V12
CHB200 SERIES
165 TO 200 WATT 2:1 INPUT
DC-DC CONVERTERS
SINGLE OUTPUT
FEATURE
*165 - 200W Isolated Output
* Efficiency to 93%
* Fixed Switching Frequency
* Input under-voltage Protection
* Over Temperature Protection
* Over Voltage/Current Protection
* Remote On/Off
* Industry Standard Half-Brick Package
* Fully Isolated 1500VDC
* No Tantalum Capacitor Inside
MODEL
INPUT
OUTPUT
OUTPUT CURRENT
CAPACITOR
INPUT CURRENT
% EFF.
NUMBER
VOLTAGE
CHB200-24S3V3 18-36 VDC
VOLTAGE
MIN.
MAX.
NO LOAD
FULL LOAD
LOAD MAX.
3.3 VDC
0 mA
50 A
140 mA
7.64 A
90
10000μF
40 A
16.7 A
240 mA
230 mA
9.16 A
91
10000μF
CHB200-24S05
18-36 VDC
5 VDC
CHB200-24S12
18-36 VDC
12 VDC
0 mA
0 mA
9.03 A
92.5
10000μF
CHB200-24S24
18-36 VDC
8.3 A
4.2 A
40 mA
70 mA
9.23 A
91
91
2200μF
18-36 VDC
0 mA
0 mA
9.12 A
CHB200-24S48
24 VDC
48 VDC
CHB200-48S3V3 36-75 VDC
3.3 VDC
0 mA
50 A
80 mA
3.80 A
90.5
10000μF
2000μF
CHB200-48S05
36-75 VDC
5 VDC
0 mA
40 A
120 mA
4.55 A
91.5
10000μF
CHB200-48S12
36-75 VDC
12 VDC
0 mA
16.7 A
90 mA
4.49 A
93
10000μF
8.3 A
50 mA
4.56 A
91
2200μF
4.2 A
60 mA
4.59 A
91.5
2000μF
CHB200-48S24
36-75 VDC
24 VDC
0 mA
CHB200-48S48
36-75 VDC
48 VDC
0 mA
NOTE:
1. Nominal Input Voltage 24, 48 VDC
2. The output terminal of 48Vout models required a minimum capacitor 47uF to maintain specified regulation.
1
V12
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENRAL SPECIFICATIONS:
Input Voltage Range ....…………........….......... 24V ................ 18-36V
48V ……….… 36-75V
Input Surge Voltage (100ms max.) ………....…. 24V ......... 50Vdc max.
48V … 100Vdc max.
Under voltage lockout ………..….. 24Vin power up ….…..……..…. 17V
24Vin power down ………..…. 16V
48Vin power up…………..…. 35V
Efficiency .................…..................................……..........…....... See Table
Isolation Voltage ... Input/Ouput, Input/Case, Output/Case ... 1500VDC min.
Isolation Resistance .............................…............…............. 107 ohm min.
Isolation Capacitance …………………..……………………… 1000pF typ.
Switching Frequency........................ 3V3 ................................ 200KHz typ.
5V ................................. 300KHz typ.
48Vin power down ………..…. 33V
Operating Case Temperature ..………....….....……........ -40℃ to 100℃
12V&24V&48V …….…... 330kHz typ.
Positive Logic Remote On/Off:
Storage Temperature ……….………....…....……............ -55℃ to +105℃
Logic Compatibility ……………... Open Collector ref to -Input
Module on ……..……. > 3.5Vdc to 75Vdc or Open Circuit
Module off ……………………….………….. 0 to < 1.2Vdc
Input Filter (note 6) ……………………………………..….……... PI Type
Thermal Shutdown, Case Temp…..……………………..……. 110℃ typ.
Humidity......................................................95% RH max. Non condensing
MTBF ………. MIL-STD-217F, GB, 25℃, Full Load ..…… 750Khrs typ.
OUTPUT SPECIFICATIONS:
Case Material ...............…......…… Aluminum Baseplate with Plastic Case
Voltage Accuracy: ......................................……..….......... 1.0% max.
Weight ………………………………………………………………….... 114g
Transient Response: 25% Step Load Change .……………3.5Vdc to 75Vdc or open circuit
5. Trim-up ………….. connect a resistor between the trim pin and +sense.
Trim-down …….…. connect a resistor between the trim pin and –sense.
Load Regulation (note2) ……………………….........…...... 0.2% max.
Over Voltage Protection trip Range, % Vo nom. .................. 115-140%
Current Limit .................……………….... 105% ~140% Nominal Output
Start up Time ………………………………………………….. 150ms typ.
6. The input terminal recommend to parallel with 100uF for 48Vin and
220uF for 24Vin ESR
很抱歉,暂时无法提供与“CHB200-24S12”相匹配的价格&库存,您可以联系我们找货
