CP30201W
CP30201W
    CLIFF
    适配器连接器 USB-C(USB TYPE-C),插座 至 USB-C(USB TYPE-C),插座 面板安装,法兰
CP30201W 数据手册
CLIFF PANEL CUTOUT MAXIMUM PANEL THICKNESS 3mm HOLES TO SUIT SCREW USED ISS. AMEND DATE 1 2 3 ISSUED USAGE NOTES ADD WHITE VARIANTS 02/09/19 07/10/19 25/06/21 29 24.0 19.0 FIXING HOLE VARIANTS: Ø3.5mm CSK 82° x Ø5.85 'X' VERSION HAS Ø2.5 PLAIN HOLES. A12 2.8 2.3 A12 B1 31 ∅24 B1 B12 A1 B12 A1 RoHS ü COMPLIANT TOLERANCE NO DEC. PLACE ± 0.50 1 DEC. PLACE ± 0.20 2 DEC. PLACE ± 0.10 HOLE Ø ± 0.10 ANGLES ± 1/2° 26 UNLESS OTHERWISE STATED Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2019 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: SEE NOTES CLEAN DRAWN: D.P.J. MATERIAL: TITLE: APPROVED: T.J.O. 3rd ANGLE PROJECTION: DO NOT SCALE FT USBC FEMALE-FEMALE DRWG. No. CP30201 FORM: A4DRWGH
CP30201W 价格&库存
很抱歉,暂时无法提供与“CP30201W”相匹配的价格&库存,您可以联系我们找货
