CLIFF
CLIFFCON® CONNECTORS
Connectors designed for high power applications, where a high quality, reliable, locking,
touch-proof connector system is required.
Features
§ Touchproof contacts
§ Polarized
§ Easy Locking / Unlocking
§ Reliable wiping contacts / Gold plated
§ Faston and screw / solder connections
§ Built in cable clamp (6mm - 15mm cable)
§ Chassis connector is panel airtight. Fits std XLR cutout
§ Tough and durable
FCR2062
4 Pole Plug
FCR2064
4 Pole Socket
Solder Tags
FCR20642
4 Pole Socket
PC Tags
CLIFF
FCR2063
4 Pole 90° Plug
Specification
1) Safety leading ground pin - makes first, breaks last.
2) Rated Voltage - 240VAC
3) Rated Current: 4 pin 20A RMS @ 80°C, 30A RMS @ 20°C (5% duty cycle)
4) Inrush Current: >30A / 20mS
5) Contact Resistance: 20MΩ @ 4000V
7) Operating Temp: -20°C to +80°C
8) Max wire size: 6mm2 / 10AWG solid, 4mm2 / 12AWG stranded
9) Gold plated touchproof contacts.
© CLIFF 09/2021 iss 3
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“FCR2063”相匹配的价格&库存,您可以联系我们找货
