULATION RESISTANCE: 10000 MEGOHM MIN   1.7 CONTACT RESISTANCE:     1.7.1 CENTER CONTACT - INTIAL 5 MILLIOHM MAX, AFTER                             ENVIRONMENTAL 8 MILLIOHM MAX     1.7.2 OUTER CONDUCTOR - GOLD PLATED INITIAL 1 MILLIOHM MAX, AFTER                             ENVIRONMENTAL 1.5 MILLIOHM MAX   1.8 CORONA  LEVEL: 250 VOLTS MINIMUM AT 70,000 FEET      INSERTION LOSS: .1 dB MAX AT 1GHz      RF LEAKAGE: -50 dB AT 2.5 GHz      RF HIGH POTENTIAL WITHSTANDING VOLTAGE: 700 VRMS AT 4 AND 7 MHz   2. MECHANICAL SPECIFICATIONS:     2.1 ENGAGE/DISENGAGE FORCE (SMP): 3.4 LBS MAX ENGAGEMENT                                  5 LBS TYPICAL DISENGAGEMENT   2.2 ENGAGE/DISENGAGE TORQUE (SMA): 2 IN LBS MAX   2.3 MATING TORQUE (SMA): 7-10 IN LBS MAX   2.4 CONTACT RETENTION FORCE: 6 LBS MIN   2.5 DURABILITY: 500 CYCLES MIN   3. ENVIRONMENTAL:   (MEETS OR EXCEEDS THE APPLICABLE PARAGRAPH OF MIL-PRF-39012)      3.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B   3.2 OPERATING TEMPERATURE: -65  ¥ C TO 165  ¥ C   3.3 CORROSION: MIL-STD-202, METHOD 101, CONDITION B   3.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION B   3.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION B   3.6 MOISTURE: MIL-STD-202, METHOD 106 SCALE  4:1 Model No: This PROPRIETARY Document is property of Cinch Connectivity Solutions.It is confidential in nature, non-transferable, and issued with the clear understanding that it is not  traced or copied without permission and is returnable upon demand.   INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. JOHNSON 134-1019-441/450 RoHS2 Cage Code 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH Title: ASSEMBLY, ADAPTER BETWEEN SERIES SMA PLUG TO SMP PLUG 3RD ANGLE PROJECTION Drawing No. Drawn by: .XX  # .02 .XXX  # .010 Date: ANGLES  # 2 ¥ 2/21/2019 REV. 134-1019-441/450 Roman.Yao Size B DO NOT SCALE DRAWING Workmanship Std:  NONE 3 Sheet 1  OF  1
134-1019-441 价格&库存
很抱歉,暂时无法提供与“134-1019-441”相匹配的价格&库存,您可以联系我们找货
