CP30211W
CP30211W
    CLIFF
    适配器连接器 USB-C(USB TYPE-C),插头 至 USB-C(USB TYPE-C),插座 面板安装,法兰
CP30211W 数据手册
CLIFF PANEL CUTOUT MAXIMUM PANEL THICKNESS 3mm HOLES TO SUIT SCREW USED ISS. AMEND DATE 1 2 ISSUED ADD WHITE VARIANTS 07/02/17 25/06/21 2.8 2.3 24 ∅24 31 Ø2.5 A1 A12 B1 B12 Materials: Frame: PA66, UL94-V2 Insert: ABS - UL94 HB 19 A12 A1 Recepticle to Plug connection: A1 to A1, A2 to A2, A3 to A3 ....... etc.. B1 to B1, B2 to B2, B3 to B3 ....... etc.. USB-C Specification: Maximum Rated Current - 3A Maximum Working Voltage - 30V Withstanding Voltage - 100V for 1 minute. Contact Resistance - 40 Milli-ohms Max. Insulation Resistance - 100 Mega-ohms Min. Insulator Flammability Rating - UL-94V0 Insertion Life - 10,000 Cycles. 24.0 39.0 7.5 19.0 B12 B1 'X' VERSION Ø2.5 PLAIN HOLES RoHS ü COMPLIANT TOLERANCE NO DEC. PLACE ± 0.50 1 DEC. PLACE ± 0.20 2 DEC. PLACE ± 0.10 HOLE Ø ± 0.10 ANGLES ± 1/2° FIXING HOLE VARIANTS: ∅3.5mm CSK 82° x ∅5.85 26 'X' VERSION HAS Ø2.5 PLAIN HOLES. UNLESS OTHERWISE STATED Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2017 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: SEE NOTES CLEAN DRAWN: D.P.J. MATERIAL: TITLE: APPROVED: T.J.O. 3rd ANGLE PROJECTION: DO NOT SCALE FT USBC FEMALE-MALE DRWG. No. CP30211 FORM: A4DRWGH
CP30211W 价格&库存
很抱歉,暂时无法提供与“CP30211W”相匹配的价格&库存,您可以联系我们找货
